查看: 1533|回复: 0
[待整理] 利用udev在/dev下动态生成/移除设备文件
发表于 2014-10-11 02:41:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用udev在/dev/下动态生成设备文件,这样用户就不用手工调用mknod了。
利用的kernel API:
class_create : 创建class
class_destroy : 销毁class
class_device_create : 创建device
class_device_destroy : 销毁device
注意,这些API是2.6.13开始有的,在2.6.13之前,应当使用
class_simple_create
class_simple_destroy
class_simple_device_add
class_simple_device_remove
这一系列,也就是ldd3第14章描述的。 详见:
https://lwn.net/Articles/128644/
Output:
[root@localhost dynamic_dev_node]# insmod ./dummy_dev.ko
[root@localhost dynamic_dev_node]# file /dev/dummy_dev0
/dev/dummy_dev0: character special (250/0)
[root@localhost dynamic_dev_node]# rmmod dummy_dev.ko
/dev/dummy_dev0: ERROR: cannot open `/dev/dummy_dev0' (No such file or directory)
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/mm.h>
#include <linux/fs.h>
#include <linux/types.h>
#include <linux/delay.h>
#include <linux/moduleparam.h>
#include <linux/slab.h>
#include <linux/errno.h>
#include <linux/ioctl.h>
#include <linux/cdev.h>
#include <linux/string.h>
#include <linux/list.h>
#include <linux/pci.h>
#include <asm/uaccess.h>
#include <asm/atomic.h>
#include <asm/unistd.h>
#define THIS_DESCRIPTION "
This module is a dummy device driver, it registern
tta char device, and utilize udev to create/destroy n
ttdevice node under /dev/ dynamicallly."
MODULE_LICENSE("GPL");
MODULE_AUTHOR("albcamus <albcamus@gmail.com>");
MODULE_DESCRIPTION(THIS_DESCRIPTION);
#define DUMMY_MAJOR 250
#define DUMMY_MINOR 0
#define DUMMY_NAME "dummy_dev"
* the open routine of 'dummy_dev'
static int dummy_open(struct inode *inode, struct file *file)
printk("Open OKn");
return 0;
* the write routine of 'dummy_dev'
static ssize_t dummy_write(struct file *filp, const char *bp, size_t count, loff_t *ppos)
printk("Don't Write!n");
return 0;
* the read routine of 'dummy_dev'
static ssize_t dummy_read(struct file *filp, char *bp, size_t count, loff_t *ppos)
return 0;
* the ioctl routine of 'dummy_dev'
static int dummy_ioctl(struct inode *inode, struct file *filep,
unsigned int cmd, unsigned long arg)
return 0;
* file_operations of 'dummy_dev'
static struct file_operations dummy_dev_ops = {
.owner = THIS_MODULE,
.open = dummy_open,
.read = dummy_read,
.write = dummy_write,
.ioctl = dummy_ioctl,
* struct cdev of 'dummy_dev'
struct cdev *my_cdev;
struct class *my_class;
static int __init my_init(void)
int err, devno = MKDEV(DUMMY_MAJOR, DUMMY_MINOR);
/* register the 'dummy_dev' char device */
my_cdev = cdev_alloc();
cdev_init(my_cdev, &dummy_dev_ops);
my_cdev->owner = THIS_MODULE;
err = cdev_add(my_cdev, devno, 1);
if (err != 0)
printk("dummy pci device register failed!n");
/* creating your own class */
my_class = class_create(THIS_MODULE, "dummy_class");
if(IS_ERR(my_class)) {
printk("Err: failed in creating class.n");
return -1;
/* register your own device in sysfs, and this will cause udevd to create corresponding device node */
class_device_create(my_class, NULL, MKDEV(DUMMY_MAJOR, DUMMY_MINOR), NULL, DUMMY_NAME "%d", DUMMY_MINOR );
return 0;
static void __exit my_fini(void)
printk("byen");
cdev_del(my_cdev);
//kfree(my_cdev); no use. because that cdev_del() will call kfree if neccessary.
class_device_destroy(my_class, MKDEV(DUMMY_MAJOR, DUMMY_MINOR));
class_destroy(my_class);
module_init(my_init);
module_exit(my_fini);
GMT+8, 2026-4-9 07:27 , 耗时 0.375872 秒, 18 个查询请求 , Gzip 开启.
