查看: 1302|回复: 0
[待整理] 行业的代表-MG3641A 合成信号发生器
发表于 2014-10-12 13:46:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
            MG3641A 合成信号发生器
最近更新日期:2006-10-03
厂商名称:                        Anritsu
商品名称:合成信号发生器
商品型号:MG3641A
简单信息:
特点
    125千赫至1040/2080兆赫:经济而高性能的信号源新的Anritsu合成器技术允许在整个频率量程范围内把频率设置在0.01赫兹的分辨率上。在任何频率上可靠测量所产生的一种独特的低噪音钇铁石榴石(YIG)振荡器产生单边带相噪音好于-130分贝/赫兹(1千兆赫,20千赫偏差)的高纯度信号,使这些信号发生器可用于无线电接收机的干涉测试和不同的本地信号源和参照信号 。
性能:
·0.01赫兹,0.01分贝的分辨率
·高信号纯度(-100dBc乱真信号)
·多样化的调节功能
技术指标
Carrier frequencyRange:125kHz to 1040MHz
            Resolution:0.01Hz
            Accuracy:Reference oscillator accuracy;reference oscillator accuracy±(0.3%ofFM setting deviatin+5Hz)at frequency modulation
            Internal reference oscillator*^1
            Frequency:10MHz ,Aging rate:±5*10^-9/day,Start-up characteristics:1*10^-7/10min(for 24 h after power on )
            Temperature stability:±3*10^-8(0° to 50℃)
            External reference input:5/10 MHz,±10ppm,≥0.7Vp-p/50Ω(AC coupling) ,BNCconnector(rear panel)
            Buffer output:10MHz TTL level(DC coupling )BNC connector(rear panel)
            Switching timw:<40ms (external control mresponse time fron lase commanduntil becomes within±0.01ppm of set frequency)
OutputRange:-143 to +17dBm (settable range:-143 to +23dBm)
            Units:dBm,dB&mu;,V,mV,&mu;V,(dB&mu;,V,mV and &mu;V switchablebetween terminationvoltage display and open voltage display)
            Resolution:0.01dB
            Frequency characteristics(at 0dBm):±1.0dB(pulse modulation:on(*^2
            Impedance:50&Omega;(N connector )VSWR :<1.5(&le;-3dBm),<2.5(>-3dBm)
            Switching time :<50ms(normal mode)<100ms (level safetymod)<10 ms(continuous mode)
            *Response time from last command until becomes within±0.5dB of final level
            Special setting mode
            Continuous mode:Variable within set value±10dB with no interruption of output
            Safety mode:Preent large spike signal grneration when operationg emchanical-typeattenuator
            Interference frdiator:<0.1&mu;V(at ouptput frequency),<1&mu;V(over entirefrequency range mmultl-menu display:OFF)
            *At point 25mm from cabinet measured with 25 mm diameter loop antenna (2windings)terminated at 50&Omega;
Signal puritySpurious(CW mode,&le;+7dBm)
            HarmonicsL<-30dBc(2nd,3rd)
            Non-harmonic:<-100dBc (&ge;15kHz offset)
            Those related power:<-40dBc(<15kHz offset)
            SSB phase noise(CW Mode,20kHz offset):
            <-140dBc/Hz(10 to 256MHz),<-136dBc/Hz(256 to 512MHz),<130dBc/Hz(512to 1040MHz)
            <-124dBc/Hz (>1040MHz,MG3642A only)
            Residual AM:<-80 dBc (&ge;500kHz ,CW mode,+7dBm,50Hz to 15kHz demodulationband)
            Residual FM(CW mode)
            300Hz to 3 kHz demodulation band:<4Hzrms(10 to <512MHz),<8Hzrms(512to 1040MHz,MG3642A only)
            50Hz to 15kHz demodulation band:<5Hzrms(10 to <512MHz),<8Hzrms(512to 1040MHz,MG3642A only)
Amplitude
            modulation
Range:0% to 100%
            Resolution:0.01%
            Accuracy:±(5% of set value+2%)*&ge;0.4MHz ,&le;+7dBm,&le;90%AM,source:lnt 1(1kHz),300Hzto 3kHz demodulation band
            Modulation frequency response(output:&le;±+7dBm)
Carrier frequency
Upper limit frequencyLower limit frequency
AM:30%AM:90%
