查看: 1199|回复: 0
[待整理] 在Oracle 10g中如何解决ORA-19815错误
发表于 2014-10-13 14:24:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问题:在备份Oracle10g时出现下面的错误:
ORA-19815: WARNING: db_recovery_file_dest_size of 2147483648 bytes is 100.00% used, and has 0 remaining bytes available.
You have the following choices to free up space from
flash recovery area:
1. Consider changing your RMAN retention policy.
If you are using dataguard, then consider changing your
RMAN archivelog deletion policy.
2. Backup files to tertiary device such as tape using the
RMAN command BACKUP RECOVERY AREA.
3. Add disk space and increase the db_recovery_file_dest_size
parameter to reflect the new space.
4. Delete unncessary files using the RMAN DELETE command.
If an OS command was used to delete files, then use
RMAN CROSSCHECK and DELETE EXPIRED commands.
此时flash_recovery_area已经手工释放空间,甚至切换到一个全新的磁盘,但问题依然没有办法解决。
解决过程如下:
首先,连接数据库查询:
$ sqlplus "/ as sysdba"
SQL*Plus: Release 10.1.0.2.0 - Production on Mon Mar 28 11:45:30 2005
Copyright (c) 1982, 2004, Oracle. All rights reserved.
Connected to:
Oracle Database 10g Enterprise Edition Release 10.1.0.2.0 - 64bit Production
With the Partitioning, OLAP and Data Mining options
SYS AS SYSDBA on 28-MAR-05 >set liesize 120
SP2-0158: unknown SET option "liesize"
SYS AS SYSDBA on 28-MAR-05 >set linesize 120
SYS AS SYSDBA on 28-MAR-05 >SELECT substr(name, 1, 30) name, space_limit AS quota,
2 space_used AS used,
3 space_reclaimable AS reclaimable,
4 number_of_files AS files
5 FROM v$recovery_file_dest ;
NAME QUOTA USED RECLAIMABLE FILES
/data5/flash_recovery_area 2147483648 2144863232 0 227
在此处发现仍然记录了227个文件,但USED空间并未释放。
然后用rman登录数据库进行crosscheck:
$ rman target /
Recovery Manager: Release 10.1.0.2.0 - 64bit Production
Copyright (c) 1995, 2004, Oracle. All rights reserved.
connected to target database: EYGLE (DBID=1337390772)
RMAN> crosscheck archivelog all;
using target database controlfile instead of recovery catalog
allocated channel: ORA_DISK_1
channel ORA_DISK_1: sid=144 devtype=DISK
validation failed for archived log
archive log filename=/opt/oracle/flash_recovery_area/EYGLE/
archivelog/2004_05_17/o1_mf_1_790_0bjq36ps_.arc recid=1 stamp=526401126
archivelog/2004_05_17/o1_mf_1_791_0bkbcy7x_.arc recid=2 stamp=526420862
archivelog/2004_05_17/o1_mf_1_792_0bkkds4d_.arc recid=3 stamp=526428057
archivelog/2004_07_16/o1_mf_1_1014_0hh3zsrp_.arc recid=225 stamp=531678074
archivelog/2004_07_16/o1_mf_1_1015_0hh40qyp_.arc recid=226 stamp=531678104
archivelog/2004_07_16/o1_mf_1_1016_0hh41jqq_.arc recid=227 stamp=531678129
Crosschecked 227 objects
RMAN> delete expired archivelog all;
released channel: ORA_DISK_1
List of Archived Log Copies
Key Thrd Seq S Low Time Name
1 1 790 X 17-MAY-04 /opt/oracle/flash_recovery_area/EYGLE/
2 1 791 X 17-MAY-04 /opt/oracle/flash_recovery_area/EYGLE/
3 1 792 X 17-MAY-04 /opt/oracle/flash_recovery_area/EYGLE/
225 1 1014 X 16-JUL-04 /opt/oracle/flash_recovery_area/EYGLE/
226 1 1015 X 16-JUL-04 /opt/oracle/flash_recovery_area/EYGLE/
227 1 1016 X 16-JUL-04 /opt/oracle/flash_recovery_area/EYGLE/
Do you really want to delete the above objects (enter YES or NO)? YES
deleted archive log
deleted archive log
deleted archive log
deleted archive log
deleted archive log
Deleted 227 EXPIRED objects
RMAN> exit
Recovery Manager complete.
此时空间得以释放:
SQL*Plus: Release 10.1.0.2.0 - Production on Mon Mar 28 12:02:19 2005
Connected to:
/data5/flash_recovery_area 2147483648 9959424 0 1
另一个解决方法:
通过执行下面的命令将闪回区的内容备份到第三方介质:
RMAN> backup recovery area;
GMT+8, 2026-4-9 00:57 , 耗时 0.203117 秒, 19 个查询请求 , Gzip 开启.
