查看: 1990|回复: 0
[待整理] 射频电缆计算公式一览表
发表于 2014-10-11 17:27:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
<div class="mb_content" id="content_box">                        Impedance (ohms)
                        Velocity of Propagation and Dielectric Constant
                        Time Delay (nS/foot)
                        Capacitance (pF/foot)
                        Inductance (uH/foot)
                        Attenuation (dB/foot)
                        Braid Factor
                        Cutoff Frequency (GHz)
                        Electrical Length (degrees)
                        Phase Temperature Coefficient (ppm/Co)
                        Phase Stability (degrees)
                        Return Loss (dB)
                        VSWR
                        Reflection Coefficient
                        Match Efficiency (%)
GMT+8, 2026-4-16 06:22 , 耗时 0.322107 秒, 22 个查询请求 , Gzip 开启.
