查看: 5074|回复: 0
[ChipProg] DIP40/TSOP56 AE-TS56-16Am
发表于 2015-7-4 12:11:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
DIP40/TSOP56 specialized adapter for FLASH memory
Description:
        DIP40/TSOP56 specialized adapter for FLASH memory. Device package dimensions: 14 x 20 mm, 0.5 mm pitch.
Supported Devices:
        Click the device programmer model below to get an appropriate list of the devices supported by this programmer with this adapter:
  • ChipProg-481
  • ChipProg-G41
  • ChipProg-48
  • ChipProg-40
        Adapter Connection Table:
DIP-40
TSOP-56
U1, 74AHC573
U2, 74AHC573
C1, 150pF
C2, 0.1uF
1
29
2
28
3
11
11
1
4
14
5
56
6
55
7
13
8
17
9
16
10
20
11
21
12
22
13
23
14
24
15
25
16
26
17
31
18
27
19
30
20
33.52
1, 10
1, 10
2
2
21
32
22
34
23
35
2
24
36
2
25
37
3
26
38
3
27
39
4
28
40
4
29
41
5
30
42
5
31
44
6
32
45
6
33
46
7
34
47
7
35
48
8
36
49
8
37
50
9
38
51
9
39
53
40
43
20
20
1
1
12
2
13
3
12
4
13
5
14
6
15
7
16
8
17
9
18
10
19
11
16
12
15
15
14
18
17
19
18
54
19
GMT+8, 2026-11-14 11:31 , 耗时 0.365372 秒, 21 个查询请求 , Gzip 开启.
