查看: 2326|回复: 0
常见CD机光头、芯片对照表
发表于 2011-4-25 12:26:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
常见CD机光头、芯片对照表
厂牌 型号  解码 光头
ACOUSTIC RESEARCH CD-07 SAA7220
ACCUPHASE DP85  AD1853  NJM4580
ACCUPHASE DP90 PCM63
ADC CD 250XR  PCM54
AKAI CD25/26/27/32/36  KSS210A
AKAI CD37 PCM67P KSS210A NJM4558
AKAI CD52  KSS210A
AKAI CD55  AD1856 KSS210A
AKAI CD57 PCM67PJ KSS210 CXD1167Q
AKAI CD62  BO38258J
AKAI CD650/70  KSS210A
AKAI CD69  PCM63 KSS210A
AKAI CD-A70  MB84053B KSS123A//BO367214J
AKAI CD-M839  PCM56
AKAI CD79  KSS210A
AKAI CD750  KSS210A
AKAI CD73/93 PCM56 KSS155A(884806401)
ALBA CD420  PCM54
ALCHEMIST NEXUS APD32A  2x TDA1549
AMC CD60  PCM1716
AMC CD8A  MN6474 (Technics MASH)
ANTHEM CD1  PCM1702
ARCAM ALPHA 5  TDA1541 CDM9
ARCAM ALPHA 5 PLUSTDA7310 SAA7220P/B TDA1541A CDM9
ARCAM ALPHA 6  SM5864
ARCAM ALPHA 7  PCM1710
ARCAM ALPHA 7SE  PCM1716
ARCAM ALPHA 8  SM5864AP
ARCAM ALPHA 9 dCS  RingDAC
ARCAM CD72  PCM1716
ARCAM CD92 dCS  RingDAC
ARCAM DELTA 70.2 TDA1541-S1 cdm4/31
ARCAM DELTA 70.3 LM627
ARCAM DELTA 270  PCM69
ARCAM DELTA BOX 5  PCM67
ARYE CX-7  PCM1738
ARYE D-1  PCM1704
AUDIO ALCHEMY ENGINE v3.0 AD1862
AUDIO ANALOGUE MAESTRO  AD1855
AUDIO INNOVATIONS ALTO  PCM1716
AUDIO NOTE CD-1  PCM1710
AUDIO NOTE CD-2  AD1865
AUDIO NOTE DAC-3  PCM63
AUDIO RESEARCH CD1  SAA7341
AUDIOLAB 8000 CD  CS4329
AVI SC2000MC  PCM63
BLAUPUNKT CP2650  PCM54
CAMBRIDGE AUDIO CD1  TDA1541
CAMBRIDGE AUDIO CD2SAA7210 SAA7220P/A 4xTDA1541 CDM2
CAMBRIDGE AUDIO CD3  TDA1541A
CAMBRIDGE AUDIO CD4SE  CS4327
CAMBRIDGE AUDIO CD6  TDA1305T
CAMBRIDGE AUDIO D500  CS4327
CARVER SD/A 450  MN6474
C.E.C. 530CD2  Y3015
C.E.C. 680CD  LC7881
CONDOR CD950  YM3020
COPLAND CDA277  PCM63
COPLAND CDA288  PCM63-K
CROWN CD2111R  LC7881
CYRUS CD7  PCM1716
CYRUS dAD1  TDA1311
CYRUS dAD3  TDA1305
CYRUS dAD3Q  AD1861
CYRUS dAD7  AD1861
DENON DA-500  PCM1702
DENON DCD-315  NKS240A
DENON DCD-435  PCM1716E
DENON DCD-480  PCM61 NKS240A
DENON DCD-485  PCM1735
DENON DCD-500  PCM54 KSS123A
DENON DCD-520  KSS210A
DENON DCD-580  PCM67P NKS240A
DENON DCD-590  PCM61
DENON DCD-600  KSS152A
DENON DCD-610/20  KSS210A
DENON DCD-615/25  NKS240A
DENON DCD-635  PCM61P
DENON DCD-650F  PCM1700P
DENON DCD-655  PCM1702
DENON DCD-660  KSS210A
DENON DCD-680  PCM69A
