查看: 1538|回复: 0
[待整理] 恩智浦MP4/PMP解决方案
发表于 2014-10-13 08:55:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
摘要:恩智浦(NXP) Nexperia个人媒体播放器(PMP)参考设计包括有高质量的数字音频和视频处理,有线和无线连接,它的极好的图像质量给制造商提供了灵活的平台,用来开发手提媒体播放器和录像设备.参考设计采用单个Nexperia PNX1500媒体处理器来译码和编码大多数受欢迎的媒体格式,包括DivX video, MPEG-2, MPEG-4, AVC/H.264,Windows Media 9,MP3, AAC, JPEG等。并无缝连接到LCD显示器(内含),硬盘驱动器和便携式闪存卡,进一步降低了BOM成本以支持众多的特色和格式。
方案特点:
The reference design’s compact size and light weight enable highly portable, ergonomic designs. Manufacturers can tailor storage, display, and media processing functionality to differentiate a variety of appealing player and recorder products enabling consumers to:
download high-quality music, movies, and photos from a PC, the Internet, home entertainment appliances, or other portables record high-quality audio, video, or TV
view/listen to hours of stored media anywhere
view photos or video from cameras or portable Flash storage devices
use the player as a wireless media adapter to enjoy PC and Internet media content in the living room
The reference design is based on a Nexperia PNX1500 media processor. The PNX1500 leverages a powerful C/C++ programmable TriMedia TM3260 CPU and runs a small real-time operating system
enabling efficient and predictable response to real-time events.
Independent, on-chip, I/O and coprocessing units capture and format datastream I/O and accelerate multimedia algorithms. A sophisticated memory hierarchy manages internal I/O and streamlines access to external memory.The PNX1500 also supports dynamic power management, lowering power consumption and conserving battery charge.
软件及开发工具:
Available separately from Philips, the Nexperia Development Kit (NDK) gives developers a full suite of system software tools to develop applications for the PNX1500’s TriMedia CPU. It includes a compiler, debugger, audio/video drivers, and example software. This comprehensive software development environment dramatically lowers cost and reduces time-to-market by enabling development of multimedia applications entirely in the C and C++ programming languages.
Application libraries for the PNX1500 are available from Philips and third parties; for a complete, up-to-date list visit:
主要特性:
Complete kit includes low-BoM reference board based on Nexperia PNX1500 media processor, 802.11a/g type IIIB MiniPCI card, LCD display, and software
Supports record and playback of most standard digital media formats including DivX? video, MPEG-2, MPEG-4,AVC/H.264,Windows Media 9, MP3, AAC, JPEG and more
Robust image enhancement features, motion-adaptive deinterlacing, and high-quality upscaling
Support for hard disk, CompactFlash?, Memory StickTM, and SD cards; expansion to other formats
Connectivity to PCs, home entertainment appliances, and portables
On-board Hi-Speed USB and Hi-Speed USB On-the-Go
Industry-leading, high-performance 802.11a/g
Expansion for Bluetooth? or RS232
Includes 3.5-inch QVGA TFT LCD display
Can output up to HD video for external big screen display
Advanced Philips PMU+ power management unit IC play stored music or full-resolution movies by connecting the player to a home theatre display or speakers
stream live TV or watch recorded TV or Internet content throughout the house
browse online multimedia content from the backyard or in any Wi-Fi hotspot
read electronic books
参考设计:
硬件(Hardware )PNX1511-based reference board; 802.11a/g type IIIB MiniPCI card (based on Philips high-performance 802.11a/g chipset: SA5250 baseband/MAC and SA5251 RF transceiver)
显示器(Display) 3.5-inch, switchable QVGA (320 x 240) included;
other displays such as 7-inch WVGA 800x480 are supported through a daughterboard
软件(Software) LCD drivers, audio/video drivers, HDD file system, demo applications
文件(Documentation): User Guide, schematics, Gerber files
参考设计板:
Media processor Nexperia PNX1511,TriMedia CPU
Memory 64 MB DDR SDRAM (2x32); 8 MB NAND Flash
PCI/XIO bus 32-bit, 33-MHz
Hard disk 1.8-in, 30-GB HDD with glueless IDE interface
Portable Flash Memory Stick, SD card, and CompactFlash; other formats via expansion bus
TV codec Philips SAA7109A; encodes up to 800 x 600 resolution PAL or NTSC; decodes PAL, NTSC, SECAM
Audio codec Philips UDA1380 stereo codec
Connectivity Philips ISP1583 Hi-Speed USB peripheral controller with direct interface to ATA/ATAPI; Philips ISP1761 Hi-Speed USB OTG host/peripheral controller (mini AB connector) miniPCI slot for 802.11 a/g card, SPI header for lowpower 802.11 b and b/g card Fast UART header for Bluetooth card Infrared receiver and blaster
Audio input mini-jack line in, microphone output mini-jack line out with inline 1W TDA8552 amp (to stereo speakers), headphone out, SPDIF out
Video I/O input CVBS/S-Video output CVBS/S-Video, component video (YPrPb interlaced and progressive or RGB/DVI up toWXGA)
Power power management unit Philips PCF50606 PMU+
supply voltage 3.3 V I/O
battery 3.7 V 3600-mAh Varta PolyFlex
DC/DC converter Philips TEA1211
Display I/O 18- or 24-bit, RGB LCD interface
User interface 8-bit microcontroller for keyboard/keypad
Security Philips P5CT072 with SmartMX technology enabling digital rights management
Supported media fomats1
Video decode MPEG-1, MPEG-2, MPEG-4 (SP,ASP), DivX-3/4/5, DV, H.263,AVC/H.264,WMV9
Video encode MPEG-1, MPEG-2, MPEG-4 (SP), DivX video, H.263, AVC/H.264
Audio decode MP2, MP3, DTS, Dolby Digital?, Dolby Pro Logic? II, AAC,WMA9, G.7xx
Audio encode MPEG-1 L2, MP3,AAC, G.7xx
Image decode JPEG, JPEG2000, GIF, BMP
Communications TCP/IP, V.90, Ethernet, 802.11x, Universal PnP, HTTP, RTP/RTCP/RTSP
下图为参考板方框图:
下图为PMP报PCB外形图:
GMT+8, 2026-4-13 09:18 , 耗时 0.284199 秒, 22 个查询请求 , Gzip 开启.
