查看: 3541|回复: 1
[ChipProg] DIP40/TSOP48 AE-TS48-NAND-4
发表于 2015-7-7 12:25:44 | 显示全部楼层 |只看大图 回帖奖励 |倒序浏览 |阅读模式
DIP40/TSOP48 specialized adapter for NAND Flash devices
Description:
        DIP40/TSOP48 specialized adapter for NAND Flash devices. Device package dimensions:12 x 20 mm, 0.5 mm pitch.
Supported Devices:
        Click the device programmer model below to get an appropriate list of the devices supported by this programmer with this adapter:
  • ChipProg-481
  • ChipProg-G41
  • ChipProg-48
  • ChipProg-40
        Adapter Connection Table:
DIP-40
TSOP-48
74LVC245
74LVC245
74LVC245
C1,1uF
C2,1uF
R1,5.1k
R2,5.1k
R3,5.1k
R4,5.1k
51k
51k
51k
51k
51k
51k
51k
51k
1
35
2
2,23
3
3
1
4
4
1
5
5
1
6
6
1
7
7
1
8
9
8
11
9
9
10
10
11
14
12
15
14
1
1
15
20
16
16
17
17
18
2
18
18
19
19
13,20,37
13,25,36,48
4,5,6,7,8,3,10,19
10,19
10,19
2
1
2
2
2
2
2
2
2
2
21
9
26
11
1
22
8
27
12
1
23
7
28
13
1
24
6
29
14
25
5
30
15
26
4
31
16
27
3
32
17
28
2
33
18
1
29
9
40
11
1
30
8
41
12
31
7
42
13
32
6
43
14
33
5
44
15
34
4
45
16
1
35
3
46
17
1
36
2
47
18
1
38
34,39
39
38
40
12,37
1,20
20
20
2
2
2
2
2
GMT+8, 2024-5-7 16:28 , 耗时 0.118114 秒, 20 个查询请求 , Gzip 开启.