DENON DCD-685  PCM1702
DENON DCD-690  PCM61
DENON DCD-695  PCM61
DENON DCD-700  PCM54HP KSS123A
DENON DCD-715  NKS240A
DENON DCD-725  PCM61P-L
DENON DCD-735  PCM61
DENON DCD-755AR  PCM1702
DENON DCD-800  PCM54 KSS152A
DENON DCD-810  KSS210A
DENON DCD-820  PCM56 KSS210A
DENON DCD-825  NKS240A
DENON DCD-860  KSS210A
DENON DCD-890  PCM61P NKS240A
DENON DCD-895  NKS240A
DENON DCD-900  KSS123A
DENON DCD-910  KSS210A
DENON DCD-920  PCM61 KSS210A
DENON DCD-980  PCM61P NKS240A
DENON DCD-1015  PCM61P NKS240A
DENON DCD-1000  KSS123A
DENON DCD-1100  PCM53JP-VKSS123A
DENON DCD-1290  NKS240A
DENON DCD-1300  KSS123A
DENON DCD-1400  PCM56
DENON DCD-1420  PCM54HP KSS210A
DENON DCD-1450AR  PCM1702
DENON DCD-1500  PCM54HP-K KSS123A
DENON DCD-1500mk2  PCM56 KSS151A
DENON DCD-1520  PCM64 KSS151A
DENON DCD-1530  PCM61
DENON DCD-1550R PCM61
DENON DCD-1550AR  PCM61P
DENON DCD-1560  PCM1701
DENON DCD-1650R  PCM1702
DENON DCD-1700  KSS123A
DENON DCD-1800  PCM53
DENON DCD-2060G/80G  NKS240A
DENON DCD-2560  4x AD1862
DENON DCD-2700  PCM1702J
DENON DCD-S10/3000  PCM1702J
DENON DCD-3300  PCM56P-K KSS123A
DENON DCD-3520  PCM64 KSS151A
DENON DCD-3560  PCM58P-K
DENON DCD-S1  PCM1702
DENON DCM-280  PCM1748
DENON RCD-100  PCM1710
DENON UCD-F10  PCM61
DENON DN-2000F  NKS240A
DIORA CD-502  TDA1543
DUAL CD130  CX20017
DUAL CD20  PCM53
EXPOSURE CD  TDA1545A
EZO FOG STAGE3  AD1853
FISCHER AD935  LC7881 SFP1
FISCHER Z1  PCM58 SFP1
GRUNDIG CD103  LC7881
GRUNDIG CD9000  TDA1541A CDM4.11(£95.00)
HARMAN KARDON HD200  YM3020
HARMAN KARDON HD500  PCM53
HARMAN KARDON HD710 MN6474
HARMAN KARDON HD720  PCM1710
HARMAN KARDON HD730  SAA7350
HARMAN KARDON HD760  PCM1702
HARMAN KARDON HD7225  MN6474
HARMAN KARDON HD7300  PCM61
HARMAN KARDON HD7325  MN6474
HARMAN KARDON HD7400/7500  KSS210A
HARMAN KARDON HD7525  PCM61P
HELIOS MODEL1S  CS4328 (36 bit, ETNA)
HELIOS MODEL2S  CS4328 (36 bit, ETNA)
HELIOS MODEL3S  CS4328 (36 bit, ETNA)
HELIOS STARGATE  CS4328 (36 bit, ETNA)
HEYBROOK SIGNATURE  PCM67
HIGH TECH GOLDLINE CX904  YM3020
JVC XL V22  PCM54 OPTIMA2
JVC XL V221  LC7881 OPTIMA5
JVC XL V250BK  PCM56 OPTIMA2
JVC XL V311BK  MN6471 OPTIMA4S
JVC XL V464  MN35500 OPTIMA6S
JVC XL V1100  PCM54 OPTIMA1
KENWOOD DP47  TD6720N KSS152A
KENWOOD DP87  KSS152A
