查看: 526|回复: 0
[电路图] 直流电动机控制电路
发表于 2011-6-2 10:10:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
直流电动机控制电路-DC Motor Control Circuit
Notes:
Here, S1 and S2 are normally open , push to close, press button switches. The diodes can be red or green and are there only to indicate direction. You may need to alter the TIP31 transistors depending on the motor being used. Remember, running under load draws more current. This circuit was built to operate a small motor used for opening and closing a pair of curtains. As an advantage over automatic closing and opening systems, you have control of how much, or how little light to let into a room. The four diodes surriunding the motor, are back EMF diodes. They are chosen to suit the motor. For a 12V motor drawing 1amp under load, I use 1N4001 diodes.
[责任编辑:电子发烧友---转载请标明出处]
GMT+8, 2026-4-9 03:46 , 耗时 0.211724 秒, 19 个查询请求 , Gzip 开启.
