查看: 3943|回复: 5
BX48 编程器 Pin Control ASIC
发表于 2014-11-13 20:17:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A new chip was introducted specifically for supporting the pin control functions.
This new pindriver ASIC provides the performance and flexibility previously inconceivable.
The BX48, BX448 and BX848 are the only programmers in the world supporting extremely low power supply ICs according to JEDEC Norm JESD8-14A.01.
Chips meeting this standard have to be powered with a supply voltage of 1.0 V with a maximum tolerance of 100 mV.
Each of the 48 pins can be used independently and flexibly:
  • Four supply and programming voltages from 0.9 V up with 10 mV resolution!
  • Logic-Output
  • Logic-Input
  • High speed serial interface
  • Analog Input (A/D measurements with 10 mV resolution!)
  • Analog Output (D/A voltage output with 10 mV resolution!)
  • Six switchable pullup+pulldown resistors on VPP, VCC and GND
  • Adjustable clock frequencies up to 24.5 MHz
  • Ground
这芯片比较牛啊
沙发
发表于 2014-11-14 08:47:01 | 只看该作者
这是个专用的pin全驱芯片,无资料可查,该是定制的
板凳
 楼主| 发表于 2014-11-19 07:09:32 | 只看该作者
用这个比分立元件方便多了
地板
发表于 2021-7-2 16:39:52 | 只看该作者
谢谢分享, 一切为了银子
5#
发表于 2025-4-6 21:37:29 | 只看该作者
谢谢分享, 一切为了银子
6#
发表于 2025-4-7 14:47:19 来自手机 | 只看该作者
这个是好,关键是价格,大家能接受。
GMT+8, 2025-5-10 01:22 , 耗时 0.086570 秒, 21 个查询请求 , Gzip 开启.
