查看: 12553|回复: 14
u2pa,牛人为top2005+写的上位机,源代码来着
发表于 2015-4-20 19:17:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
牛人为top2005+写的上位机,源代码来着,参考是不错的
20120526 Version 0.1:
20120530 Correction a: Added support for 274096 as it was desribed in the release notes.
20120602 Correction b: Fixed a bug regarding the GND-pins.
This is the first release of U2Pa, a command line interface for
Top Universal Programmers.
Features:
- Simple reading of some EPROMs
- Simple (Classic Algorithm) programming of some EPROMs
- Simple test of some SRAMs
- Support for other EPROMs and SRAMs are fairly easy implemented (through XML)
- Coded in C#
- Uses the GPL library LibUsbDotNet (that in turn uses the GPL library
  libusb-1.0)
- The source code is well documented and should by fairly easy to understand
- Runs on both native .NET (tested on Windows7) and Mono (tested on Ubuntu)
Suported and tested programmers:
- Top2005+ Universal Programmer
Supported devices:
- EPROMs: 2716, 2732, 2764, 27128, 27256, 27512 (out of the box)
- EPROMs: 271024, 272048, 274096 (by the use an easy-to-build-adaptor)
- SRAMs:  6116, 6264 (out of the box)
- SRAMs:  6148 (by using 1 wire)
u2pa V0.1b.zip (210.21 KB, 下载次数: 41)
收藏收藏2 分享分享 支持支持 反对反对
沙发
发表于 2015-4-20 22:04:02 | 只看该作者
先看在说。不管那么多,下载。
地板
发表于 2015-4-23 13:21:40 | 只看该作者
学习中!感谢!
5#
发表于 2015-4-23 14:35:37 | 只看该作者
下下来看看再说啊
6#
发表于 2015-5-3 22:52:14 | 只看该作者
学习中!感谢!!
7#
发表于 2016-6-9 17:30:02 | 只看该作者
路过,为了赚积分.
8#
发表于 2016-6-16 21:36:12 | 只看该作者
看看 学习学习
9#
发表于 2018-2-25 11:12:38 | 只看该作者
咋用,没有后续吗?
10#
发表于 2018-3-7 14:54:52 | 只看该作者
先看在说。不管那么多,下载
GMT+8, 2025-12-16 08:08 , 耗时 0.125075 秒, 22 个查询请求 , Gzip 开启.
