查看: 2605|回复: 0
[待整理] 用Vivado-HLS实现低latency 除法器
发表于 2014-10-13 17:46:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 Vivado HLS简介
        2创建一个Vivado-HLS工程
        2.1打开Vivado HLS GUI
        2.2创建新工程
        在 Welcome Page, 选择Create New Project
        2.3添加源文件
        指定顶层需要综合的源文件名,并添加文件.
        2.4添加测试文件
        添加测试文件.
        2.5创建solution
        3 C Validation
        4 C Synthesis. 13
        5 Explore不同新的Solution. 15
        1 Vivado HLS简介
        Xilinx Vivado High-Level Synthesis (HLS)工具将C, C++,或者SystemC设计规范,算法转成Register Transfer Level(RTL)实现,可综合到Xilinx FPGA.
        将DSP算法快速转到RTL FPGA实现将C至RTL时间缩短4倍基于C语言的验证时间缩短100倍RTL仿真时间缩短3倍
        2创建一个Vivado-HLS工程2.1打开Vivado HLS GUI双击桌面上Vivado HLS GUI图标,或从Start > All Programs >
        Vivado > Vivado HLS GUI
        打开GUI之后,Vivado-HLS welcome界面如下所示:
        2.2创建新工程在Welcome Page,选择Create New Project
        2.3添加源文件指定顶层需要综合的源文件名,并添加文件。
        本除法器设计采用移位算法
        #include "radix2div.h"
        quotient_t radix2div (
        dividend_t dividend, // (numerator)
        divisor_t divisor, // (denominator)
        remainder_t *remainder //
        #pragma AP latency max=3
        #pragma AP pipeline
        quotient_i_t quo, y; // +1 bits unsigned
        subtract_t sub_out, rem_r; // +1 bits signed
        boolean_t last_bit, next_bit;
        loop_cnt_t i;
        last_bit = 0;
        rem_r = 0;
        if (LOOP_MAX > 32)
        quo = 0ULL;
        else
        quo = 0;
        div_booth_label0: for (i = 0; i
        #include
        int test_divider (dividend_t dividend,
        divisor_t divisor
        quotient_t quotient;
        remainder_t remainder;
        quotient = radix2div(dividend,divisor,
        fprintf(stdout, ">>>>>>>>> dividend = %u, divisor = %u quotient = %u remainder = %u n",
        dividend, divisor, quotient, remainder);
        fprintf(stdout, ">>>>>>>>>—— n");
        if ((quotient == dividend/divisor) (remainder == dividend-(divisor*quotient)) ) {
        printf ("PASS n");
        else {
        printf ("FAIL n");
        return 1;
        int main () {
        int i, j;
        dividend_t max_num;
        max_num = 0;
        j = LOOP_MAX-1;
        for (i = 0; i < j; i = i+1) {
          max_num = max_num + pow(2,i);
        test_divider (max_num,1);
        test_divider (2,pow(2,9)-1);
        test_divider (max_num,pow(2,9)-1);
        test_divider (8,1);
        test_divider (99,10);
                        test_divider (8,1);
        2.5      创建solution
               创建solution, 时钟约束, 并选器件.
               打开包括工程信息Vivado HLS GUI.
        3      C Validation
               在将c/c++/system c 转换成RTL之前,必须先验证C 设计,确保其功能是正确的
               点击 “Run C Simulation” 图标,
        4      C Synthesis
               现在可以对设计做C 综合,生成RTL代码. 当综合完成,, GUI 更新综合结果. 包括资源使用,latency等。
                为了达到了预先要求为3 个时钟周期, 将latency 的directive设置为3。
        5      Explore 不同新的Solution
               project -> new solution。
               在同一个工程里面,可以使用同一套源代码,进行不同solutions的尝试。
GMT+8, 2026-4-22 08:04 , 耗时 0.118304 秒, 21 个查询请求 , Gzip 开启.
