查看: 6187|回复: 2
DS1481 PARALLEL PORT INTERFACE
发表于 2019-9-14 20:39:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
NMI interrupts of the PC will not guarantee flawless
communication to a 1-wire device through a parallel port
directly, and is discouraged to attempt. As the 1-wire protocol
requires the first 15us of each time slot to contain the data
information, any disruption of this time segment will result in
a communication error. Communicating through the PC
parallel port, as it has been utilized for Dallas Thermal Demo
kits DS1820K and DS1821K, requires timing corrections.
These functions are performed by the DS1481 bus-master. It
translates code from the parallel port to the 1-wire data line,
and buffers data coming from the 1-wire device to the parallel
port:
板凳
发表于 2024-8-2 23:45:34 | 只看该作者
谢谢分享
GMT+8, 2026-4-11 21:39 , 耗时 0.096507 秒, 20 个查询请求 , Gzip 开启.
