查看: 712|回复: 0
[电路图] 用分立(贴片)元件制作的调频发射电路
发表于 2011-6-3 09:04:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用分立(贴片)元件制作的调频发射电路
This SMD FM transmitter has an operating frequency of about 80 to 115MHz. Under reasonable circumstances you will be able to receive its signal at a distance of about 200 meters. Although it is low-power, it might be illegal in your part of the planet.
Here's the circuit:
Depending on the electret microphone you use, you might have to tweek R4 to set the gain of the pre-amplifier. Depending on the Q of the LC-part (usually not very good when using off-the-shelf SMD parts) you may also have to re-bias the end stage of the circuit. For the coil you can use a ECM45T Series Inductor.
You can download the PCB design here (only 2.5Kb). It's a double-sided PCB in CorelDraw 3.0 format (zip compressed).
GMT+8, 2026-4-13 16:29 , 耗时 0.089903 秒, 18 个查询请求 , Gzip 开启.
