查看: 1843|回复: 0
[待整理] 基于S3C44BOX的嵌入式磨削数控系统
发表于 2014-10-12 18:57:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Abstract: This paper presents an embedded numerical control system of grinder,including its design of hardware and software. The controller is S3C44BOX, the operating system is uC/OS-II, the machining-information is transferred by USB flash disk, the motor is controlled by PWM mode, the system information is displayed by LCD displayer in the proposed system. It has many advantages such as higher control accuracy, lower cost, smaller volume etc., and meanwhile it is extended and upgraded easily . It befits the reconstruction for traditional machine tool, and also befits the development for economical numerical control system.
Keyword:numerical control system of grinder,embedded system,S3C44BOX Micro Processor Unit,uC/OS-II operating system,controlled by PWM mode
        本文阐述了一个嵌入式磨削数控系统,包括系统硬件设计和软件设计。该系统以S3C44BOX为控制器,以uC/OS-II为操作系统,以U盘进行加工信息的离线传输,以PWM方式进行电机控制,以LCD显示器进行显示,具有控制精度高,成本低,体积小,易于扩展和升级等特点,是传统机床的数控化改造和经济型数控机床开发的发展趋势。
关键字:数控磨床;嵌入式系统;S3C44BOX微处理器;uC/OS-II操作系统;PWM控制
点击此处下载
GMT+8, 2026-4-20 17:59 , 耗时 0.153709 秒, 22 个查询请求 , Gzip 开启.
