查看: 1655|回复: 0
[接口电路] CAN总线控制器IP核代码分析
发表于 2012-1-16 16:38:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
include "timescale.v"
// synopsys translate_on
`include "can_defines.v"
module can_top
? `ifdef CAN_WISHBONE_IF
??? wb_clk_i,
??? wb_rst_i,
??? wb_dat_i,
??? wb_dat_o,
??? wb_cyc_i,
??? wb_stb_i,
??? wb_we_i,
??? wb_adr_i,
??? wb_ack_o,
? `else
??? rst_i,
??? ale_i,
??? rd_i,
??? wr_i,
??? port_0_io,
? `endif
? cs_can_i,
? clk_i,
? rx_i,
? tx_o,
? irq_on,
? clkout_o
parameter Tp = 1;
? input??????? wb_clk_i;
? input??????? wb_rst_i;
? input? [7:0] wb_dat_i;
? output [7:0] wb_dat_o;
? input??????? wb_cyc_i;
? input??????? wb_stb_i;
? input??????? wb_we_i;
? input? [7:0] wb_adr_i;
? output?????? wb_ack_o;
? reg????????? wb_ack_o;
? reg????????? cs_sync1;
? reg????????? cs_sync2;
? reg????????? cs_sync3;
? reg????????? cs_ack1;
? reg????????? cs_ack2;
? reg????????? cs_ack3;
? reg????????? cs_sync_rst1;
? reg????????? cs_sync_rst2;
`else
? input??????? rst_i;
? input??????? ale_i;
? input???? ???rd_i;
? input??????? wr_i;
? inout? [7:0] port_0_io;
? reg??? [7:0] addr_latched;
? reg????????? wr_i_q;
? reg????????? rd_i_q;
`endif
input??????? cs_can_i;
input??????? clk_i;
input??????? rx_i;
output?????? tx_o;
output?????? irq_on;
output?????? clkout_o;
reg????????? data_out_fifo_selected;
wire???????? irq_o;
wire?? [7:0] data_out_fifo;
wire?? [7:0] data_out_regs;
/* Mode register */
wire???????? reset_mode;
wire???????? listen_only_mode;
wire???????? acceptance_filter_mode;
wire???????? self_test_mode;
/* Command register */
wire???????? release_buffer;
wire???????? tx_request;
wire???????? abort_tx;
wire???????? self_rx_request;
wire???????? single_shot_transmission;
/* Arbitration Lost Capture Register */
wire???????? read_arbitration_lost_capture_reg;
/* Error Code Capture Register */
wire???????? read_error_code_capture_reg;
wire?? [7:0] error_capture_code;
/* Bus Timing 0 register */
wire?? [5:0] baud_r_presc;
wire?? [1:0] sync_jump_width;
/* Bus Timing 1 register */
wire?? [3:0] time_segment1;
wire?? [2:0] time_segment2;
wire???????? triple_sampling;
/* Error Warning Limit register */
wire?? [7:0] error_warning_limit;
/* Rx Error Counter register */
wire???????? we_rx_err_cnt;
/* Tx Error Counter register */
wire???????? we_tx_err_cnt;
/* Clock Divider register */
wire???????? extended_mode;
/* This section is for BASIC and EXTENDED mode */
/* Acceptance code register */
wire?? [7:0] acceptance_code_0;
/* Acceptance mask register */
wire?? [7:0] acceptance_mask_0;
/* End: This section is for BASIC and EXTENDED mode */
/* This section is for EXTENDED mode */
wire?? [7:0] acceptance_code_1;
wire?? [7:0] acceptance_code_2;
wire?? [7:0] acceptance_code_3;
wire?? [7:0] acceptance_mask_1;
wire?? [7:0] acceptance_mask_2;
wire?? [7:0] acceptance_mask_3;
/* End: This section is for EXTENDED mode */
/* Tx data registers. Holding identifier (basic mode), tx frame information (extended mode) and data */
wire?? [7:0] tx_data_0;
wire?? [7:0] tx_data_1;
wire?? [7:0] tx_data_2;
wire?? [7:0] tx_data_3;
wire?? [7:0] tx_data_4;
wire?? [7:0] tx_data_5;
wire?? [7:0] tx_data_6;
wire?? [7:0] tx_data_7;
wire?? [7:0] tx_data_8;
wire?? [7:0] tx_data_9;
wire?? [7:0] tx_data_10;
wire?? [7:0] tx_data_11;
wire?? [7:0] tx_data_12;
/* End: Tx data registers */
wire???????? cs;
/* Output signals from can_btl module */
wire???????? clk_en;
wire???????? sample_point;
wire???????? sampled_bit;
wire???????? sampled_bit_q;
wire???????? tx_point;
wire???????? hard_sync;
wire???????? resync;
/* output from can_bsp module */
wire???????? rx_idle;
wire???????? transmitting;
