查看: 1598|回复: 0
[待整理] Altera StratixIV 100G开发方案介绍
Altera公司的Stratix IV 40nm FPGA包括Stratix IV E, Stratix IV GX和Stratix IV GT三个系列, 具有最高的密度(680K 逻辑单元(LE),22.4 Mbits 嵌入式存储器和1,360个18 x 18 乘法器),最佳的性能以及最低的功耗, 系统带宽(8.5 Gbps的48 个高速收发器,以及 1,067 Mbps (533 MHz) DDR3存储器接口)达到了前所未有的水平,并具有优异的信号完整性, 非常适合无线通信,固网,军事,广播等其他最终市场中的高端数字应用。本文介绍了Stratix? IV FPGA主要特性, Stratix IV GT器件框图,以及采用EP4S100G5F45I1 Stratix IV GT FPGA器件的Stratix IV GT 100G开发板主要特性,方框图,详细电路图和材料清单.
Altera? Stratix? IV FPGAs deliver a breakthrough level of system bandwidth and power efficiency for high-end applications, allowing you to innovate without compromise. Stratix IV FPGAs are based on the Taiwan Semiconductor Manufacturing Company (TSMC) 40-nm process technology and surpass all other high-end FPGAs, with the highest logic density, most transceivers, and lowest power requirements.
The Stratix IV device family contains three optimized variants to meet different application requirements:
■ Stratix IV E (Enhanced) FPGAs—up to 813,050 logic elements (LEs), 33,294 kilobits
(Kb) RAM, and 1,288 18 x 18 bit multipliers
■ Stratix IV GX transceiver FPGAs—up to 531,200 LEs, 27,376 Kb RAM, 1,288 18 x 18-bit multipliers, and 48 full-duplex clock data recovery (CDR)-based transceivers at up to 8.5 Gbps
■ Stratix IV GT—up to 531,200 LEs, 27,376 Kb RAM, 1,288 18 x 18-bit multipliers, and 48 full-duplex CDR-based transceivers at up to 11.3 Gbps
Stratix? IV FPGA主要特性:
The following list summarizes the Stratix IV device family features:
■ Up to 48 full-duplex CDR-based transceivers in Stratix IV GX and GT devices supporting data rates up to 8.5 Gbps and 11.3 Gbps, respectively
■ Dedicated circuitry to support physical layer functionality for popular serial protocols, such as PCI Express (PCIe) (PIPE) Gen1 and Gen2, Gbps Ethernet (GbE), Serial RapidIO, SONET/SDH, XAUI/HiGig, (OIF) CEI-6G, SD/HD/3G-SDI, Fibre Channel, SFI-5, and Interlaken
■ Complete PCIe protocol solution with embedded PCIe hard IP blocks that implement PHY-MAC layer, Data Link layer, and Transaction layer functionality
■ Programmable transmitter pre-emphasis and receiver equalization circuitry to compensate for frequency-dependent losses in the physical medium
■ Typical physical medium attachment (PMA) power consumption of 100 mW at 3.125 Gbps and 135 mW at 6.375 Gbps per channel
■ 72,600 to 813,050 equivalent LEs per device
■ 7,370 to 33,294 Kb of enhanced TriMatrix memory consisting of three RAM block sizes to implement true dual-port memory and FIFO buffers
■ High-speed digital signal processing (DSP) blocks configurable as 9 x 9-bit, 12 x 12-bit, 18 x 18-bit, and 36 x 36-bit full-precision multipliers at up to 600 MHz
■ Up to 16 global clocks (GCLK), 88 regional clocks (RCLK), and 132 periphery clocks (PCLK) per device
■ Programmable power technology that minimizes power while maximizing device performance
■ Up to 1,120 user I/O pins arranged in 24 modular I/O banks that support a wide range of single-ended and differential I/O standards
■ Support for high-speed external memory interfaces including DDR, DDR2, DDR3 SDRAM, RLDRAM II, QDR II, and QDR II+ SRAM on up to 24 modular I/O banks
■ High-speed LVDS I/O support with serializer/deserializer (SERDES), dynamic phase alignment (DPA), and soft-CDR circuitry at data rates up to 1.6 Gbps
■ Support for source-synchronous bus standards, including SGMII, GbE, SPI-4 Phase 2 (POS-PHY Level 4), SFI-4.1, XSBI, UTOPIA IV, NPSI, and CSIX-L1
■ Pinouts for Stratix IV E devices designed to allow migration of designs from Stratix III to Stratix IV E with minimal PCB impact
Stratix IV GT Devices
Stratix IV GT devices provide up to 48 CDR-based transceiver channels per device:
■ Thirty-two out of the 48 transceiver channels have dedicated PCS and PMA circuitry and support data rates between 600 Mbps and 11.3 Gbps
■ The remaining 16 transceiver channels have dedicated PMA-only circuitry and support data rates between 600 Mbps and 6.5 Gbps
图1. Stratix IV GT器件框图
Stratix IV GT器件主要特性:
Stratix IV GT 器件EP4S100G5F45I1主要特性:
The Stratix IV GT 100G development board provides a hardware platform for evaluating the performance and signal integrity features of the Altera? Stratix IV GT devices.
Altera的Stratix? IV GT版100G开发套件支持您对100GbE设计进行全面评估:
通过光模块,支持10G/40G和100G线路接口。
通过4x18 ADRII和4x32 DDR3存储器块,支持需要外部存储器接口的应用。
通过两对FCI AirMax连接器,使用系统侧接口。
全面的线路侧(光模块)至系统侧(AirMax连接器)数据通路分析。
评估性能高达11.3 Gbps的收发器。
验证兼容10G/40G/100G以太网、Interlaken、CEI-6G/11G、PCI Express (Gen1, Gen2和Gen3)、Serial RapidIO?以及其他主要标准的物理介质附加(PMA)子层。
验证SFP、SFP+、QSFP和CFP等光模块之间的互操作性。
Stratix IV GT版100G开发套件包括:
Stratix IV GT开发板(参见图1)
安装的器件:EP4S100G5F45I1N
EPM2210F324C3N,MAX? II 256引脚CPLD
配置状态和设置单元
快速被动并行(FPP)配置
嵌入式USB-BlasterTM下载电缆
时钟
板上可编程时钟振荡器
SMA连接器,为收发器参考时钟提供外部差分时钟。
通用用户输入/输出
DIP和按键式开关
LED
LCD
存储器件
1-Gb同步闪存(主要用于存储两个FPGA配置——工厂和用户配置)
板上存储器
4个2-Gb DDR3 SDRAM
4个72-Mb QDR II SRAM
元件和接口
10/100/1000以太网PHY和RJ-45插头
36个收发器通道
1个SFP+接口通道
1个具有EDC的SFP+接口通道
4个QSFP接口通道
10个CFP接口通道
20个Interlaken接口通道
温度测量电路
管芯温度
环境温度
电源
14-V至20-V直流输入
2.5-mm筒形插座,用于直流电源输入。
On/off电源滑动开关
板上电源测量电路
Quartus II软件许可并没有含在这一套件中
You can use this development kit to:
• Develop and test designs to interface with a variety of different optical modules.
• Develop and test Interlaken designs.
• Develop and test memory subsystems consisting of DDR3 or QDR II memory.
• Build designs capable of migrating to Altera’s HardCopy IV ASICs.
图2.Stratix IV GT 100G开发板方框图
图3.Stratix IV GT 100G开发板外形图
GMT+8, 2026-4-22 12:27 , 耗时 0.255618 秒, 22 个查询请求 , Gzip 开启.
