查看: 788|回复: 0
[电路图] 自动大灯亮度开关电路 (Automatic Headlight Brightness Switch)
发表于 2011-6-2 13:50:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Driving the highway with your high-beam headlights can really increase your visibility, but can he a blinding hazard for other drivers. This simple circuit can be wired into your headlight switch to provide automatic switching between high and low beam headlights when there is oncoming traffic. It does this by sensing the lights of that traffic. In this way, you can drive safely with your high-beams on without blinding other drivers.
Parts:
Part
Total Qty.
Description
Substitutions
R115K 1/4W Resistor
R2, R3, R435K Pot
Q11NPN Phototransistor
Q212N3906 PNP Transistor
K11Low Current 12V SPST Relay
K21High Current 12V SPDT Relay
S11SPST Switch
B11 Car Battery
MISC1Case, wire, board, knobs for pots
Notes:
1. Q1 should me mounted in such a way so it points toward the front of the car with a clear line of site. Suitable places are on the dashboard, in the front grill, etc.
2. Adjust all the pots for proper response by testing on a deserted road.
3. S1 enables and disables the circuit.
4. B1 is, obviously, in the car already.
5. Before you try to connect this circuit, get a wiring diagram for your car. Some auto manufacturers do weird things with wiring.
6. Connection A goes to the high beam circuit, B goes to the headlight switch common and C connects to the low beam circuit.
GMT+8, 2026-4-26 15:40 , 耗时 0.137927 秒, 19 个查询请求 , Gzip 开启.
