查看: 1431|回复: 0
[待整理] 步进电机定位控制系统的VHDL程序设计
发表于 2014-10-12 16:52:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
步进电机定位控制系统VHDL程序与仿真
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity step_motor is
port (reset:in STD_LOGIC; --系统复位信号
dir: in STD_LOGIC; --方向控制信号
clk: in STD_LOGIC; --系统时钟信号
ini: in STD_LOGIC; --初始化使能信号
manner: in STD_LOGIC_VECTOR (1 downto 0); --激磁方式的选择开关
angle: in INTEGER range 255 downto 0; --步进角的倍数设定输入
baBA: out STD_LOGIC_VECTOR (3 downto 0)); --步进电机状态输出
end step_motor;
architecture stepmotor_arch of step_motor is
signal count: INTEGER range 0 to 7; --计数器
signal cntInc: INTEGER range -2 to 2; --设定累加器所需的累(加/减)计数值
signal cc : integer range 0 to 3;
signal cntIni: INTEGER range -1 to 0; --设定累加器所需的计数初值
signal angleDnCount: INTEGER range 255 downto 0;  --计算已经转过的步进角
signal angleDnCntDec: INTEGER range 2 downto 1;
begin
process(dir, manner, angle)--, ini)
begin
--if ini='1' then
cc<=conv_integer(manner);
if dir='0' then
case cc is
when 1 => -- 1-?相激励
--count<=0;
cntIni<=0;
cntInc<=2;
angleDnCntDec<=2;--"10";
when 2 => -- 2-?相激励
--count<=7;
cntIni<=-1;
cntInc<=2;
when 3 => -- 1-2?相激励
--count<=0;
cntIni<=0;
cntInc<=1;
angleDnCntDec<=1;--"01";
when 0 => --manner="00" autodetect
if (angle rem 2) =1 then -- 2-?相激励
--count<=7;
cntIni<=-1;
cntInc<=2;
else -- 1-?相激励
--count<=0;
cntIni<=0;
cntInc<=2;
end if; --angle
end case; --manner
else -- if dir='1'
case cc is
when 1 => -- 1-?相激励
--count<=0;
cntIni<=0;
cntInc<=-2;
when 2 => -- 2-?相激励
--count<=7;
cntIni<=-1;
cntInc<=-2;
--count<=0;
cntIni<=0;
cntInc<=-1;
if (angle rem 2) = 1 then -- 2-?相激励
cntIni<=-1;
cntInc<=-2;
else -- 1-?相激励
cntIni<=0;
cntInc<=-2;
end if; --angle
end case; --manner
end if; -- else dir=0
--end if; -- ini
end process;
counting_reset: process(reset,ini, angle, clk)
begin
if reset='1' then
count<=0;
angleDnCount<=0;
elsif clk'event and clk='1' then
if ini='0' then
count<=0+cntIni;
angleDnCount<=angle;
else
count <= count+cntInc;
if angleDnCount > angleDnCntDec then
angleDnCount <= angleDnCount-angleDnCntDec;
else
angleDnCount <= 0;
end if;
end if;
end if;
end process;
baBA <="0000" when angleDnCount=0 else
"0001" when count=0 else
"0011" when count=1 else
"0010" when count=2 else
"0110" when count=3 else
"0100" when count=4 else
"1100" when count=5 else
"1000" when count=6 else
"1001";-- when count>=7;
end stepmotor_arch;
GMT+8, 2026-4-22 12:27 , 耗时 0.255673 秒, 19 个查询请求 , Gzip 开启.
