查看: 1764|回复: 0
[GPS] 基于时空系统统一的北斗与GPS融合定位
发表于 2014-10-1 06:13:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* 谨以此文祝贺宁津生院士80华诞
第41卷 第5期测 绘 学 报Vol.41,No.5
 2012年10月Acta Geodaetica et Cartographica Sinica Oct.,2012
GAO Xingwei,GUO Jingjun,CHENG Pengfei,et al.Fusion positioning of Compass/GPS Based on Spatio Temporal System Unification
[J].Acta Geodaetica et Cartographica Sinica,2012,41(5):743-748,755.(高星伟,过静珺,程鹏飞,等.基于时空系统统一的北斗与GPS
融合定位[J].测绘学报,2012,41(5):743-748,755.)
基于时空系统统一的北斗与GPS融合定位*
高星伟1,过静珺2,程鹏飞1,陆明泉2,丁志刚3,秘金钟1,成英燕1,敖 翔2,祝会忠1
1.中国测绘科学研究院,北京100830;2.清华大学,北京100084;3.山东北斗华宸导航技术有限公司,山东淄博255088
Fusion Positioning of BeiDou/GPS Based on Spatio Temporal System Unification
GAO Xingwei 1,GUO Jingjun2,CHENG Pengfei 1,LU Mingquan2,DING Zhigang3,BEI Jinzhong1,CHENG Yingyan1,
AO Xiang,ZHU Huizhong1
1.Chinese Academy of Surveying and Mapping,Beijing 100830,China;2.Tsinghua University,Beijing 100084,China;3.Shandong
Compstar Navi-technology Limited Company,Zibo 255088,China
Abstract:Currently,nine BeiDou satellites have been launched.Regional positioning system of BeiDou has been constructed.
It can supply Chinese users with primary three-dimensional positioning.Mainly work of BeiDou is focused on tests
and evaluations.This paper discusses conversion of time and coordinates between BeiDou and GPS,broadcasting ephemeris
 and calculation of satellite coordinates,and precise positioning with BeiDou and GPS.The united precise positioning
with BeiDou and GPS is realized,and proved by test results of observations on Sept.29,2011.The tests and results can
supply reference to construction of BeiDou II system.
Key words:BeiDou satellite navigation system;GPS;fusion positioning
摘 要:我国的北斗卫星导航定位系统目前已经发射9颗北斗卫星,北斗区域卫星导航系统的基本系统已建设完成,正开展星
地联调和测试评估工作,已经具备我国范围内的初步三维定位导航能力。本文研究北斗和GPS的时间系统/坐标系统的统一、
卫星广播星历与卫星位置计算,以及二者的高精度定位算法,并实现了北斗和GPS载波相位的数据融合和高精度联合定位,最
后通过2011-09-29的实测数据和处理结果证明了本文方法的正确性,同时为北斗二号系统的调试提供了相关试验与结果。
关键词:北斗卫星导航系统;全球定位系统;融合定位
中图分类号:P228    文献标识码:A    文章编号:1001-1595(2012)05-0743-06
基金项目:国家863计划(2011AA120503;2012BAB16B01);中国测绘科学研究院基本科研业务费(7771017;7771202;
