查看: 1845|回复: 0
[待整理] RedHat 9.0上ADSL最终解决方案
发表于 2015-4-27 00:28:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在网上一些BBS看了很多关于ADSL的文章,都没有解决我的REDHAT9上ADSL上网的问题,今天实在是没有办法,重新建立连接,曲折的经历,终于上网了(非常激动,可能表达的不是很好),特的写下我的过程,作为参考:
  REDHAT默认的PPPOE有问题,需要RPM -E,然后,安装这个
  http://www.roaringpenguin.com/pppoe/rp-pppoe-3.5.tar.gz(北南兄推荐)
  解压和安装:
  #tar zxvf rp-pppoe-3.5.tar.gz
  进入解压目录执行
  #sh ./go
  然后再来设置ADSL。这一处,我们要用命令。
  #adsl-setup
  Welcome to the Roaring Penguin ADSL client setup. First, I will run some checks on your system to make sure the PPPoE client is installed
  properly...
  Looks good! Now, please enter some information:
  USER NAME
  >>> Enter your PPPoE user name (default XXX): 在这里输入ADSL的用户名
  INTERFACE
  >>> Enter the Ethernet interface connected to the ADSL modem For Solaris, this is likely to be something like /dev/hme0.
  For Linux, it will be ethn, where 'n' is a number.
  (default eth0):如果一张网卡就设置写上eth0
  Do you want the link to come up on demand, or stay up continuously?
  If you want it to come up on demand, enter the idle time in seconds after which the link should be dropped. If you want the link to stay up permanently, enter 'no' (two letters, lower-case.)
  NOTE: Demand-activated links do not interact well with dynamic IP addresses. You may have some problems with demand-activated links.
  >>> Enter the demand value (default no):不用写什么 DNS
  Please enter the IP address of your ISP's primary DNS server.
  If your ISP claims that 'the server will provide DNS addresses',
  enter 'server' (all lower-case) here.
  If you just press enter, I will assume you know what you are doing and not modify your DNS setup.
  >>> Enter the DNS information here:在这里写上202.96.134.133
  下一个DNS是202.96.168.68 //这里根据个人不同可以修改
  PASSWORD
  >>> Please enter your PPPoE password:输入密码
  >>> Please re-enter your PPPoE password:再输入一次
  FIREWALLING
  Please choose the firewall rules to use. Note that these rules are very basic. You are strongly encouraged to use a more sophisticated firewall setup; however, these will provide basic security. If you are running any servers on your machine, you must choose 'NONE' and set up firewalling yourself. Otherwise, the firewall rules will deny access to all standard servers like Web, e-mail, ftp, etc. If you are using SSH, the rules will block outgoing SSH connections which allocate a privileged source port.
  The firewall choices are:
  0 - NONE: This script will not set any firewall rules. You are responsible for ensuring the security of your machine. You are STRONGLY
  recommended to use some kind of firewall rules.
  1 - STANDALONE: Appropriate for a basic stand-alone web-surfing workstation
  2 - MASQUERADE: Appropriate for a machine acting as an Internet gateway
  for a LAN
  >>> Choose a type of firewall (0-2):这里添写为2
  ** Summary of what you entered **
  Ethernet Interface: eth0
  User name: XXX
  Activate-on-demand: No
  DNS: Do not adjust
  Firewalling: MASQUERADE
  >>> Accept these settings and adjust configuration files (y/n)?
  弄完后,就按一个y键。
  (以上为北南兄文章里面内容)
  不要急于连接,REBOOT -N
  然后进入网络设置,设置ETH1固定IP,停止ETH1(我的是用他)
  然后ADSL-START PING 你的DNS,如果可以,那么,恭喜你!
  如果不行,REBOOT -N
  ADSL-START,这下没问题啦,尽情享受吧!
  其中部分内容可能不同,仅作参考,主要在连接后,能够PING通DNS即可!
GMT+8, 2026-4-21 23:25 , 耗时 0.138535 秒, 18 个查询请求 , Gzip 开启.