wire???????? last_bit_of_inter;
wire???????? set_reset_mode;
wire???????? node_bus_off;
wire???????? error_status;
wire?? [7:0] rx_err_cnt;
wire?? [7:0] tx_err_cnt;
wire???????? rx_err_cnt_dummy;? // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
wire???????? tx_err_cnt_dummy;? // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
wire???????? transmit_status;
wire???????? receive_status;
wire???????? tx_successful;
wire???????? need_to_tx;
wire???????? overrun;
wire???????? info_empty;
wire???????? set_bus_error_irq;
wire???????? set_arbitration_lost_irq;
wire?? [4:0] arbitration_lost_capture;
wire???????? node_error_passive;
wire???????? node_error_active;
wire?? [6:0] rx_message_counter;
wire???????? tx_out;
wire???????? tx_oen;
wire???????? rst;
wire???????? we;
wire?? [7:0] addr;
wire?? [7:0] data_in;
reg??? [7:0] data_out;
/* Connecting can_registers module */
can_registers i_can_registers
? .clk(clk_i),
? .rst(rst),
? .cs(cs),
? .we(we),
? .addr(addr),
? .data_in(data_in),
? .data_out(data_out_regs),
? .irq(irq_o),
? .sample_point(sample_point),
? .transmitting(transmitting),
? .set_reset_mode(set_reset_mode),
? .node_bus_off(node_bus_off),
? .error_status(error_status),
? .rx_err_cnt(rx_err_cnt),
? .tx_err_cnt(tx_err_cnt),
? .transmit_status(transmit_status),
? .receive_status(receive_status),
? .tx_successful(tx_successful),
? .need_to_tx(need_to_tx),
? .overrun(overrun),
? .info_empty(info_empty),
? .set_bus_error_irq(set_bus_error_irq),
? .set_arbitration_lost_irq(set_arbitration_lost_irq),
? .arbitration_lost_capture(arbitration_lost_capture),
? .node_error_passive(node_error_passive),
? .node_error_active(node_error_active),
? .rx_message_counter(rx_message_counter),
? /* Mode register */
? .reset_mode(reset_mode),
? .listen_only_mode(listen_only_mode),
? .acceptance_filter_mode(acceptance_filter_mode),
? .self_test_mode(self_test_mode),
? /* Command register */
? .clear_data_overrun(),
? .release_buffer(release_buffer),
? .abort_tx(abort_tx),
? .tx_request(tx_request),
? .self_rx_request(self_rx_request),
? .single_shot_transmission(single_shot_transmission),
? /* Arbitration Lost Capture Register */
? .read_arbitration_lost_capture_reg(read_arbitration_lost_capture_reg),
? /* Error Code Capture Register */
? .read_error_code_capture_reg(read_error_code_capture_reg),
? .error_capture_code(error_capture_code),
? /* Bus Timing 0 register */
? .baud_r_presc(baud_r_presc),
? .sync_jump_width(sync_jump_width),
? /* Bus Timing 1 register */
? .time_segment1(time_segment1),
? .time_segment2(time_segment2),
? .triple_sampling(triple_sampling),
? /* Error Warning Limit register */
? .error_warning_limit(error_warning_limit),
? /* Rx Error Counter register */
? .we_rx_err_cnt(we_rx_err_cnt),
? /* Tx Error Counter register */
? .we_tx_err_cnt(we_tx_err_cnt),
? /* Clock Divider register */
? .extended_mode(extended_mode),
? .clkout(clkout_o),
? /* This section is for BASIC and EXTENDED mode */
? /* Acceptance code register */
? .acceptance_code_0(acceptance_code_0),
? /* Acceptance mask register */
? .acceptance_mask_0(acceptance_mask_0),
? /* End: This section is for BASIC and EXTENDED mode */
? /* This section is for EXTENDED mode */
? .acceptance_code_1(acceptance_code_1),
? .acceptance_code_2(acceptance_code_2),
? .acceptance_code_3(acceptance_code_3),
? .acceptance_mask_1(acceptance_mask_1),
? .acceptance_mask_2(acceptance_mask_2),
? .acceptance_mask_3(acceptance_mask_3),
? /* End: This section is for EXTENDED mode */
? /* Tx data registers. Holding identifier (basic mode), tx frame information (extended mode) and data */
? .tx_data_0(tx_data_0),