7771020;7771120);地理空间信息工程国家测绘地理信息局重点实验室开放基金(201103)
1 引 言
北斗卫星导航系统是中国自主研制开发的、
具有自主知识产权的卫星导航定位系统,是继美
国的GPS全球定位系统、俄罗斯的GLONASS
之后,国际上可定位的第3个卫星导航系统。北
斗卫星导航试验系统(北斗一号)已于2005年建
成,正在建设的北斗卫星导航定位系统(北斗二号
一期)是由5颗GEO 卫星、3颗IGSO 卫星和4
颗MEO 卫星组成,覆盖中国境内及周边地区。
其建设与发展将遵循开放性、自主性、兼容性、渐
进性原则。为用户提供高质量的定位、导航和授
时服务,并具有短报文通信功能[1]。目前已经发
射9颗北斗卫星,在轨可工作卫星己有7颗,其中
4颗GEO卫星、3颗IGSO卫星。因此,北斗区域
卫星导航系统的基本系统已经建立,已经具备我
国范围内初步三维定位导航能力。为了测试和验
证目前北斗II系统在高精度相对定位方面的定
位精度,本文首先对北斗和GPS联合高精度定位
的相关问题进行了阐述,然后用清华大学和山东
北斗华宸导航技术有限公司联合开发的BeiDou/
GPS/GLONASS三系统双频高精度接收机,进行
了BeiDou/GPS实测数据的采集与高精度处理,
最后对测试结果进行了分析总结。试验结果不但
验证了本文方法的正确性,也说明目前的北斗二
号一期系统已经基本具备高精度的区域定位导航
能力。但由于卫星数量和分布的不均匀,整体能
力仍稍逊于GPS系统,随着后期的北斗卫星的不
断发射与系统的完善,这些问题将迎刃而解。
October 2012Vol.41No.5AGCS http:∥xb.sinomaps.com
2 定位采用的基准
不同的卫星定位系统有特定的坐标基准和时
间基准。北斗采用的是CSCS2000国家大地坐标
系统和北斗时间系统(BeiDouT);GPS采用的是
WGS-84坐标系统和GPS时间系统(GPST)[2-3]。
在北斗和GPS联合解算时,应将二者的坐标基准
和时间基准进行转换和统一。
(1)CGCS2000与WGS-84坐标系在原点、
尺度、定向及定向的定义都是相同的。参考椭球
非常相近,在4个椭球常数a、f、GM、ω 中,唯有
扁率f 有微小差异(df)
df=fCGCS2000-fWGS84=1.643 484×10-11
扁率变化对大地经度L、大地纬度B 和大地
高H 的影响为
dL=0
dB=M 2-(2f-f ) [ 2 sin2B]
(1-f) sin Bcos Bdf
d H= M
1-f 1-(2f-f ) [ 2 sin2B ]sin2 Bd
f 烎
(1)
通过上面的公式,可得出:①df 不引起大地
经度变化;②df 引起大地纬度的变化范围为0~
0.105mm;③ df 引起大地高的变化范围为0~
0.105 mm。因此,在当前的坐标测量精度
(±1mm)条件下,从理论上来说,由两个坐标系
的参考椭球的扁率差异引起同一点在WGS-84
和CGCS2000坐标系内的坐标变化,对于短距离
的相对定位可以忽略。
(2)BeiDouT和GPST都采用原子时,秒长
定义一样,没有闰秒问题。不同的是二者时间系
统的起算点不同。GPST是从1980-01-06T00:00
开始起算,并且无闰秒。而世界协调时有闰秒问
题,到2006年GPST与世界协调时之间的闰秒差
异已达到14s。BeiDouT是从2006-01-01T00:00
开始起算,没有闰秒问题[1]。因此,BeiDouT 与
GPST除了相差1356周外,还始终保持一个14s
的系统差,二者之间的转换关系为
BeiDou周=GPS周-1356
BeiDou秒=GPS秒烍
-14 烎
(2)
3 定位算法
3.1 广播星历与卫星位置计算
GPS广播星历数据格式采用标准的RINEX
格式,目前常用版本有RINEX 2.x和RINEX 3.x。
由于北斗系统正在建设中,所以既便是最新的
RINEX 3.1中也没有对北斗数据格式明确的规
定。但由于北斗二代系统采用与GPS相类似的
定位原理和卫星轨道参数,因此通常是参照GPS
的相关说明,按RINEX 3.1中GPS的形式,编写北
斗广播星历文件,只是在卫星号前分别用字母“G”
和“C”区分GPS卫星和北斗卫星。同时,采用
BeiDouT表示北斗卫星的参考时刻,采用CGCS
2000坐标基准表示北斗卫星的轨道信息。
北斗卫星星座共包括3类卫星:地球静止轨
道(GEO)卫星、倾斜地球同步轨道(IGSO)卫星
和中等高度地球轨道(MEO)卫星。其中IGSO
和MEO 卫星的瞬时位置计算与GPS的类似,
GEO卫星稍有不同,主要是轨道倾角对同步轨道
带来的影响。
3.2 定位解算模型
3.2.1 北斗和GPS单独定位