KENWOOD DP460  TD6709N
KENWOOD DP660SG  KSS152A
KENWOOD DP730  KSS210A
KENWOOD DP850  CX20152
KENWOOD DP920/30/50  KSS210A
KENWOOD DP1030  KSS210A
KENWOOD DP1050  NKS240A
KENWOOD DP1060  RCTRH8136
KENWOOD DP1080  LC78620E
KENWOOD DP1100D  CX20152
KENWOOD DP1510  PCM56 KSS210A
KENWOOD DP2000  CX20152
KENWOOD DP2010  PCM56P KSS210A
KENWOOD DP2030  KSS210A
KENWOOD DP2050  NKS240A
KENWOOD DP2060  RCTRH8136
KENWOOD DP2080  LC78620E (LC78820)
KENWOOD DP3010/30/50  KSS210A
KENWOOD DP3060  NKS240A
KENWOOD DP3080  SM5864
KENWOOD DP4030  KSS210A
KENWOOD DP4090  KAN03
KENWOOD DP5010/30/40  KSS210A
KENWOOD DP5020  PCM1701P KSS210A
KENWOOD DP5090  MN35502 JVC
KENWOOD DP7002  PCM1702
KENWOOD DP7030  CXD2552 KSS210A
KENWOOD DP7040/50  KSS210A
KENWOOD DP7060  TDA1547
KENWOOD DP7090  8x PCM1702
KENWOOD DP8020  KSS152A
KOREA CHINA CD 022  KDA0316LN
KOREA HCD 630 Y3015
KRELL KAV280  PCM1704
LINN GENKI  PCM1723
LUXMAN D 102  TD6709N
LUXMAN D 103  PCM1701
LUXMAN D 112  1x PCM56
LUXMAN D2 92  LC7881
MARANTZ CD7  TDA1541AS2 (double crown)
MARANTZ CD10SAA7310TDA1547 CDM4/D36
MARANTZ CD11LE/II TDA1547 CDM4/D36 HDAM
MARANTZ CD1010/20  CDM12.1
MARANTZ CD14  TDA1547 CDM12.1
MARANTZ CD15  TDA1547 CDM4-MD
MARANTZ CD16DSAA7310TDA1547  HDAM
MARANTZ CD17mkIITDA1370TDA1547(DAC7)VAM1201 NJM2114/HDAM
MARANTZ CD19  SM5872
MARANTZ CD23  CDM9
MARANTZ CD273  CDM2
MARANTZ CD38  TDA1545 CDM12.1
MARANTZ CD385  CDM4
MARANTZ CD40SAA7310 SAA7220 TDA1541/A CDM4/19
MARANTZ CD42 SAA7310SAA7350 ? CDM4//691.30209
MARANTZ CD42 II  CDM4
MARANTZ CD43  SM5872BS CDM12.1/05 NJM4560
MARANTZ CD45  TDA1540 CDM2/29
MARANTZ CD46  CDM12.1
MARANTZ CD48  TDA1545//1549CDM12.1
MARANTZ CD50  TDA1541 CDM4/19
MARANTZ CD52SAA7310 SAA7321GP CDM4
MARANTZ CD52SE SAA7310 SAA7350(Bitstream) CDM4 NE5532
MARANTZ CD53  SM5872BS CDM12.1 NJM2114
MARANTZ CD56 TDA1541 CDM4/25
MARANTZ CD57/57 II  CDM12.1
MARANTZ CD583/93  CDM4/19
MARANTZ CD60 TDA1541 A CDM4/19 NE5534
MARANTZ CD63  SM5872BS CDM12.1 HDAM
MARANTZ CD63II  SM5872 CDM12.1
MARANTZ CD63mkII KI  SM5872 CDM12.1
MARANTZ CD63SE  SM5872BS CDM12.1
MARANTZ CD65 SAA7310TDA1541 CDM4/25
MARANTZ CD65 II SAA7210 SAA7220B TDA1541 ACDM4/19
MARANTZ CD67  SM5872 CDM12.1
MARANTZ CD67SE  SM5872 CDM12.1
