楼主: shangdawei
[资料] TL866CS升级TL866A的方法 中文版
发表于 2018-12-23 19:21:24 | 只看该作者
非常实用,有用。谢谢楼主分享!
272#
发表于 2018-12-26 18:38:05 | 只看该作者
火前刘明,收藏下来学习下先
273#
发表于 2019-1-4 16:03:01 | 只看该作者
银子不足挣点银子
274#
发表于 2019-1-10 22:04:06 | 只看该作者
谢谢,感谢分享
275#
发表于 2019-1-21 09:15:23 | 只看该作者
感谢分享 学习了
276#
发表于 2019-1-21 14:21:22 | 只看该作者
谢谢分享,楼主辛苦了
277#
发表于 2019-1-22 21:57:30 | 只看该作者
请用新版本V2.5,更新crc
TL866.zip (1.06 MB, 下载次数: 0)
1. Browse for update.dat file (any version is good including the new 6.80, 6.81 and 6.82)
2.Select the firmware dumper and click reflash.
3.After reflash click the advanced button
4.Now pay attention: if the copy protection checkbox is unchecked please check this and click write button.
If the copy protection checkbox is checked leave it alone.
This is important if you leave the copy protect bit unchecked then the new firmware will disable the bootmode, so beware!
5.Serial number and device code section.
Just click the write button in the serial number section. This will rewrite the same serial with the correct checksum.
This was a flaw in my reencrypted serial. A single byte checksum was wrong and the autoelectric discovered this after five years! good. I like this.
6.Close the advanced window, check the TL866A firmware and click reflash again.
强制进入bootmode方法
if the programmer is bricked. you can add a resistor(about 240 ohm) as the follow picture. and install old version software , then reflash firmware. then remove this resistor.
278#
发表于 2019-1-26 23:36:29 | 只看该作者
fcdsfdsfds fdsafdsfdsf
279#
发表于 2019-2-20 10:12:01 | 只看该作者
谢谢分享,楼主辛苦了
280#
发表于 2019-2-22 21:47:10 | 只看该作者
很棒,刚好用得上,谢谢。
GMT+8, 2026-1-24 12:00 , 耗时 0.098950 秒, 20 个查询请求 , Gzip 开启.
