查看: 1505|回复: 0
[待整理] CAT6500自动电源选择开关简述
发表于 2014-10-11 07:57:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
        简述
        CAT6500 is an automatic power switch designed to select between two power sources and direct that power to a load for battery charging or system power.
        CAT6500’s power inputs withstand voltages of up to 18V and protect the downstream load from voltages exceeding7V. In the event of a polarity reversal at either input CAT6500’s internal power switches will shut off to prevent discharge of the system’s internal power source.
        Low resistance power switches handle currents in excess of 3 A and when OFF block current flow in both directions. CAT6500 can operate in reverse mode in which internal system power is be directed to either of the power input ports for powering an external device, such as a USB On−The−Go appliance.
        特性
  •                 Autonomous Switching between 2 Power Sources
  •                 Withstands +18 V to −5 V on Either Power Input
  •                 80 m_ Switches (typ.) for Low Power Loss
  •                 Reverse−Mode for Powering External Devices
  •                 Over Voltage Protection of Downstream Load
  •                 Compatible with USB−OTG Devices
  •                 2−Lead WQFN 4.4 mm x 4.4 mm Package
  •                 This Device is Pb−Free, Halogen Free/BFR Free and is RoHS Compliant
        典型应用
  •                 Mobile Phones
  •                 PDAs
  •                 Personal Navigation Devices
        Figure 1. Typical Application Circuit
        涵盖了CAT6500的技术方案和CAT6500的应用笔记以及CAT6500的电路图,为工程师学习CAT6500提供了一站式学习环境。
GMT+8, 2026-4-9 17:41 , 耗时 0.134593 秒, 22 个查询请求 , Gzip 开启.