MARANTZ CD67II OSE  SM5872 CDM12.1
MARANTZ CD72SAA7310SAA7350(Bitstream) CDM4/19
MARANTZ CD72mkII SE SAA7310TDA1547 CDM 4/28//CDM4/19 HDAM
MARANTZ CD73 SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD74SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD75  CDM4/25
MARANTZ CD75NB  CDM2-160
MARANTZ CD75XNB  691.20464
MARANTZ CD80 TDA1541 CDM1/mkII(CDM4.19) single opamps
MARANTZ CD84 TDA1540 CDM1
MARANTZ CD85  CDM1/mkII
MARANTZ CD94/mkII TDA1541 CDM1
MARANTZ CD873  CDM2-0500//CDM4/11
MARANTZ CD883  CDM4/19
MARANTZ CD4000SAA7378TDA1545VAM1201 NJM4560
MARANTZ CD5000SAA7378TDA1549 VAM1201 NJM4560
MARANTZ CD6000SAA7378SM5872 VAM1201 NJM2114
MARANTZ CD6000KISAA7372SM5872BS VAM1201 HDAM
MARANTZ CD6000OSE SAA73722xSM5872 VAM1201 HDAM
MARANTZ SA-12S1/SA14 CS4397HDAM
MARK LEVINSON N'36  PCM1702 (vagy PCM1704)
MARK LEVINSON No. 390S  AD1853
MERIDIAN 508  CS4329
MICROMEGA LEADER  SAA7321GP
MICROMEGA LOGIC  SAA7321
MICROMEGA PREMIUM18 newCS4327
MICROMEGA STAGE2  SAA7321GP
MICROMEGA STAGE6  TDA1305
MISSION dAC5  TDA1547
MISSION dAD3  TDA1305
MISSION PCM4000  TDA1541
MITSUBISHI DP109  PCM56
MITSUBISHI MC5100  PCM56
MUSICAL FIDELITY x-ray PCM1716NE5532
MUSICAL FIDELITY Tri-Vista PCM1738NE5532
MUSICAL FIDELITY A2 YDC103
MUSICAL FIDELITY DIGILOG  TDA1541
MUSICAL FIDELITY E60  YDC103
MUSICAL FIDELITY E624  PCM1716
MYRYAD T-10  CS4327
MYRYAD T-20  CS4327
MYRYAD MC100  CXD2565
NAD 502  MN6474AM KSS210A
NAD 510  SAA7350 CDM12.1
NAD 515  CDM12.1
NAD 512  MN6474 KSS210A
NAD 522  PCM1710
NAD 5100  PCM56
NAD 5325  LC7881
NAD 5425  MN6471M
NAD C520  PCM1710
NAD S500  CS4390
NAIM AUDIO CD1  TDA1541
NAIM AUDIO CD2  TDA1541
NAIM AUDIO CD3  TDA1541
NAIM AUDIO CD3.5  TDA1305
NAIM AUDIO CD5  TDA1305
NAIM AUDIO CDI  TDA1541AS1 (single crown)
NAIM AUDIO CDS11  PCM1702K
NAKAMICHI CD PLAYER 1  PCM1700P
NAKAMICHI CD PLAYER 4  AD1864N
NAKAMICHI MB 4  LC78840
NAKAMICHI MB 5  LC78840
NAKAMICHI CDP 2E  TDA1541A
NAKAMICHI OMS 1E  PCM56
NAKAMICHI OMS 4E  PCM54
NAKAMICHI OMS 5E  TDA1540
NAKAMICHI OMS 7E  PCM54
NEC CD610  PCM54
ONKYO DX-704  MN6472 (Technics MASH)
ONKYO DX-6430  YM3020
ONKYO DX-6470  PCM56
ONKYO DX-6550 Integra  TC9219 (ONKYO 8D-3170-1)
ONKYO DX-6570  PCM58
ONKYO DX-6620  LC7881
ONKYO DX-7011  TC9237
ONKYO DX-7211  SM5874
