查看: 1184|回复: 0
[无线] 无线话筒电路图
发表于 2011-6-3 13:24:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Couple Notes:
Q1 amplifies input signal via C4 from the electret microphone.
Q2 acts as an oscillator and the signal coming off C2 is fed onto the base of Q2.
L1/C1 is a called 'tank' circuit in the 88MHZ band on your regular AM/FM radio dial.L1 is a 1uH variable inductor ciol be able to tune it a little bit,and the range of 1uH is approximate.
The antenna can be as simple as a 8 "(21cm)piece of wire of and king.
GMT+8, 2026-4-20 17:53 , 耗时 0.215000 秒, 22 个查询请求 , Gzip 开启.
