查看: 2560|回复: 0
[待整理] Rhythm R3710预配置DSP系统设计所需规范详析
发表于 2015-4-27 23:58:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Rhythm R3710 规范
          Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability.
        Table 1. ABSOLUTE MAXIMUM RATINGS
          WARNING: Electrostatic Sensitive Device − Do not open packages or handle except at a static−free workstation.
          WARNING: Moisture Sensitive Device − RoHS Compliant; Level 4 MSL. Do not open packages except under controlled conditions.
        Table 2. ELECTRICAL CHARACTERISTICS (Supply Voltage VB = 1.25 V; Temperature = 25C)
        Table 3. TIMING
  •                 1. A device must internally provide a hold time of at least 300 ns for the PC_SDA signal to bridge the undefined region of the falling edge of PC_CLK.
  •                  The maximum tHD;DAT has only to be met if the device does not stretch the LOW period (tLOW) of the PC_CLK signal.
  •                  A Fast−mode I2C−bus device can be used in a Standard−mode I2C−bus system, but the requirement tSU;DAT P250ns must then be met.This will automatically be the case if the device does not stretch the LOW period of the PC_CLK signal. If such a device does stretch the LOW period of the PC_CLK signal, it must output the next data bit to the PC_SDA line tr max + tSU;DAT = 1000 + 250 = 1250 ns (according to the Standard−mode I2C−bus specification) before the PC_CLK line is released.
  •                  Cb = total capacitance of one bus line in pF.
        Figure 2. Mode Timing
          推荐阅读:
          摘 要:Rhythm R3710是一款专门针对IIC助听器而设计的预配置数字信号处理器(DSP)系统,适合深耳道应用。这器件采用安森美半导体先进的thinSTAX微型 封装,以堆叠式芯片架构将多个芯片及元件封装在混合模块中,提供业界最小混合模块外形因数,使助听器制造商能够利用这极小尺寸的优势,生产适合更大部分消 费者 的IIC助听器。
          摘 要:RhythmR3710 is a pre−configured DSP system designed specifically for Invisible−In−Canal (IIC) hearing aid devices.Available in the industry’s smallest hybrid form−factor.
          摘 要:The iSceneDetect feature, when enabled, will sense the environment and automatically control the enhancement algorithms without any user involvement.
GMT+8, 2026-4-15 10:16 , 耗时 0.431306 秒, 22 个查询请求 , Gzip 开启.