0.4 to <0.5MHz2kHz(±1dB bandwidth)1kHz(±1dB bandwidth)DC External DC coupling(±1dB bandwidth)
                        20Hz:External AC coupling(±1 dB bandwith)
0.5 to <2MHz10kHz(±1dB bandwidth)5kHz(±1dB bandwidth)
2 to <32MHz20kHz(±1dB bandwidth)
32 to <64MHz50kHz(±1dB bandwidth)
&ge;64MHz50kHz(±1dB bandwidth),100kHz(±1dB bandwidth)
            Distortion:<-40dB (30% AM),<-30dB(90%AM)*&ge;0.4MHz,&le;+7dBm,source:lnt1(1kHz)
            Incidental FM:<200 Hz peak*&ge;0.4MHz &le;+7dBm source:lint 1 (1kHz)300Hzto 3kHz demodulation band
            Modulation signal source:One of internal (lint 1,lnt 2,lnt 3)and external(Ext 1, Ext 2)
            Modulation signal Positive/negative switchable
Frequency
            modulation
Range:
0 to 125Hz (125 to <250kHz)0 to 25.6kHz(16 to <32MHz)
0 to 250Hz(250 to <500kHz)0 to 51.2kHz(32 to <64MHz)
0 to 500Hz(0.5 to <1MHz)0 to 102kHz(64 to <128MHz)
0 to 1kHz(1 to< 2MHz)0 to 256kHz(128 to <256MHz)
0 to 2kHz (2 to< 4MHz)0 to 512kHz(256 to 512MHz)
0 to 4kHz(4 to< 8MHz)0 to 1024kHz(512 to 1040MHz)
0 to 10kHz(8 to <16MHz)0 to 2048kHz(>1040MHz,MG3642A only)
            Resolution:
1Hz(0 to 4kHz deviation)250 Hz(102.25 to 256kHz deviation)
10Hz(4.01 to 10kHz deviation)500 Hz(256.5 to 512 kHz deviation)
25Hz(10.025 to 25.6kHz deviation)1kHz (513 to 1024kHz deviation)
50Hz(25.65 to 51.2kHz deviation)1kHz(1025 to 2048kHz deviation,NG3642A only)
100Hz(51.3 to 102kHz deviation)
            Accuracy:±(5% of set value+10Hz)(0.4 to <512MHz),±(5% of set value+20Hz)(512to 1040MHz)
            ±(5% of set value+40 Hz)(>1040MHz,MG3642A only)
            *Source:lnt 1(1kHz),300 Hz to 3kHz demodulation band
            Modulation frequency response:DC or 20 Hz*^3 to 20kHz(0.4 to <10MHz)DCor 20Hz*^3 to 100kHz(&ge;10MHz)*±1dB bandwidth
            Distortion:<-40dB*&ge;16MHz,3.5kHz deviation,source:lnt 1(1kHz)
            <-45dB*&ge;16MHz,3.5kHz deviation,source:lnt 1(1kHz)
            Incidental FM:<1% peak*&ge;64MHz,&le;+7dBm,100kHz deviation,source:;lnt 1(1kHz),300Hzto 3kHz demodulation band
            External modulation grop delay:<30&mu;s*&ge;10MHz,source:external DC couplingmodemmodulation rate:&le;100kHz
            Modulation signal source(FM1,FM2):One of internal (lnt 1,lnt 2,lnt 3),andexternal (Ex 1 ,Ext 2)
            Modulation signal polarity:FM 1, FM 2 positive/negative switchable
Pulse modulationAccrding to option specifications
Modulation signal sourceInternal modulation(lnt 1)
            Frequency:400Hz ,1 kHz
            Accuracy:Same as reference oscillator accuracy
            Internal modulation (lnt 2,lnt 3):According to option specifications
            External modulation(Ext 1,Ext 2)
            Proper input level:2 Vp-p approx
            Input impedance:600&Omega;,BNC connector
            Coupling :DC/AC switchable
AF outputOutput signal source:One of internal (lnt 1,lnt 2,lnt3),and external(Ext 1,Ext 2)
            Output level:0 to 4Vp-p
            Output level resolution:1m Vp-p
            Output level accuracy:±(5% of setting level+2mVp-p)*Source:lnt 1 (1kHz)
            Impedance:600&Omega;,BNC connector
Simultaneous
            modulation
Excluking amplitued modulation and pulse modulation*^2combination,simultaneous modulation,modulation rate,edviation independently
Sweep functionSweep parameters:Frequency,output level,memory
            Sweep patterns
