查看: 3686|回复: 0
[资料] Experimental Board 1.3 for Series 1 FPGA Boards
发表于 2014-11-26 09:57:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
http://www.ztex.de/usb-fpga-1/exp-1.3.e.html
Features
  • Baseboard for USB-FPGA Modules 1.2, 1.11 and 1.15.
  • High-efficiency switching regulators to generate the supply voltages
    • 1.2 V @ 8 A
    • 2.6 V @ 2.5 A
    • 3.3 V @ 2.5 A
    • Wide input range: 4.5 to 16 V
  • I/O voltages VCCO_RIGHT / VCCO_IO and VCCO_TOP can be easily and independently set to 3.3V, 2.6V, 1.2V or to an external voltage.
  • All I/O Ports available on a standard 2.54 mm (0.1 inch) grid via six 1x23 pin connectors to which Expansion Boards or Breadboards can be connected
  • Downward pin compatible to Experimental Board 1.2 and Experimental Board 1.1
  • JTAG interface for the FPGA
GMT+8, 2026-4-22 11:18 , 耗时 0.228280 秒, 22 个查询请求 , Gzip 开启.
