查看: 3757|回复: 2
[资料] USB-FPGA Module 2.16
发表于 2014-11-26 09:43:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
http://www.ztex.de/usb-fpga-2/usb-fpga-2.16.e.html
Features
  • High-Speed (480 MBit/s) USB interface via Mini-USB connector (B-type)
  • Cypress CY7C68013A EZ-USB FX2 Microcontroller (128 pin version)
  • Two Xilinx Artix 7 FPGA variants: XC7A200T (stock type) and XC7A100T (on request), see Variants
  • External I/O connector (consisting in two female 2x32 pin headers with 2.54mm grid) provides:
    • 100 General Purpose I/O's (GPIO) connected to FPGA
    • JTAG signals
    • Reset signal
    • External power (4,5 V .. 16 V) input
    • 3.3V output
    • I/O voltage output or input, see External I/O connector
  • 128 MBit on-board Flash memory
    • Allows Bitstream loading from Flash to FPGA (up to 16.5 MByte/s)
    • Accessible from EZ-USB FX2 and from FPGA, see the CPLD description
  • Fast FPGA configuration via USB using CPLD: up to 24 MByte/s
  • Memory mapped IO between EZ-USB FX2 and FPGA
  • 128 Kbit EEPROM memory (can be used to store the EZ-USB firmware)
  • 2 Kbit MAC-EEPROM: contains a unique non erasable MAC-address and is used to store firmware settings
  • On-Board power supply:
    • 3.3 V: 2000 mA
    • 1.8 V: 1000 mA
    • 1.0 V; 14000 mA
  • Heat sink for high performance / high speed applications, see Section heat sink
  • Optional:
    • Battery to store a key for bitstream encryption
    • On-board JTAG connector
  • Temperature range: 0-70°C
沙发
 楼主| 发表于 2014-11-26 09:46:12 | 只看该作者
板凳
 楼主| 发表于 2014-11-26 09:46:53 | 只看该作者
GMT+8, 2026-4-22 08:04 , 耗时 0.404175 秒, 20 个查询请求 , Gzip 开启.