            Frequency sweep(start/stop):Linear(specified step ieze and number of pointsf)Log(multiplyingfactor:1%)
            Frequency sweep (center/span):Linear(specified step size and number of points)
            Level sweep(start/stop,center/span):dB(specified step size and number ofpoints)* Sweep :continuous mode(max.20 dB width)
            Memory mode:Auto ,single,manual
            Sweep time
            Setting range:1ms to 600s/point:0 V sweep end point:+10V),BNC connector(rearpanel)
            Resolution:10 &mu;s)/point
            Auxiliary output
            X-Out:Ramp waveform(sweep start point:0 V,sweep end point:+10V),BNC connector(rearpanel)
            Z-Out:TTL level(H-level at switching),BNC connector(rear panel)
            Blanking-Out:TTL level(H-level at switching),BNC connector(rear panel)
            Maker-Out:TTL level(H-level at switching),BNC connector(rear panel)
FunctionsRelative display:Carrier frequency,output level
            Offset display:Carrier frequency,output level
            Memory:Saves/recalls 1000 panel settings,recall contents:panel,frequency,frequency/outputlevel selection
            Trigger:An external trigger signal(rear panel BNC connector TTL level)canbe used to execute a previously programmed operation sequence (secept
            power switch,preset key,local key and ratary knob operations),Max.numberof sequence steps of trigger program:20 steps
            Back-up:The panel settings before power-off are back-upped and displayedagain at power-on,except data-input contents,GPIB data contents remote settings,RPPoperations
            GPIB control:All functions,except power switch,local key,rotary knobs andresolutioh keys(Interface:SH1,AH1,T5,L3,TE0,SR1 RL1,PP0,DC1,DT1,
            C0,E2)
Reverse power protectionMax.reverse input power:&le;50W(&le;1040MHz),&le;25W(>1040MHz,MG3642Aonly)±50Vdc
Power suply*4Vac(+10%,-15%),47.5 to 63/380 to 420Hz &le;200VA
TemperatureOperating:0 °to 50℃ Storage:-30 °to +71℃
Dimensions and mass320(W)*177(H)*451(D)mm,&le;20kg
EMCEN55011:1991 ,Group 1, Class A
            EN50082-1:1992
            Harmonic current emissions:EN61000-3-2(1995)
SafetyEN61010-1:1993(Installation Category II ,Pollution DegreeII)
订货信息
Model /Order No.Name
Main frame
MG3641ASynthesized Signal Generator
Standard accessories
J0017FPower cored ,2.5m:1pc
B0325GPIB connector shiedlded cap:1pc
F0013Fuse,5A (for 200Vac mains):2pcs
F0012Fuse,3.15 A (for 200Vac mains):2pcs
W1137AEMG3641A/3642A operation manual1copy
W1137BEMG3641A/3642A service manual:1copy
Options
MG3641[]A-01Reference oscillator (aging rate:5*10^-10/day)
MG3641[]A-11Pulse modulatior(pulse repetition rate:DCto 1 MHz )
MG3641[]A-21AF synthesizer(0.01 Hz to 400kHz ,resolution:0.01Hz)
MG3641[]A-22FSK encoder(2 or 4 levels FSK)
MG3641[]A-23Pattern generator
Application software
MX364001B*^1Software foe Pattern Generator Data Write(Microsoft@ Windows 95)
Optioonal accessories
J0576BCoaxial cord(N-P·5D-2W·N-P),1m
J0127BCoaxial cord(BNC-P·RG58A/U·BNC-P),1m
J0007GPIB cable,1m,
J0008GPIB cable,2m
MP51APad
MP52APad
MA1612AFour-Point Juntion Pad
MP721[]Atenuator(DC to 12.4GHz)
B0395CRack mount kit(EIA/IEC)
B0329GFront cover(3/4MW 4U)
B0412ACarrying case(with casters and B0329G frontcover)
B0330BTit bail (3/4MW 450D)
GMT+8, 2026-4-26 09:43 , 耗时 0.314328 秒, 18 个查询请求 , Gzip 开启.
