查看: 1479|回复: 0
[待整理] 移动通讯词汇-2(中英对照)
发表于 2014-10-13 11:23:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大规模集成电路 large scale integrated circuit (LSI)
大信号信躁比 signal-to-noise ratio of strong signal
带成功结果的常规操作 normal operation with successful outcome
带宽 bandwidth
带内导频单边带 pilot tone-in-band single sideband
带内谐波 in-band harmonic
带内信令 in-band signalling
带内躁声 in-band noise
带通滤波器 band-pass filter
带外发射 out-of-band emission
带外功率 out-of-band power
带外衰减 attenuation outside a channel
带外信令 out-band signalling
带状线 stripline
单边带发射 single sideband (SSB) emission
单边带发射机 single side-band (SSB) transmitter
单边带调制 single side band modulation
单边带解调 single side band demodulation
单边带信号发生器 single side band signal generaltor
单端同步 single-ended synchronization
单工、双半工 simplex, halfduplex
单工操作 simplex operation
单工无线电话机 simplex radio telephone
单呼 single call
单频双工 single frequency duplex
单频信令 single frequency signalling
单相对称控制 symmetrical control (single phase)
单相非对称控制 asymmetrical control (single phase)
单向 one-way
单向的 unidirectional
单向控制 unidirectional control
单信道地面和机载无线电分系统 SINCGARS
单信道无绳电话机 single channel cordless telephone
单信号方法 single-signal method
单音 tone
单音脉冲 tone pulse
单音脉冲持续时间 tone pulse duration
单音脉冲的单音频率 tone frequency of tone pulse
单音脉冲上升时间 tone pulse rise time
单音脉冲下降时间 tone pulse decay time
单音制 individual tone system
单元电缆段(中继段) elementary cable section (repeater section)
单元再生段 elementary regenerator section (regenerator section)
单元增音段,单元中继段 elementary repeater section
当被呼移动用户不回答时的呼叫转移 call forwarding on no reply (CFNRy)
当被呼移动用户忙时的呼叫转 calling forwarding on mobile subscriber busy (CFB)
当漫游到原籍PLMN国家以外时禁止所有入呼 barring of incoming calls when roaming outside the home PLMN country (BIC-Roam)
当前服务的基站 current serving BS
当无线信道拥挤时的呼叫转移
calling forward on mobile subscriber not reachable (CENRc)
刀型天线 blade antenna
导频 pilot frequency
导频跌落pilot fall down
倒L型天线 inverted-L antenna
等步的 isochronous
等幅电报 continuous wave telegraph
等权网(互同步网) democratic network (mutually synchronized network)
等效比特率 equivalent bit rate
等效地球半径 equivalent earth radius
等效二进制数 equivalent binary content
等效全向辐射功率 equivalent isotropically radiated power (e. i. r. p.)
等效卫星线路躁声温度 equivalent satellite link noise temperature
低轨道卫星系统 LEO satellite mobile communication system
低气压实验 low atmospheric pressure test
低时延码激励线性预测编码 low delay CELP (LD-CELP)
低通滤波器 low pass filter
低温实验 low temperature test
低躁声放大器 low noise amplifier
地-空路径传播 earth-space path propagation
地-空通信设备 ground/air communication equipment
地波 ground wave
地面连线用户 land line subscriber
地面无线电通信 terrestrial radio communication
地面站(电台) terrestrial station
第N次谐波比 nth harmonic ratio
第二代无绳电话系统 cordless telephone system second generation (CT-2)
第三代移动通信系统 third generation mobile systems
点波束天线 spot beam antenna电报 telegraphy
电报电码 telegraph code
电波衰落 radio wave fading
电池功率 power of battery
电池能量 energy capacity of battery
电池容量 battery capacity
电池组 battery
电磁波 electromagnetic wave
电磁波反射 reflection of electromagnetic wave
电磁波饶射 diffraction of electromagnetic wave
电磁波散射 scattering of electromagnetic wave
电磁波色射 dispersion of electromagnetic wave
电磁波吸收 absorption of electromagnetic wave
电磁波折射 refraction of electromagnetic wave
电磁场 electromagnetic field
电磁发射 electromagnetic field
电磁辐射 electromagnetic emission
电磁干扰 electromagnetic interference (EMI)
电磁感应 electromagnetic induction
电磁环境 electromagnetic environment
电磁兼容性 electromagnetic compatibility (EMC)
电磁兼容性电平 electromagnetic compatibility level
电磁兼容性余量 electromagnetic compatibility margin
电磁脉冲 electromagnetic pulse (EMP)
电磁脉冲干扰 electromagnetic pulse jamming
电磁敏感度 electromagnetic susceptibility
电磁能 electromagnetic energy
电磁耦合 electromagnetic coupling
电磁屏蔽 electromagnetic shielding
电磁屏蔽装置 electromagnetic screen
电磁骚扰 electromagnetic disturbance
电磁噪声 electromagnetic noise
电磁污染 electromagnetic pollution
电动势 electromotive force (e. m. f.)