高精度的卫星定位都是基于载波相位观测值
的,北斗和GPS的载波相位观测方程为
λCφC=RC+λC NC+(tr+tCG-tC
s )C +
  TC-IC+MC+PC+eC
λGφG=RG+λG NG+(t
r -tG
s )C+TG-
  IG+MG+PG+e
烎G
(3)
式中,λ为载波波长;φ 为载波相位观测值;R 为卫
星到接收机相位中心的几何距离;N 为载波模糊
度;tr
为接收机的钟差;tCG 为BeiDouT与GPST
之间的同步误差;ts
为卫星的钟差;C 为光速;T
为对流层延迟误差;I为电离层延迟误差;M 为多
路径误差;P 为天线相位中心偏差;e为其他非模
型化误差和载波相位观测噪声;上标C和G分别
用于区分BeiDou和GPS。不同的载波频率对应
不同的载波波长:BeiDou的双频频率分别为B1:
1561.098MHz,B2:1207.140MHz;GPS的双频频率
分别为L1:1575.42MHz,L2:1227.60MHz。在实
际定位中,公式(3)中的时间系统同步误差项会被
接收机钟差项吸收,相当于下面的式子
λCφC=RC+λC NC+(tC
r-tC
s)C+TC-IC+
  MC+PC+eC
λGφG=RC+λG NG+(tG
r-tG
s)C+TC-IG+
  MG+PG+e
G 烎
(3′)
即含有不同的接收机钟差项tC
和t G
r。
744
第5期高星伟,等:基于时空系统统一的北斗与GPS融合定位
一般情况下,由于式(3)中含有过多的未知数
和误差信息,所以造成定位解算的效率和精度并
不是很好。为了提高定位精度,实际使用中最常
采用的方法是分别用式(3)在2颗卫星和2台接
收机间求二次差,得到如下的双差观测方程
λCΔ ΔφC=Δ ΔRC+λC·Δ ΔNC+Δ ΔTC-Δ ΔIC+
  Δ ΔMC+Δ ΔPC+Δ ΔeC
λGΔ ΔφG=Δ ΔRG+λG·Δ ΔNG+Δ ΔTG-Δ ΔIG+
  Δ ΔMG+Δ ΔPG+Δ Δe
烎G
(4)
式中,各符号含义与式(3)相同,Δ Δ表示双差算
子。双差观测方程的优点是消除了接收机钟差和
卫星钟差的影响,消除了大部分电离层延迟和对
流层延迟误差等系统误差,并且保持了载波模糊
度的严格整周特性。
3.2.2 北斗和GPS联合定位
北斗和GPS联合定位时,首先要解决2个系
统的基准问题,必须采用统一的时间基准和坐标
基准,即可统一采用WGS-84坐标系和GPST基
准,也可以采用CGCS2000坐标系和BeiDouT基
准。由第2节的说明和分析可知,最新的WGS-84
与CGCS2000的系统差异理论上在0~0.105mm
范围内,对于短距离的相对定位来说,完全可以忽
略。其次在时间基准同步时,由于BeiDouT 与
GPST之间还存在微小的同步误差。为了消除不
同卫星系统对定位的影响,这里双差组合仅限定
在同一系统内部,即对于BeiDou系统可以得到
类似式(4)的方程组,对于GPS系统,也可得方程
(4)的方程组,然后进行联立可得BeiDou/GPS双
差载波相位观测方程。对于相对定位中的双差观
测方程,由于彻底消除了卫星钟差和接收机钟差
影响,并且在站间距离较近,多路径误差有效抑制
或可以忽略的情况下,双差观测方程中只剩下三
维相对位置、整周模糊度未知数。另外,需要说明
的是天线相位中心偏差,其值由天线厂商提供或
者事先精确标定,结合天线定向安置进行影响修
正与消除。因此,简化后的BeiDou/GPS双差载
波相位观测方程为
ΔbC aC 0
ΔbG 0 a [ ] G
dX
Δ ΔNC
Δ ΔN
燅G
Δ ΔLC
Δ ΔL [ ] G (5)
式中
a=
λ 0 … 0
0 λ … 0
0 0 …
烏 烐 烑
λ
m-1
b=
x1-x0
r0
y1-y0
r0
z1-z0
r0
xm-x0
r0
ym-y0
r0
zm-z0
烎0
(6)
式(5)中,dX 表示相对坐标改正向量;Δ ΔN
为双差整周模糊度向量;b为与dX 相对应的系数
矩阵;a为与Δ ΔN 相对应的系数矩阵;L 为常数项
向量,其中Δ 为单差算子。式(6)中,(x0,y0,z0)
为用户位置初值;xm,y( m,zm)为卫星坐标;r0
用户位置初值与卫星之间的几何距离;m 为观测
到的同一系统卫星数。由于限定于同一系统内部
求差,所以m 颗GPS卫星可得到m-1个GPS
双差观测方程,n颗北斗卫星可得到n-1个北斗
双差观测方程,共m+n-2个观测方程。对于
式(5)的求解可以采用最小二乘法或卡尔曼滤波的
形式,可参考相关文献[4-5],这里不再赘述。一般是
先求出双差整周模糊度Δ ΔN[6-9],然后再求出相对
坐标改正值,进而得到精确的相对位置信息。
4 实测结果与分析
4.1 数据采集
2011-09-29,采用清华大学和山东北斗华宸
导航技术有限公司联合开发的BeiDou/GPS/