ONKYO DX-7500  ONKYO 8S-3380-1
ONKYO DX-7711 Integra  SM5864AP
ONKYO DX-7911 Integra  SM5864AP
ORELLE CD100  TDA1541
PARASOUND CD M839  PCM56
PARASOUND C/DP1000  PCM67
PHILIPS AK601/630/640/729/CCD310/320  CDM4/19
PHILIPS CD-80  TDA1541
PHILIPS CD-85M TDA1541
PHILIPS CD-94M TDA1541
PHILIPS CD-100  TDA1540CDM0
PHILIPS CD-101 TDA1540 CDM1
PHILIPS CD-104  TDA1540 CDM0/CDM1
PHILIPS CD-115/130/140  CDM4/19
PHILIPS CD-150/1  CDM2/29
PHILIPS CD-160  CDM4/25
PHILIPS CD-162/4  CDM4/19
PHILIPS CD-163  CDM12.1/05
PHILIPS CD-200  TDA1540 CDM0
PHILIPS CD-202  TDA1540 CDM0
PHILIPS CD-204  TDA1540 CDM0
PHILIPS CD-210  TDA1543 CDM4/19
PHILIPS CD-210 CDM4/19
PHILIPS CD-300/303 SAA7210 SAA7020 2xTDA1540 CDM1
PHILIPS CD-304 TDA1540 CDM1
PHILIPS CD-304 MkII (alu chassis) SAA7210 SAA7220P/A TDA1541 CDM1
PHILIPS CD-310  CDM4/19
PHILIPS CD-340  CDM4/19
PHILIPS CD-350 TDA1541 CDM2/29
PHILIPS CD-360  CDM2 //CDM4/25
PHILIPS CD-371/3  CDM4/11
PHILIPS CD-380 TDA1543/1/1A CDM4/19
PHILIPS CD-410  CDM12.1/05
PHILIPS CD-460  TDA1541 CDM2 //CDM4/25
PHILIPS CD-465  TDA1541
PHILIPS CD-470
PHILIPS CD-471  TDA1541 CDM4/11
PHILIPS CD-472 TDA1541 CDM4/11
PHILIPS CD-473 TDA1541 CDM4/11
PHILIPS CD-480/2  TDA1543 CDM4/19
PHILIPS CD-500/2  CDM4/19
PHILIPS CD-560  CDM2 //CDM4/25
PHILIPS CD-581/2 TDA1541CDM4/19
PHILIPS CD-583/4  CDM4/19
PHILIPS CD-586  CDM4/19
PHILIPS CD-600/4/5  CDM4/19
PHILIPS CD-610SAA7310 SAA7220P TDA1541CDM4/19
PHILIPS CD-604 TDA1543 CDM4/19
PHILIPS CD-614/15 TDA1543 CDM4/19
PHILIPS CD-618 Bitstream ? CDM4/19
PHILIPS CD-620 TDA1541 ?CDM4/19
PHILIPS CD-621 SAA7345
PHILIPS CD-624 SAA7323 CDM4/19
PHILIPS CD-630SAA7220P/B TDA1541CDM4/19
PHILIPS CD-634 Bitstream ? CDM4/19
PHILIPS CD-640 TDA1541
PHILIPS CD-650SAA7210 SAA7220P/A TDA1541 CDM2/29//CDM4/25
PHILIPS CD-660  CDM4/11
PHILIPS CD-670 SAA7210 SAA7220P/A TDA1541 CDM4/11//(69130212) LM833 slim size,
plastic case, SPDIF
PHILIPS CD-690 Bitstream ? RCD1.2D
PHILIPS CD-692 Bitstream ? CDM9/63
PHILIPS CD-710/720  CDM12.1/05
PHILIPS CD-723SAA7378TDA1545  VAM1201 NJM4560
PHILIPS CD-733/740  CDM12.1/05
PHILIPS CD-751SAA7378TDA1549 CDM12.1/05
PHILIPS CD-750 SAA7378TDA1549 CDM12.1/05
PHILIPS CD-753SAA7378TDA1549  VAM1201 NJM4560
PHILIPS CD-771  CDM2-0500//CDM4/11
