查看: 6401|回复: 4
[资料] ENHANCED HIGH-SIDE CURRENT MONITOR -- ZXCT1010
发表于 2014-11-28 09:59:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
DESCRIPTION
The ZXCT1010 is a high side current sense monitor.
Using this device eliminates the need to disrupt the
ground plane when sensing a load current.
It is an enhanced version of the ZXCT1009 offering
reduced typical output offset and improved accuracy
at low sense voltage.
The wide input voltage range of 20V down to as low as
2.5V make it suitable for a range of applications. A
minimum operating current of just 4μA, combined
with its SOT23-5 package make suitable for portable
battery equipment.
FEATURES
• Low cost, accurate high-side current sensing.
• Output voltage scaling.
• Up to 2.5V sense voltage.
• 2.5V – 20V supply range.
• 300nA typical offset current.
• 3.5μA quiescent current.
• 1% typical accuracy.
• SOT23 -5 package.
APPLICATIONS
• Battery Chargers
• Smart Battery Packs
• DC Motor control
• Over current monitor
• Power Management
• Programmable current source
沙发
发表于 2014-11-28 20:06:00 | 只看该作者
这个做电流保护不错,但是不可控
板凳
 楼主| 发表于 2014-11-29 16:13:37 | 只看该作者
软启动, 防短路
地板
 楼主| 发表于 2014-11-29 16:14:35 | 只看该作者
过流保护
5#
 楼主| 发表于 2014-11-29 16:46:47 | 只看该作者
SuperPro 过流电路
GMT+8, 2026-11-7 08:33 , 耗时 0.479325 秒, 21 个查询请求 , Gzip 开启.