GLONASS三系统双频高精度接收机,在山东潍
坊进行了A、B2点的短基线相对定位试验。基
线长度为1031m,数据采样率为1Hz,卫星高度
截止角为15°。为了将北斗定位结果与GPS进行
比较,选择了GPS比较具有代表性的一段观测数
据,数据观测时间将近2h,接收和使用的卫星为:
北斗卫星,1、3、4、7、8;GPS卫星,3、6、7、8、11、
13、16、19、23、24。
与GPS系统不同的是,北斗系统的卫星由不
同类型的卫星组成,其中的1、3、4号卫星属于
GEO卫星,7和8号卫星属于IGSO卫星。因本
次试验重点分析北斗和GPS卫星的定位情况,故
没有对GLONASS数据进行处理。
4.2 数据处理
(1)坐标参考值:为了对目前的北斗系统高
745
精度定位情况进行精确比较,首先对其中的GPS
数据及周边国际IGS站数据,采用精密星历和
GAMIT软件进行静态基线处理,得到A 点和B
点的准确的坐标及其基线分量值,作为真值,以便
后面的定位结果与此进行比较;
(2)坐标初值:GPS的坐标初值可以采用单
点定位的方式确定,而关于北斗的坐标初值确定
有两种方法,一种方法是由GPS提供,另外一种
方法是北斗单独进行单点定位提供。需要说明的
是北斗的单点定位精度。笔者在2011年5月份
进行了的实测数据处理与比较,当时卫星情况与
本文的实验情况类似,可以接收到4、5颗有效北
斗卫星。由于篇幅所限,这里只给出最终的
BeiDou/GPS单点定位结果(如表1),此结果采用
北斗和GPS等权处理。从表1可以看出,单独利
用北斗进行初值确定也是完全可以的,另外还可
以通过伪距差分方式进一步提高初值精度。
表1 2011年5月BeiDou/GPS单点定位误差RMS值
Tab.1 RMS of absolute bias of absolute GPS,BeiDou and
BeiDou/GPS positioning in 2011May m
N 分量误差E 分量误差U 分量误差
GPS 1.846 8 1.610 1 3.927 7
BeiDou 12.737 8 2.429 4 20.562 7
BeiDou/GPS 2.512 7 1.403 6 8.626 7
(3)整周模糊度:如3.2节所述,整周模糊度的
快速准确确定是高精度载波相位定位的首要前提条
件,由于北斗系统与GPS系统类似,所以GPS的模
糊度搜索方法同样适用于北斗模糊度搜索,如
LAMBDA方法、单历元整周模糊度搜索方法等[6-8]。
(4)定位结果:准确固定整周模糊度后,首先
对GPS数据进行最小二乘解算,可以得到每历元
GPS高精度相对定位结果,与GAMIT定位结果
进行比较,可得到AB 基线在北(N)、东(E)、天顶
(U)3个方向上的误差值,如图1~图3。
图1
Fig.1
746
图2
Fig.2
747
图3
Fig.3
  从图1中可以得出:GPS的PDOP值在2~4
之间变化,卫星数在7~10之间,水平方向定位结
果一般优于1cm,垂直方向定位结果一般优于
2cm,在卫星数增加或减少时会出现个别较大的
误差,一般为2cm左右。
然后采用与GPS类似的方法对北斗数据进行
处理,可得到北斗的定位结果,如图2所示。由于
北斗卫星数一直为5,所以PDOP变化比较平缓。
由于目前北斗卫星数较少,并且分布不均匀,主要
集中在东西方向上,所以北斗卫星的PDOP值整体
都比较大,并且东西方向的定位精度明显高于其他
方向,与GPS处于同一精度。由于卫星数比较稳
定,东西方向精度甚至还稍优于GPS的;其他方向
由于受卫星数和卫星分布的限制,稍差于GPS的。
最后采用上述方法对北斗和GPS数据进行
联合定位解算,得到BeiDou/GPS的定位结果,如
图3所示。需要说明的是,北斗和GPS在联合解
算时分配的是相同的权比,并且结果图中各轴含
义和误差单位同前。从图3 中可以得出:
BeiDou/GPS的卫星数明显多于单一卫星系统,
PDOP值也有所下降,特别是GPS卫星数较少,
分布较差时(如图中的4800s附近),定位精度也
较单一系统有所提高。
(3)为了便于定量分析比较,对上述3种情
况下的每个分量误差进行概率统计,求出其均方
根误差(RMS),列于表2中。
表2 不同系统载波相位相对定位绝对误差RMS值
Tab.2 RMS of absolute bias of differential GPS,BeiDou
and BeiDou/GPS positioning mm
N 分量误差E 分量误差U 分量误差
GPS 6.5 7.0 12.9
BeiDou 9.9 3.1 18.5
BeiDou/GPS 4.5 4.5 11.7
5 结 论
我国的北斗卫星定位导航系统目前处于积极
建设中,通过本文的论述与测试分析,可得如下
结论:
