查看: 209|回复: 0
基于ADS1298设计的8路24位精度心电图(ECG)前端技术
发表于 2012-1-16 16:26:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADS1298集成了心电图(ECG)前端的8路24位精度delta-sigma (ΔΣ)模/数转换器,具有同时取样和内置的可编增益放大器(PGA),基准电压和振荡器,包含了医疗心电图(ECG)和脑电图(EEG)所有的功能.本文介绍了ADS1298主要特性和优势,功能方框图,以及每路输入复接器方框图,单电源连接框图, 双电源连接框图与心电图(ECG)总体方框图.8-Channel, 24-bit Analog-To-Digital Converter With Integrated ECG Front EndThe ADS1294/6/8 are a family of multichannel, simultaneous sampling, 24-bit, delta-sigma (ΔΣ) analog-to-digital converters (ADCs) with a built-in programmable gain amplifier (PGA), internal reference, and an onboard oscillator. The ADS1294/6/8 incorporate all of the features that are commonly required in medical electrocardiogram (ECG) and electroencephalogram (EEG) applications.ADS1298主要特性和优势:Simplifies design and saves board space, using up to 95 percent fewer components, by integrating all common features required for ECG and EEG front ends, including the following: eight low-noise programmable gain amplifiers (PGAs). eight high-resolution, simultaneous sampling analog-to-digital converters (ADCs). integrated amplifier for right-leg drive. integrated amplifiers for Wilson Central Terminal (WCT) and Goldberger Terminals (GCT). digital pace detection capability. continuous lead-off detection. onboard oscillator and reference for smaller footprint and low-power applications. Power consumption of 1 mW/channel results in up to 95 percent less power use than discrete implementations, increasing equipment portability and improving patient mobility. The ADS1298’s 4-uVpp (typical) input-referred noise is far superior to the limits set in IEC60601-2-27/51, for more accurate measurements in portable equipment and high channel-density, high-end ECG and EEG equipment. Complementing the analog front end’s leading power consumption is the low-power TMS320C5505 DSP family. At less than 0.15-mW/MHz power consumption, the TMS320C5505 maximizes battery life for portable patient monitoring applications. Together with TI’s full portfolio of analog signal chain and power management solutions, these devices offer customers a complete signal chain for ECG and EEG applications to speed their time to market. ADS1298应用:? Medical Instrumentation (ECG and EEG) including:– Patient monitoring; Holter, event, stress, and vital signs ECG, AED, telemedicine,fetal ECG– bispectral index (bIS), Evoked audio potential (EAP), Sleep study monitor? High-Precision, Simultaneous, Multichannel Signal Acquisition
图1.ADS1298功能方框图
图2.ADS1298每路输入复接器方框图
a)标准配置???????? ??????????????????b) DAISY_IN 配置
                                图3.多个器件配置图
图4.ADS1298单电源连接框图
图5.ADS1298双电源连接框图
图6.心电图(ECG)方框图
GMT+8, 2026-4-25 07:19 , 耗时 0.104939 秒, 18 个查询请求 , Gzip 开启.