电话机 telephone set
电话局容量 capacity of telephone exchange
电话型电路 telephone-type circuit
电话型信道 telephone-type channel
电离层 ionosphere
电离层波 ionosphere wave
电离层传播 ionosphere propagation
电离层反射 ionosphere reflection
电离层反射传播 ionosphere reflection propagation
电离层散射传播 ionosphere scatter propagation
电离层折射 ionosphere refraction
电离层吸收 ionosphere absorption
电离层骚扰 ionosphere disturbance
电流探头 current probe
电路交换 circuit switching
电屏蔽 electric shielding
电视电话 video-telephone, viewphone, visual telephone
电台磁方位 magnetic bearing of station
电台方位 bearing of station
电台航向 heading of station
电文编号 message numbering
电文队列 message queue
电文格式 message format
电文交换 message switching
电文交换网络 message switching network
电文结束代码 end-of-message code
电文路由选择 message routing
电小天线 electronically small antenna
电信管理网络 telecommunication management network (TMN)
电信会议 teleconferencing
电压变化 voltage change
电压变化持续时间 duration of a voltage change
电压变化的发生率 rate of occurrence of voltage changes
电压变化时间间隔 voltage change interval
电压波动 voltage fluctuation
电压波动波形 voltage fluctuation waveform
电压波动量 magnitude of a voltage fluctuation
电压不平衡 voltage imbalance, voltage unbalance
电压浪涌 voltage surge
电压骤降 voltage dip
电源 power supply
电源电压调整率 line regulation
电源抗扰性 mains immunity
电源持续工作能力 continuous operation ability of the power supply
电源去耦系数 mains decoupling factor
电源骚扰 mains disturbance
电子干扰 electronic jamming
电子工业协会 Electronic Industries Association (EIA)
电子系统工程 electronic system engineering
电子自动调谐 electronic automatic tuning
电子组装 electronic packaging
电阻温度计 resistance thermometer
跌落试验 fall down test
顶部加载垂直天线 top-loaded vertical antenna
定长编码 block code
多次调制 multiple modulation
多点接入 multipoint access
多电平正交调幅 multi-level quadrature amplitude modulation (QAM)
多分转站网 multidrop network
多服务器队列 multiserver queue
多工 multiplexing
多工器 nultiplexer
多功能系统 MRS
多级处理 multilevel processing
多级互连网络 multistage interconnecting network
多级卫星线路 multi-satellite link
多径 multipath
多径传播 multipath propagation
多径传播函数 nultipath propagation function
多径分集 multipath diversity
多径时延 multipath delay
多径衰落 multipath fading
多径效应 multipath effect
多路复接 multiplexing
多路接入 multiple access
多路信道 multiplexor channel
多脉冲线性预测编码 multi-pulse LPC (MPLC)
多频信令 multifrequency signalling
多普勒频移 Doppler shift
多跳路径 multihop path
多信道选取 multichannel access (MCA)
多信道自动拨号移动通信系统
multiple-channel mobile communication system with automatic dialing
多优先级 multiple priority levels
多帧 multiframe
多址呼叫 multiaddress call
多址联接 multiple access
多重时帧 multiple timeframe
多用户信道 multi-user channel
E
额定带宽 rated bandwidth
额定射频输出功率 rated radio frequency output power
额定使用范围 rated operating range
额定音频输出功率 rated audio-frequency output power
额定值 rated value
爱尔兰 erlang
恶意呼叫识别 malicious call identification (MCI)
耳机(受话器) earphone
耳机额定阻抗 rated impedance of earphone
二十进制码 binary-coded decimal (BCD) code
二十进制转换 binary-to-decimal conversion
二十六进制转换 binary-to-hexadecimal conversion
二进制码 binary code
二进制频移键控 binary frequency shift keying (BFSK)
二进制数 binary figure
二频制位 binary digit(bit)
二频制 two-frequency system
二维奇偶验码 horizontal and vertical parity check code
二线制 two-wire system
二相差分相移键控 binary different phase shift keying (BDPSK)
二相相移键控 binary phase shift keying (BPSK)
GMT+8, 2026-4-10 11:28 , 耗时 0.089402 秒, 19 个查询请求 , Gzip 开启.