(1)北斗卫星导航系统已经具备我国范围内
的初步三维高精度定位导航能力;
(2)由于整个北斗系统尚未布设完成,现有
卫星数量较少、几何分布较差,是造成单独北斗定
位精度整体偏低的主要原因;
(3)相同卫星条件下,北斗与GPS在高精度
相对定位方面处于同一精度级别,二者联合定位
可以明显增加可用卫星资源,改善卫星几何结构,
提高卫星定位精度。
(4)随着我国北斗系统的快速建设与不断完
善,北斗定位将更加精确有效。
致 谢:感谢宁津生院士一直以来对笔者的指导与
帮助,同时对宁院士的80华诞表示衷心的祝贺!
参考文献:
[1] YANG Yuanxi.Progress,Contribution and Challenges of
Compass/Beidou Satellite Navigation System [J].Acta
Geodaetica et Cartographica Sinica,2010,39(1):1-6.(杨
元喜.北斗卫星导航系统的进展、贡献与挑战[J].测绘学
报,2010,39(1):1-6.)
[2] CHEN Junyong,YANG Yuanxi,WANG Min,et al.
Establishment of 2000National Geodetic Control Network
of China and It’s Technological Progress[J]. Acta
Geodaetica et Cartographica Sinica,2007,36(1):1-8.(陈
俊勇,杨元喜,王敏,等.2000国家大地控制网的构建和它
的技术进步[J].测绘学报,2007,36(1):1-8.)
[3] CHENG Pengfei,WEN Hanjiang,CHENG Yingyan,et
al.Parameters of the CGCS2000Ellipsoid and Comparisons
with GRS80and WGS-84[J].Acta Geodaetica et Cartographica
 Sinica,2009,38(3):189-194.(程鹏飞,文汉江,
成英燕,等.2000国家大地坐标系椭球参数与GRS80和
WGS-84的比较[J].测绘学报,2009,38(3):189-194.)
[4] YU Zhongchou,YU Zhenglin.Principle of Surveying
Adjustment[M],Wuhan:Publishing House of Wuhan
University of Surveying and Mapping,1990.(於宗俦,于正
林.测量平差原理[M].武汉:武汉测绘科技大学出版
社,1990.)
[5] QIN Yongyuan,ZHANG Hongcheng,WANG Shuhua.
Principles of Kalman Filtering and Combination Navigation
[M].Xi’an:Northwestern Polytechnical University
Press.1998.(秦永元,张洪铖,汪叔华.卡尔曼滤波与组
合导航原理[M].西安:西北工业大学出版社.2007.)
(下转第755页)
748
第5期陶 珂,等:多指标融合的小波去噪最佳分解尺度选择方法
·Laser,2010,21(9):1408-1411.(杜文辽,朱茹敏,李
彦明.小波滤波分解层数的自适应确定方法[J].光电子
·激光,2010,21(9):1408-1411.)
[13] CAI Tie,ZHU Jie.Adaptive Selection of Optimal Decomposition
 Level in Threshold De-noising Algorithm Based
on Wavelet[J].Control and Decision,2006,21(2):217-
220.(蔡铁,朱杰.小波阈值降噪算法中最优分解层数的
自适应选择[J].控制与决策,2006,21(2):217-220.)
[14] WANG Wei,ZHANG Yingtang,REN Guoquan.Adaptive
Selection and Simulation of Optimal Decomposition Level
in Threshold De-noising Algorithm Based on Wavelet
Transform[J].Chinese Journal of Scientific Instrument,
2009,30(3):526-530.(王维,张英堂,任国全.小波阈
值降噪算法中最优分解层数的自适应确定及仿真[J].
仪器仪表学报,2009,30(3):526-530.)
