查看: 436|回复: 0
[电路图] 黑暗感应开关电路,Dark Sensitive Switch
发表于 2011-6-2 22:25:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Specifications
Dark Sensitive Switch is a simple project which operates a relay when the light falling on the LDR goes below a set point.
Input - 12 V @ 55 mA
Relay output - NC-C-NO
Onboard preset to set the level
Power-On LED indicator
Relay On LED indicator
Power Battery Terminal (PBT) for easy relay output connection
Four mounting holes of 3.2 mm each
PCB dimensions 44 mm x 49 mm
Parts List
PCB
GMT+8, 2026-4-10 06:46 , 耗时 0.126637 秒, 19 个查询请求 , Gzip 开启.
