查看: 162|回复: 0
单片机应用实例:LED显示电脑电子钟
发表于 2012-1-16 17:29:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                      本例介绍一种用LED制作的电脑电子钟(电脑万年历)。其制作完成装潢后的照片如下图:
  上图中,CPU选用的是AT89C2051,时钟芯片选用的是Dallas公司的DS1302,温度传感器选用的是Dallas公司的数字温度传感器DS1820,显示驱动芯片选用的是德州仪器公司的TPIC6B595,也可选用与其兼容的芯片NC595或国产的AMT9595。整个电子钟用两个键来调节时间和日期。一个是位选键,一个是数字调节键。按一下位选键,头两位数字开始闪动,进入设定调节状态,此时按数字调节键,当前闪动位的数字就可改变。全部参数调节完后,五秒钟内没有任何键按下,则数字停止闪动,退出设定调节状态。
  源程序清单如下(无温度显示程序):
  STart:do;
  $include(reg51.dcl)
  declare (sclk,io,rst) bit at (0b3h) register; /* p33,p34,p35 */
  declare (command,data,n,temp1,num) byte;
  declare a(9) byte;
  declare ab(6) byte;
  declare aco(11) byte cONstant (0fdh,60h,0dah,0f2h,66h,0b6h,0beh,
  0e0h,0feh,0f6h,00h);
  declare week(11) byte constant (0edh,028h,0dch,7ch,39h,75h,0f5h,
  2ch,0fdh,7dh,00h);
  declare da literally 'p15',clk literally 'p16',ale literally 'p17',
  mk literally 'p11',sk literally 'p12';
  clear:procedure;
  sclk=0;io=0;rst=0;
  end clear;
  send1302:procedure(comm);
  declare (i,comm) byte;
  do i=0 to 7;
  comm=scr(comm,1);
  io=cy;
  call TIme(1);
  sclk=0;
  call time(1);
  sclk=1;
  end;
  end send1302;
  wbyt1:procedure(com,dat);/*字节写过程*/
  declare (com,dat) byte;
  call clear;
  rst=1;
  call send1302(com);
  call send1302(dat);
  call clear;
  end wbyt1;
  wbyt8:procedure;/*时钟多字节突发模式写过程*/
  declare j byte;
  call clear;
  a(7)=A(6);a(6)=a(0);
  rst=1;
  call send1302(command);
  do j=1 to 8;
  call send1302(a(j));
  end;
  call clear;
  end wbyt8;
  RBYT1ROCEDURE;
  DECLARE I BYTE;
  CALL CLEAR;
  RST=1;
  call send1302(0c1h);
  IO=1;
  DO I=0 TO 7;
  SCLK=1;
  SCLK=0;
  CY=IO;
  N=SCR(N,1);
  END;
  A(8)=N;
  CALL CLEAR;
  END RBYT1;
  send595:procedure;
  declare k byte;
  do k=0 to 7;
  data=scr(data,1);
  da=cy;
  clk=1;
  clk=0;
  end;
  end send595;
  send595_1:procedure;
  declare k byte;
  do k=0 to 7;
  data=scr(data,1);
  da1=cy;
  clk1=1;
  clk1=0;
  end;
  end send595_1;
  rb1:procedure(abc,j);
  DECLARE (I,j,abc) BYTE;
  CALL CLEAR;
  RST=1;
  call send1302(abc);
  IO=1;
  DO I=0 TO 7;
  SCLK=1;
  SCLK=0;
  CY=IO;
  N=SCR(N,1);
  END;
  ab(j)=N;
  ab(j)=dec(ab(j));
  CALL CLEAR;
  end rb1;
  rbyt6:procedure;
  call rb1(0f1h,0);
  call rb1(0f3h,1);
  call rb1(0f5h,2);
  call rb1(0f7h,3);
  call rb1(0f9h,4);
  call rb1(0fbh,5);
  call rb1(0fdh,6);
  end rbyt6;
  wbyt6:procedure;
  call wbyt1(8eh,0);? /* write enable */
  call wbyt1(0f0h,ab(0));
  call wbyt1(0f2h,ab(1));
  call wbyt1(0f4h,ab(2));
  call wbyt1(0f6h,ab(3));
  call wbyt1(0f8h,ab(4));
  call wbyt1(0fah,ab(5));
  call wbyt1(0fch,ab(6));
  call wbyt1(8eh,80h);? /* write disable */
  end wbyt6;
  rbyt8:procedure;/*时钟多字节突发模式读过程*/
  declare (i,j) byte;
  call clear;
  rst=1;
  io=1;
  do j=1 to 8;
  do i=0 to 7;
  sclk=1;
  call time(1);
  sclk=0;
  cy=io;
  n=scr(n,1);
  end;
  a(j)=n;
  end;
  call clear;
  a(0)=a(6);a(6)=A(7);
  a(0)=a(0) and 0fh;
  if a(0)>6 then a(0)=0;
  CALL RBYT1;
  if (a(1)=0 and a(2)=0 and a(3)=0) then
  do;
  do num=0 to 35;
  call time(250);
  end;
  temp1=1;
  end;
  if temp1=1 then
  do;