PHILIPS CD-780/1  CDM4/19
PHILIPS CD-782 TDA1541 CDM4/19
PHILIPS CD-820SAA7220 TDA1541 A CDM4/19 LM833
PHILIPS CD-830  CDM4/19
PHILIPS CD-824/834  CDM4/19
PHILIPS CD-840 Bitstream CDM4/19
PHILIPS CD-850 TDA1541 CDM4/19 LM833
PHILIPS CD-880  TDA1541 S1CDM1 mkII
PHILIPS CD-882  CDM1 mkII//691.20449
PHILIPS CD-883  CDM4/19
PHILIPS CD-910/11 SAA7341GP(4822-691-20768) CDM12.1/05//RCD1.2D
PHILIPS CD-930/1  TDA1547 CDM9/44
PHILIPS CD-920/1  CDM12.1/05//RCD1.2D
PHILIPS CD-940  CDM9/44
PHILIPS CD-950  TDA1547 CDM9/44
PHILIPS CD-950/1  TDA1547 CDM9/44
PHILIPS CD-960  TDA1541CDM1/mkII ??? NE5534
PHILIPS LHH-100  TDA1547
PHILIPS LHH-500  TDA1547
PHILIPS LHH-600  TDA1547
PHILIPS LHH-800  TDA1547
PHILIPS LHH-1000  TDA1541
PHILIPS MAGNAVOX CDB-560  TDA1541
PHILIPS MAGNAVOX CDB-650  TDA1541PINK TRIANGLE NUMERAL TDA1305T
PIONEER DV-717  PE8001A
PIONEER PD40S  PWY1010
PIONEER PD75  PD2028A
PIONEER PD93  PD2028A
PIONEER PD95  PD2028A
PIONEER PD-102/3  PEA1179
PIONEER PD-202/3  PEA1179
PIONEER PD-204  PD2026B
PIONEER PD-970  PEA1030
PIONEER PD-4050  PWY1010
PIONEER PD-4500  PCM1700 PEA1030
PIONEER PD-4700/5700/6500/67000/7700/8700  PEA1030
PIONEER PD-4550 PCM1700P PEA1030
PIONEER PD-5100  PD0034 PWY1010
PIONEER PD-52  PEA1030
PIONEER PD-5300  PCM56 PWY1010
PIONEER PD-54  PEA1179
PIONEER PD-5500  PEA1030
PIONEER PD-5050  PWY1010
PIONEER PD-5700  PD2026A PEA1030
PIONEER PD-6050/6100/6300  PWY1010
PIONEER PD-65/6500/6700  PEA1030
PIONEER PD-7050  PWY1010
PIONEER PD-7300  PCM58P
PIONEER PD-7300/7500/7700/8700  PEA1030
PIONEER PDR-04  AKM4321
PIONEER PDR-609  PCM1716
PIONEER PDR-W739  PCM1716
PIONEER PDR-W839  PCM1716
PIONEER PDS-06  PCM1702J
PIONEER PD-S303  PEA1030 NJM 4558/4580
PIONEER PD-S501  PEA1030 NJM 4558/4580
PIONEER PD-S502  PD2026B PEA1179 NJM 4558/4580
PIONEER PD-S503  PEA1179 NJM 4558/4580
PIONEER PD-S505  PD2029A PEA1030 NJM 4558/4580
PIONEER PD-S507 CXD2507aq PE8001A  NJM 4558/4580
PIONEER PD-S602/3  PEA1179 NJM 4558/4580
PIONEER PD-S601/701  PEA1030 NJM 4558/4580
PIONEER PD-S702  PEA1179 NJM 4558/4580
PIONEER PD-S703  PD2029A PEA1179 NJM 4558/4580
PIONEER PD-S707  PEA1030 NJM 4558/4580
PIONEER PD-S801  PD2028
PIONEER PD-S802  PD0116A PEA1179
PIONEER PD-S901  PD2028B PEA1030
PIONEER PD-S909/990  PEA1030