[15] LI Wei,CHEN Xiaohui,MAO Haijie.A Study of Adaptive
Optimal Decomposition Level in Threshold De-noising
Algorithm Based on Wavelet Transform[J].Computer
Simulation,2009,26(3):311-313.(李炜,陈晓辉,毛海
杰.小波阈值消噪算法中自适应确定分解层数研究[J].
计算机仿真,2009,26(3):311-313.)
[16] LIU Bin,DAI Guiping.Adaptive Wavelet Thresholding
Denoising Algorithm Based on White Noise Detection and
3σRule[J].Journal of Transduction Technology,2005,
18(3):473-476.(刘彬,戴桂平.基于白化检验和3σ准
则的小波阈值去噪算法[J].传感器学报,2005,18(3):
473-476.)
[17] HALKIDI M,BATISTAKIS Y,VAZIRGIANNIS M.
On Clustering Validation Techniques[J].Journal of
Intelligent Information Systems, 2001, 17 (2-3):
107-145.
[18] YUAN Jie,SHI Haibo,LIU Chang.Construction of
Fuzzy Membership Functions Based on Least Squares
Fitting[J].Control and Decision,2008,23(11):1263-
1266.(袁杰,史海波,刘昶.基于最小二乘拟合的模糊
隶属函数构建方法[J].控制与决策,2008,23(11):
1263-1266.)
[19] LIU Qiliang,DENG Min,WANG Jiamu,et al.Spatio-
Temporal Outliers Detection within the Space-time
Framework[J].Journal of Remote Sensing,2011,15(3):
457-474.(刘启亮,邓敏,王佳璆,等.时空一体化框架下
的时空异常探测[J].遥感学报,2011,15(3):457-474.)
[20] TAO Ke,ZHU Jianjun.A Comparative Study of Validity
Assessment of Wavelet De-noising[J].Journal of Geodesy
and Geodynamics,2012,32(2):128-133.(陶珂,朱建
军.小波去噪质量评价方法的对比分析研究[J].大地测
量与地球动力学,2012,32(2):128-133.)
(责任编辑:宋启凡)
收稿日期:2012-05-18
修回日期:2012-08-10
第一作者简介:陶珂(1987—),女,硕士生,主要从事大地
测量数据处理方面研究。
First author:TAO Ke(1987—),female,postgraduate,
majors in surveying data processing.
E-mail:hncstaoke@
櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂櫂
126.com
(上接第748页)
[6] GAO Xingwei,LIU Jingnan,GE Maorong.An Ambiguity
Searching Method for Network RTK Baselines between
Base Stations at Single Epoch [J].Acta Geodaetica et
Cartographica Sinica,2002,31(4):305-309.(高星伟,刘
经南,葛茂荣.网络RTK基准站基线的单历元整周模糊度
确定方法[J].测绘学报,2002,31(4):305-309.)
[7] ZHU Huizhong,GAO Xingwei,XU Aigong,et al.Single
Epoch Ambiguity Resolution for Network RTK Rovers
[J].Science of Surveying and Mapping,2010,35(2):77-
79.(祝会忠,高星伟,徐爱功,等.网络RTK流动站整周模
糊度的单历元解算[J].测绘科学,2010,35(2):77-79.)
[8] ZHU Huizhong,GAO Xingwei,BI Jinzhong,et al.An
Algorithm of GPS Ambiguity Resolution on Single Epoch
[J].Science of Surveying and Mapping,2011,36(4):9-
11.(祝会忠,高星伟,秘金钟,等.一种GPS整周模糊度单
历元解算方法[J].测绘科学,2011,36(4):9-11.)
[9] TEUNISSEN P J G.The Least Squares Ambiguity Decorrelation
 Adjustment:A Method for Fast GPS Integer
Ambiguity Estimation[J].Journal of Geodesy,1995,70(1/
2):65-82.
(责任编辑:丛树平)
收稿日期:2012-04-20
修回日期:2012-07-19
第一作者简介:高星伟(1973—),男,博士,副研究员,研
究方向为多系统卫星定位网络RTK算法和相关软件。
First author:Gao Xingwei(1973—),male,PhD,associate
 research fellow,majors in algorithm research of GNSS
network RTK and their softwares development.
E-mail:gaoxw@casm.ac.cn
755】
基于时空系统统一的北斗与GPS融合定位.pdf (670.26 KB, 下载次数: 0)
GMT+8, 2026-3-19 05:49 , 耗时 0.130895 秒, 21 个查询请求 , Gzip 开启.
