查看: 2306|回复: 0
[待整理] 英飞凌门禁系统解决方案
发表于 2015-4-27 21:40:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Door Module Solution
In automotive comfort electronics, Door Zone Modules have become a mainstream solution. A Door Zone Module covers all (or a part of) the electrical functions which are located in the mechanical door assembly like electrical door lock, electrified mirror, power window, lights, LEDs and the control panel. To generate system cost advantage on the wire harness, the module is a stand-alone unit, controlled by bus communication.
Infineon offers a complete range of products for this application, covering all necessary functions such as communication, supply, power drivers, sensors and microcontrollers. Standard stand-alone products as well as Application Specific Standard Products (ASSPs) are available.
XC164CS Series
64-256 KBytes Flash in P-TQFP-100 package CAN, 14 ch. ADC, CCU6, -40..85/125°C
XC161CJ/CS
128-256 KBytes Flash in P-TQFP-144 package CAN, J1850, 12 ch. ADC, I2C, -40..85/125°C
XC164CM Series
32-128 KBytes Flash in PG-TQFP-64 package CAN, 14 ch. ADC, CCU6, -40..85/125°C
XC167CI
128-256 KBytes Flash in P-TQFP-144 package CAN, 16 ch. ADC, CCU6, IIC, -40..85/125°C
Additional Information
Documents
点击获取相关产品资料
GMT+8, 2026-4-25 02:25 , 耗时 0.458172 秒, 21 个查询请求 , Gzip 开启.
