查看: 2588|回复: 1
[待整理] 用打印机端口做可编程频率发生器电路
发表于 2014-10-5 10:54:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
用打印机端口做可编程频率发生器电路
#include<stdio.h>
#include<conio.h>
#include<math.h>
#include<bios.h>
#include<dos.h>
#define CLK1 0x04 /* Clock Pulse High*/
#define CLK0 0xfb /* Clock Pulse Low*/
#define CS1  0x01 /* Chip Select high to deactivate DAC*/
#define CS0 0xfe /* Chip Select low to activate DAC*/
#define DATA1 0x02 /* Data Pulse High*/
#define DATA0 0xfd /* Data Pulse low*/
int c[16],dport,ACTUALDATA,out,k;   /*Global Declarations*/
float VOUT;/*DAC OUTPUT*/
void d2b(unsigned int x, int*c)/*Routine for Decimal to Binary Conversion*/
int i;
for(i=0;i<=15;i++)
*(c++)=(x>>i) & 0x1;
float ftov()   /*Hertz to DAC output Conversion Routine*/
int HERTZ;
printf("
Enter the frequency  within 0 to 10000Hz:");
scanf("%d",&HERTZ);
VOUT=0.00040955*HERTZ;
printf("
VOUT=%f
",VOUT);
return VOUT;
void CLOCK_DAC(void)/*Routine for clocking the DAC*/
out|=CLK1;
outportb(dport,out);/*Setting the clock high*/
delay(1);
out&=CLK0;
outportb(dport,out);/*Setting the clock low*/
delay(1);
void LOAD_DACDATA(int*c)/*Routine for loading actual data into the DAC*/
out|=CS1;
outportb(dport,out);/*Chip Select high to disable DAC*/
delay(1);
out&=CS0;
outportb(dport,out);/*Chip Select low to enable DAC*/
delay(1);
printf("
DATA loaded into the DAC=");
for(k=15;k>=0;k--)
out|=c[k];
printf("%d",c[k]);
delay(1);
CLOCK_DAC();
out|=CS1;
delay(1);
main()
int v,inc;
float y;
unsigned  int x;
double fraction, integer, number;
clrscr();
printf("        Use Your Printer Port as a Programmable Frequency Generator");
printf("
                         by
printf("        K.Suresh,MSD,IGCAR,Kalpakkam,TamilNadu-603102,India");
dport= peek(0x40,8);/*Check up for availability of Printer Port*/
if (dport==0)
printf("
LPT NOT AVIAILABLE! EXITING........");
exit(1);
printf("
Address of the printer port found =0x%X",dport);
ftov();
y=(VOUT*8192)/(2.5*1.6384);
v=y/1;
number=y;
fraction = modf(number, &integer);
if (fraction<0.44)
inc=0;
else inc=1;
ACTUALDATA=16384+v+inc; /*Actual data including the Control Word for DAC*/
d2b(ACTUALDATA,c);
LOAD_DACDATA(c);
return 0;
GMT+8, 2026-4-15 10:14 , 耗时 0.428337 秒, 21 个查询请求 , Gzip 开启.
