查看: 3942|回复: 2
[资料] USB-FPGA Module 2.04
发表于 2014-11-26 09:41:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
http://www.ztex.de/usb-fpga-2/usb-fpga-2.04.e.html
Features
  • USB 2.0 interface with Mini-USB connector (B-type)
  • Cypress CY7C68013A EZ-USB FX2 Microcontroller (100 pin version)
  • Xilinx Spartan 6 XC6SLX16 FPGA (XC6SLX9 and XC6SLX25 on request)
  • External I/O connector (consisting in two female 2x32 pin headers with 2.54mm grid) provides:
    • 88 General Purpose I/O's (GPIO) connected to FPGA
    • 6 General Purpose I/O's (GPIO) connected to EZ-USB FX2 Controller
    • 6 Special I/O's (SIO) connected to EZ-USB FX2 Controller
    • JTAG signals
    • Reset signal
    • External power (4.5 V .. 16 V) input
    • 3.3V output
    • I/O voltage output or input, see External I/O connector
  • 64 MByte DDR SDRAM:
    • 200 MHz clock frequency
    • 16 Bit bus width
    • Up to 800 MByte/s data rate
    • Easy to use hard memory controller included Spartan 6 FPGA with 6 ports. (see SDK for examples)
  • 128 MBit on-board Flash memory
    • Allows Bitstream loading from Flash to FPGA (up to 6.5 MByte/s)
    • Accessible from EZ-USB FX2 and from FPGA
  • 128 Kbit EEPROM memory (can be used to store the EZ-USB firmware)
  • 2 Kbit MAC-EEPROM: contains a unique non erasable MAC-address and is used to store firmware settings
  • On-Board power supply:
    • 3.3 V: 2000 mA
    • 2.5 V: 2000 mA
    • 1.2 V; 1000 mA
  • Temperature range: 0-70°C
沙发
 楼主| 发表于 2014-11-26 09:48:14 | 只看该作者
板凳
 楼主| 发表于 2014-11-26 09:48:39 | 只看该作者
GMT+8, 2026-4-22 08:04 , 耗时 0.213139 秒, 20 个查询请求 , Gzip 开启.