PRIMARE D20  AKM4324
PRIMARE D302  4x PCM1702
PROCEED PCD2  PCM58P
PROTON AC423  LC78820
PROTON AC424  TDA1311A
QUAD66 TDA1541A
QUAD77 CS4328
REGA PLANET  PCM1710U
REVOX B225  TDA1540
REVOX B226  TDA1541  NE5534
REVOX C221  SAA7310
ROKSAN ATTESSA DP3P  CS4328
ROKSAN CASPIAN  TDA1305
ROTEL RCD-02  PCM1732
ROTEL DCM-9PRO  PCM63
ROTEL RCD-855  TDA1541 CDM4/19
ROTEL RCD-856BX  SAA7323
ROTEL RCD-865BX  SAA7323
ROTEL RCD-945AX  SAA7341GP T
ROTEL RCD-955  TDA1541
ROTEL RCD-965BX  SAA7323GP T
ROTEL RCD-970BX  TDA1305T
ROTEL RCD-971  PCM63
ROTEL RCD-975  TDA1305T
ROTEL RCD-991  PCM63P
ROTEL RCD-1070  PCM1732
SANSUI CD V1000  PCM56
SANYO CP489  LC7881
SEG CD200  YM3020
SHARP DX112  IR 3K16BM
SHARP DX650  LC7880
SHERWOOD CD1  TDA1547
SHERWOOD CD1060C  D6372 CX
SHERWOOD CD1160R  PCM56
SHERWOOD CD1192R  YM4113B
SHERWOOD CDC2000C  μPD6376
SHERWOOD CDC2010RC  μPD6376
SHERWOOD CD4030R  SAA7350BS
SIMAUDIO MOON ECLIPSE  4x PCM1704K
SONIC FRONTIERS SFCD1 UltraAnalogD20400A
SONY CDP-25/356  KSS120C
SONY CDP-203/30/45/50/55/65/70  KSS121A
SONY CDP-40  1x PCM54
SONY CDP-101  CX20017
SONY CDP-222ES  PCM56P J
SONY CDP-227ESD  TDA1541
SONY CDP-228ESD  PCM58P KSS151A
SONY CDP-302ES  CX20152
SONY CDP-333ESA  CXD2562
SONY CDP-333ESD  TDA1541
SONY CDP-333ESJ  CXD2562
SONY CDP-337ESD  2xTDA1541A
SONY CDP-497  CXD2561
SONY CDP-502  PCM54
SONY CDP-502ES  CX20152
SONY CDP-552  PCM54
SONY CDP-553ESD  PCM53JP-V K
SONY CDP-555ESA  CXD2562
SONY CDP-555ESD  TDA1541A
SONY CDP-555ESJ  CXD2562
SONY CDP-620 CX23034 PCM54
SONY CDP-650  PCM54
SONY CDP-701ES  CX20017
SONY CDP-777ESA  CXD2562Q
SONY CDP-M18 CXD2500Q CXD2554MKSS240A
SONY CDP-MS1  CXD8594 + CXA8042AS
SONY CDP-R3 + DAS-R1a     CXD2552Q + CXD2552
SONY CDP-X229ES  CXD2562Q NKS240A
SONY CDP-X3000  CXD2562Q + CXA8042AS
SONY CDP-X303ES  CXD2562Q
SONY CDP-X5000 CXD2515 CXD2562 + CXA8042
SONY CDP-X505ES  CXD2562Q
SONY CDP-X33ES  CXD2552Q
SONY CDP-X55ES  CXD2552 KSS270A
SONY CDP-X777ES  CXD2552BQ
SONY CDP-X779ES  CXD2562
SONY CDP-X77ES  CXD2552 KSS280A
SONY CDP-X7ESD  PCM58P S KSS190A
SONY CDP-X900  CXA8042
SONY CDP-XA30ES  CXD2562Q + CXA8042AS KSS160B
SONY CDP-XA50ES  CXA8042AS
SONY CDP-XA55ES  CXD8594Q + CXA8042S KSS310A
SONY CDP-XA5ES  CXD2562Q + CXA8042AS
SONY CDP-XA7ES  CXD2562 + CXA8042AS
