查看: 672|回复: 0
[电路图] AD7414/AD7415 数字输出温度传感器
发表于 2011-6-2 23:59:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The AD7415 is a complete temperature monitoring system in a 5-pin SOT-23 package. It contains a bandgap temperature sensor and 10-bit ADC to monitor and digitize the temperature reading to a resolution of 0.25°C.
The AD7415 provides a two-wire serial interface, which is compatible with SMBus and I2C interfaces. The part comes in four versions, the AD7415-0, AD7415-1, AD7415-2 and AD7415-3. The AD7415-0 and AD7415-1 versions allow for the choice of three different SMBus addresses each. All four versions combined give a possibility of eight different I2C addresses for the AD7415.
The AD7415's 2.7 V supply voltage, low supply current, serial interface and small package size, make it ideal for a variety of applications, including personal computers, cellular phones, office equipment and domestic appliances.
Also see the AD7414, a sister part to the AD7415 but with more functionality such as SMBus Alert functionality in a 6-Lead SOT-23.
Typical Application Circuit for AD7415
AD7414/AD7415,pdf datasheet (Digital Output Temperature Sensor)
GMT+8, 2026-4-6 23:23 , 耗时 0.937917 秒, 19 个查询请求 , Gzip 开启.
