查看: 961|回复: 0
[电路图] 3线混频器电路 (3 Line Mixer)
发表于 2011-6-3 08:44:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
This project is a 3 or more lines mixer. For more than 3 inputs you can repeat the input parts (P=10K R=22K). It powered with 9Vdc.
Componets Layout
PCB (5,5cm x 4,4cm)
GMT+8, 2026-4-7 13:34 , 耗时 0.316033 秒, 18 个查询请求 , Gzip 开启.
