查看: 1542|回复: 4
8-pin Universial Programmer
发表于 2025-8-3 14:54:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
原文:
https://hackaday.io/project/171689-8-pin-universial-programmer
This is a "universal" programmer intended for various 8-pin chips:
I2C EEPROM chips, for example 24LC02B and AT24C64D
SPI EEPROM and Flash chips, for example M25P16 and W25Q128
Microwire EEPROM chips, for example 93AA66C
Some microcontrollers, for example ATtiny85.
The architecture of this programmer is somewhat based on those high end universal programmers: a USB MCU interfacing the computer, and an FPGA routing signals to the pins of the target chip. This specific implementation used a STM32F103CBT6 as the USB MCU, and a XC2C32A CPLD as the routing chip.
The hardware allows the programmer to interface any chip that:
In a DIP-8 package, or can be adapted to this pin layout using adapters,
Operates with 3.3V power on pin 8,
Operates with ground on pins 4 or 5,
Operates with 3.3V LVTTL logic levels,
Additionally, if I2C is used on pins 5, and 6, an external bypass can be used to allow faster I2C access.
电路图
JerichoProgrammer.pdf (70.36 KB, 下载次数: 7)
没找到固件及软件,大家一起找找看看
沙发
发表于 2025-8-21 08:04:30 | 只看该作者
这个要是又固件和软件的话那是相当的不错啊
板凳
 楼主| 发表于 2025-8-21 11:54:52 | 只看该作者
他还在开发中呢
地板
发表于 2025-8-24 08:10:24 | 只看该作者
那看来还有后续咯!
5#
发表于 2025-10-7 07:20:32 | 只看该作者
楼主后面还有后续吗?
GMT+8, 2026-5-1 19:27 , 耗时 0.439010 秒, 21 个查询请求 , Gzip 开启.
