查看: 1682|回复: 0
[待整理] 英飞凌LIN网络解决方案
发表于 2014-10-13 09:05:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
LIN, which stands for local interconnect network, is an inexpensive, low-speed (1 to 20 kilobits per second) Class-A, serial multiplexing protocol. It was designed to link switches, actuators and sensors into a sub-bus that connects to the main bus, usually a CAN bus. Vehicle assembly units that could benefit from a LIN sub-bus are door, roof, steering column, seat, climate control, switch panel and intelligent wipers. Furthermore LIN can be used for engine diagnostics. LIN, not designed exclusively for auto applications, also applies to industrial electronics.
Infineon offers LIN transceivers also including bus wake-up functionality as well as microcontrollers with a LIN compliant UART interface.
点击获取相关产品信息
GMT+8, 2026-4-13 02:03 , 耗时 0.263092 秒, 21 个查询请求 , Gzip 开启.
