查看: 2015|回复: 0
[待整理] 英飞凌安全气囊控制解决方案
发表于 2015-4-27 21:40:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
INTRODUCTION
Since the airbag was introduced its reliability and safeness has been improved continuously. A very important role comes up to the microcontroller that determines when to fire the airbag(s) based on sensor data.
COMPONENTS
Infineon''s 16-bit microcontroller C164CL/CG suits this application perfectly in combination with a micromachined acceleration sensor. The sensor provides measurement in two dimensions and including sensing, signal conditioning, system interface, and self-test capability.
Highly integrated power devices that reduce board space and pin count are dedicated to airbag applications. Application Specific ICs (ASICs) to fire and test the squibs are good examples. A power supply with step-down and step-up converters is fully integrated, too. This integration is possible due to Infineon''s smart power technologies combining bipolar, CMOS, and DMOS, on one chip. Infineon has already shipped more than 53 million System IC devices for airbag applications.
SCHEMATIC DIAGRAM of an airbag Electronic Control Unit (ECU):
点击获取相关产品信息
GMT+8, 2026-4-25 06:08 , 耗时 0.089868 秒, 21 个查询请求 , Gzip 开启.