  temp1=0;
  ab(4)=ab(4)+1;
  if ab(4)>99h then
  do;
  ab(4)=0;
  ab(5)=ab(5)+1;
  if ab(5)>99h then ab(5)=0;
  end;
  call wbyt6;
  end;
  end rbyt8;
  display:procedure;? /*jieya,yima,fasong*/
  declare (i,n,m) byte;
  n=a(0) and 0fh; /* send week */
  data=week(n);
  call send595;
  n=a(4);????????? /* send date */
  n=n and 0fh;
  data=aco(n);
  call send595;
  n=a(4);
  n=shr(n,4);
  data=aco(n);
  call send595;
  do i=1 to 3;???? /* send second,minute,hour */
  n=a(i);
  n=n and 0fh;
  data=aco(n);
  call send595;
  n=a(i);
  n=shr(n,4);
  data=aco(n);
  call send595;
  end;
  do i=5 to 6;???? /* send month,year */
  n=a(i);
  n=n and 0fh;
  data=aco(n);
  call send595;
  n=a(i);
  n=shr(n,4);
  data=aco(n);
  call send595;
  end;
  n=a(8);???????? /*? send 19 or 20 */
  n=n and 0fh;
  data=aco(n);
  call send595;
  n=a(8);
  n=shr(n,4);
  data=aco(n);
  call send595;
  do m=0 to 5;
  n=ab(m);
  n=n and 0fh;
  data=aco(n);
  call send595_1;
  n=ab(m);
  n=shr(n,4);
  data=aco(n);
  call send595_1;
  end;
  ale=0;
  ale=1;
  end display;
  beginset:procedure;
  a(0)=06h;a(1)=58h;a(2)=59h;a(3)=23h;
  a(4)=30h;a(5)=06h;a(6)=97h;a(7)=00;
  a(8)=19h;?? /* set date/time (1997,7,1,8:00:00,week 3) */
  call wbyt1(8eh,0); /* write enable*/
  call wbyt1(80h,00h);/* start colock */
  call wbyt1(0beh,0abh);/*两个二极管与8K电阻串联充电*/
  command=0beh;? /* write colock/date */
  call wbyt8;
  call wbyt1(0c0h,a(8));
  call wbyt1(8eh,80h);? /* set write protect bit */
  end beginset;
  key:procedure;
  declare (i,time1,k1,tem) byte;
  call time(100);
  k1=7;time1=30;
  if mk=0 then
  do;
  do while time1>0;
  week:?????? if k1=0 then
  do;
  do i=0 to 5;
  /*??? call hz(a(0));? */
  end;
  do i=0 to 3;
  /*??? call hz0;? */
  end;
  end;
  tem=a(k1);
  if k1=7 then tem=a(8);
  a(k1)=0aah;
  if k1=7 then a(8)=0aah;
  call display;
  call time(254);
  call time (254);
  a(k1)=tem;
  if k1=7 then a(8)=tem;
  call display;
  call time(254);
  call time(254);
  call time(254);
  time1=time1-1;
  if mk=0 then
  do;call time(100); /*MOD KEY PROCESS*/
  TIME1=30;
  IF MK=0 THEN
  DO;
  k1=k1-1;
  DO WHILE K1=0FFH;
  K1=7;
  END;
  END;
  end;
  IF SK=0 THEN
  DO;CALL TIME(100);? /*SET KEY PROCESS*/
  TIME1=30;
  IF SK=0 THEN
  DO;
  tem=tem+1;
  tem=dec(tem);
  DO CASE K1;
  DO WHILE tem=7;/*week*/
  tem=0;
  END;
  DO WHILE tem=60H;/*scond*/
  tem=0;
  END;
  DO WHILE tem=60H;/*minute*/
  tem=0;
  END;
  DO WHILE tem=24H;/*hour*/
  tem=0;
  END;
  DO WHILE tem=32H;/*date*/
  tem=1;
  END;
  DO WHILE tem=13H;/*month*/
  tem=1;
  END;
  DO while tem=100h;?? /*? YEAR */
  tem=00;
  END;
  DO WHILE TEM>=21H;
  tem=19H;
  END;
  END;
  A(K1)=tem;
  END;
  END;
  END;
  END;
  end key;
  main$program:
  mk=1;sk=1;temp1=0;num=0;p32=1;
  if sk=0 then call beginset;
  clk=0;da=0;ale=1;
  loop:
  do while mk=1 ;
  command=0bfh;
  call rbyt8;
  call display;
  do while mk=0;
  call key;
  call wbyt1(8eh,0);
  command=0beh;
  call wbyt8;
  call wbyt1(0C0H,A(8));
  end;
  end;
  goto loop;
  end start;
GMT+8, 2026-4-6 16:25 , 耗时 0.464405 秒, 18 个查询请求 , Gzip 开启.
