查看: 48053|回复: 52
[资料] TL866CS升级TL866A的方法 英文版
发表于 2017-4-20 21:54:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Here's a quick guide to upgrading your TL866 programmer from the CS version to the A version.
This operation enables use of the ICSP port (which is easily soldered in).
游客,如果您要查看本帖隐藏内容请回复
1: Install the Programmer's software in C:\MiniPro (I used the current version included in the .zip).
2: Plug in Programmer (hope you c[/hide]hose to install the USB driver in the above step).
3: Run Programmer Software and look at the very bottom line. It should show your version TL866CS.
4: Exit back to Desktop.
5: Run the TL866.exe program.
6: Click the browse button [...] and browse for your update.dat file in C:\MiniPro.
7: Select the "Firmware Dumper" button, and hit the "Reflash" button
8: Click "Advanced", then select "A Bootloader", then hit "Write"
9: Unselect "Code protection bit", then hit "Write"
A: Hit OK to exit that menu, then select "TL866A firmware" and hit "Reflash"
B: When reflash is done, hit "Reset", wait, and hit "Reset" again.
C: Exit the TL866.exe program.
D: Run Programmer software again, look at bottom line. It should say TL866A.
E: Have fun
Please note that I performed the above steps while I was typing this,
so I am quite certain everything is correct.
Edit: There are some confirmation prompts that I skipped here because they're obvious.
Just say "Yes" or "OK" on all such prompts.
沙发
发表于 2017-4-20 22:42:57 | 只看该作者
感谢分享 学习了
板凳
发表于 2017-4-21 11:32:52 | 只看该作者
东西不错,可惜看不懂。
地板
发表于 2017-4-21 19:51:16 | 只看该作者
谢谢楼主分享。
5#
发表于 2017-4-22 17:55:25 | 只看该作者
感谢分享 学习了
6#
发表于 2017-4-26 00:04:40 | 只看该作者
看看是什么东西
7#
发表于 2017-4-28 09:56:39 | 只看该作者
我想看看怎么改,我有一个这样的编程器
8#
发表于 2017-5-24 10:11:58 | 只看该作者
想学习一下,谢谢!
9#
发表于 2017-5-28 13:13:11 | 只看该作者
在那下载那个updata.dat文件呀!
10#
发表于 2017-5-29 14:03:27 | 只看该作者
太好了。谢谢分享
GMT+8, 2024-9-22 14:18 , 耗时 0.100356 秒, 18 个查询请求 , Gzip 开启.
