查看: 4972|回复: 10
flashprog,开源的
发表于 2015-11-8 17:38:22 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
又一个开源的编程器,学习的好东东了
原文
                Description
FlashProg is USB base flash memory programmer which is specifically design to read and program 3.3V SPI flash memory devices.
                Features
  • Based on USB interface.
  • Support for wide range of 3.3V SPI flash memory chips.
  • Easy to build programmer with minimum number of components.
  • No surface mounted components in programmer device.
  • Support for read, write, erase, chip protection configuration and chip identification operations.
  • Terminal base simple PC interface.
  • Support for both Windows and Linux operating systems.
flashprog-v1.0.0-win32-full.7z (1.75 MB, 下载次数: 14)
收藏收藏2 分享分享 支持支持 反对反对
沙发
 楼主| 发表于 2024-3-31 23:02:10 | 显示全部楼层
源代码地址
https://sourceforge.net/p/flashprog/code/HEAD/tree/
方便大家,下面附件可以直接下
flashprog-code-r2-trunk.zip (275.56 KB, 下载次数: 0)
GMT+8, 2024-5-22 01:46 , 耗时 0.093718 秒, 20 个查询请求 , Gzip 开启.