? .tx_data_1(tx_data_1),
? .tx_data_2(tx_data_2),
? .tx_data_3(tx_data_3),
? .tx_data_4(tx_data_4),
? .tx_data_5(tx_data_5),
? .tx_data_6(tx_data_6),
? .tx_data_7(tx_data_7),
? .tx_data_8(tx_data_8),
? .tx_data_9(tx_data_9),
? .tx_data_10(tx_data_10),
? .tx_data_11(tx_data_11),
? .tx_data_12(tx_data_12)
? /* End: Tx data registers */
assign irq_on = "irq_o;
/* Connecting can_btl module */
can_btl i_can_btl
? .clk(clk_i),
? .rst(rst),
? .rx(rx_i),
? /* Output signals from this module */
? .clk_en(clk_en),
? .sampled_bit(sampled_bit),
? .sampled_bit_q(sampled_bit_q),
? .tx_point(tx_point),
? .hard_sync(hard_sync),
? .resync(resync),
? /* output from can_bsp module */
? .rx_idle(rx_idle),
? .last_bit_of_inter(last_bit_of_inter)
can_bsp i_can_bsp
? .clk(clk_i),
? .rst(rst),
? /* From btl module */
? .addr(addr),
? .data_out(data_out_fifo),
? .fifo_selected(data_out_fifo_selected),
                                /* Mode register */
? .last_bit_of_inter(last_bit_of_inter),
? .rx_err_cnt({rx_err_cnt_dummy, rx_err_cnt[7:0]}),?? // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
? .tx_err_cnt({tx_err_cnt_dummy, tx_err_cnt[7:0]}),?? // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
? .tx_data_12(tx_data_12),
? /* Tx signal */
? .tx(tx_out),
? .tx_oen(tx_oen)
assign tx_o = tx_oen? 1'bz : tx_out;
// Multiplexing wb_dat_o from registers and rx fifo
always @ (extended_mode or addr or reset_mode)
begin
? if (extended_mode & ("reset_mode) & ((addr >= 8'd16) && (addr = 8'd20) && (addr <= 8'd29)))
??? data_out_fifo_selected <= 1'b1;
? else
??? data_out_fifo_selected <= 1'b0;
end
always @ (posedge clk_i)
begin
//? if (wb_cyc_i & ("wb_we_i))
? if (cs & ("we))
??? begin
????? if (data_out_fifo_selected)
??????? data_out <=#Tp data_out_fifo;
????? else
??????? data_out <=#Tp data_out_regs;
??? end
end
? // Combining wb_cyc_i and wb_stb_i signals to cs signal. Than synchronizing to clk_i clock domain.
? always @ (posedge clk_i or posedge rst)
? begin
??? if (rst)
????? begin
??????? cs_sync1???? <= 1'b0;
??????? cs_sync2???? <= 1'b0;
??????? cs_sync3???? <= 1'b0;
??????? cs_sync_rst1 <= 1'b0;
??????? cs_sync_rst2 <= 1'b0;
????? end
??? else
????? begin
??????? cs_sync1???? <=#Tp wb_cyc_i & wb_stb_i & ("cs_sync_rst2) & cs_can_i;
??????? cs_sync2???? <=#Tp cs_sync1?????????? ?& ("cs_sync_rst2);
??????? cs_sync3???? <=#Tp cs_sync2??????????? & ("cs_sync_rst2);
??????? cs_sync_rst1 <=#Tp cs_ack3;
??????? cs_sync_rst2 <=#Tp cs_sync_rst1;
????? end
? end
? assign cs = cs_sync2 & ("cs_sync3);
? always @ (posedge wb_clk_i)
? begin
??? cs_ack1 <=#Tp cs_sync3;
??? cs_ack2 <=#Tp cs_ack1;
??? cs_ack3 <=#Tp cs_ack2;
? end
? // Generating acknowledge signal
? begin
??? wb_ack_o <=#Tp (cs_ack2 & ("cs_ack3));
? end
? assign rst????? = wb_rst_i;
? assign we?????? = wb_we_i;
? assign addr???? = wb_adr_i;
? assign data_in? = wb_dat_i;
? assign wb_dat_o = data_out;
`else
? // Latching address
? always @ (negedge clk_i or posedge rst)
? begin
??? if (rst)
????? addr_latched <= 8'h0;
??? else if (ale_i)
????? addr_latched <=#Tp port_0_io;
? end
? // Generating delayed wr_i and rd_i signals
? begin
??? if (rst)
????? begin
??????? wr_i_q <= 1'b0;
??? ????rd_i_q <= 1'b0;
????? end
??? else
????? begin
??????? wr_i_q <=#Tp wr_i;
??????? rd_i_q <=#Tp rd_i;
????? end
? end
? assign cs = ((wr_i & ("wr_i_q)) | (rd_i & ("rd_i_q))) & cs_can_i;
? assign rst?????? = rst_i;
? assign we??????? = wr_i;
? assign addr????? = addr_latched;
? assign data_in?? = port_0_io;
? assign port_0_io = (cs_can_i & rd_i)? data_out : 8'hz;
`endif
endmodule
GMT+8, 2026-4-4 04:31 , 耗时 0.098944 秒, 18 个查询请求 , Gzip 开启.