SONY CDP-XB920  CXD8715 + CXA8355
SONY CDP-XB720E  CXD8735N
SONY CDP-XB930  CXD8735N
SONY CDP-XE300  CXD8567
SONY CDP-XE330  CXD2529Q
SONY CDP-XE900  CXD8505 + CXA8055 KSS213B
SONY DAS-R1  4XTDA1541AS1 (single crown)
SONY CDX11/20/80/5B  KSS160B
SONY CDXA15/20/30  KSS160B
SOUND WAVE CD1100  LC7881
SUDGEN OPTIMA  TDA1543
SUDGEN SDA-1  TDA1541
SUDGEN SDT-1  TDA1541AS1 (single crown)
T+A CD1210R  SM5864AP
TAG McLAREN CD20R  CS4329
TALK ELECTRONICS THUNDER 3 CS4390
TASCAM CD201  MN6474
TEAC PD155mk2  Y3015
TEAC PD160  TC9218F 9A01026600
TEAC CPD3450SE YDC103LSI  OPAxx
TEAC CPD3100/4100  KSS210A
TEAC PD365 YM7121B
TEAC VRDS 7  TDA1547
TEAC VRDS 8  PCM1702
TEAC VRDS 9  PCM1702
TEAC VRDS 10SE  TDA1547
TEAC VRDS 25  AD1862J
TEAC ZD5000  PCM53
TECHNICS SL-P1  PCM53
TECHNICS SL-P2  PCM53
TECHNICS SL-P110  PCM54HP
TECHNICS SL-P120K E  PCM54HP
TECHNICS SL-P272A  MN6474
TECHNICS SL-P202/212/222  CDM4/19
TECHNICS SL-P177/277/377/477 A  CDM4/19
TECHNICS SL-P1200  PCM54HP
TECHNICS SL-P360/70/460/70/570  CDM12.1/05
TECHNICS SL-PG480A  MN662713 CDM12.1/05
TECHNICS SL-PG100/200/400/420/440/500/520/540  CDM4/19
TECHNICS SL-PJ28A  MN6477 CDM4/19
TECHNICS SL-PJ24/26/27/28/37/325/46  CDM4/19
TECHNICS SL-PS620  CDM4/19
TECHNICS SL-PS670D  MN6474 CDM12.1/05
TECHNICS SL-PS700  MN6474 SOAD70A
TECHNICS SL-PS740A CDM4/19
TECHNICS SL-PS770A  MN6473 CDM12.1/05
TECHNICS SL-PS840/900A SOAD70A
THETA DSP  PCM67
THOMSON LAD300  TD6720N
THULE CD100  CS4303
THULE SPIRIT  PCM1715U
TOSHIBA XR40  TD6705AP
UHER UCD-210 LC7882
UNIVERSUM CD4682  PCM56
USHER CD-100  PCM1732
WADIA 850  PCM1702
WADIA 860  4x PCM1702
WADIA 861  4x PCM1704
YAMAHA CD-2  PCM53
YAMAHA CD-3  PCM53
YAMAHA CD-2000  PCM54HP
YAMAHA CDX-3 PCM54
YAMAHA CDX-410  PCM56
YAMAHA CDX-420  PCM56
YAMAHA CDX-450  KSS210A
YAMAHA CDX-470  YDC103 KSS210A
YAMAHA CDX-480  MN66271 KSS210A
YAMAHA CDX-490  MN66271R
YAMAHA CDX-580  YAC514 KSS210A
YAMAHA CDX-590  YAC514
YAMAHA CDX-593  YAC514
YAMAHA CDX-700  PCM56
YAMAHA CDX-750/860  KSS210A
YAMAHA CDX-880  YAC514 KSS210A
YAMAHA CDX-900  PCM56
YAMAHA CDX-890  YAC514
YAMAHA CDX-893  YAC514
YAMAHA CDX-993  YAC514F
YAMAHA CDX-1100  PCM56
YAMAHA CDX-2020  PCM58
GMT+8, 2026-4-25 04:25 , 耗时 0.135375 秒, 19 个查询请求 , Gzip 开启.
