查看: 2025|回复: 0
[ChipProg] DIP40转QFP80 AE-Q80-F32
发表于 2015-7-3 17:59:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
DIP40/QFP80 specialized adapter for 32-bit Flash memory
Description:
        DIP40/QFP80 specialized adapter for 32-bit Flash memory. Device package dimensions: body - 20.0 x 14.0 x 3.2 mm, body with pins - 23.2 x 17.2 mm, 0.8 mm pitch.
Supported Devices:
        Click the device programmer model below to get an appropriate list of the devices supported by this programmer with this adapter:
  • ChipProg-481
  • ChipProg-G41
  • ChipProg-48
  • ChipProg-40
        Adapter Connection Table:
DIP-40
QFP-80
U1, 74AHC573
U2, 74AHC573
U3, 74AHC573
C1, 150pF
C2, 0.1uF
1
74
2
75
3
76
4
1
2
5
2
3
6
3
4
7
4
5
8
7
6
9
8
7
10
9
8
11
10
9
12
11
2
13
12
3
14
13
4
15
14
5
16
17
6
17
18
7
18
19
8
19
20
9
20
6,16,31,50,60,70,71
1, 10
1, 10
1, 10
2
2
21
11
11
11
1
22
32
23
45
24
46
25
47
26
48
27
51
28
52
29
53
30
54
31
55
2
32
56
3
33
57
4
34
58
5
35
61
6
36
62
7
37
63
8
38
64
9
39
66
40
5,15,21,33,49,59,65,73,77,78,80
20
20
20
1
22
19
23
18
24
17
25
16
26
15
27
14
28
13
29
12
30
19
34
18
35
17
36
16
37
15
38
14
39
13
40
12
41
19
42
18
43
17
44
16
GMT+8, 2024-9-25 03:07 , 耗时 0.094436 秒, 21 个查询请求 , Gzip 开启.
