查看: 199|回复: 0
ARM Linux静态映射分析
发表于 2012-1-16 18:42:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                      作者:易松华,华清远见嵌入式学院讲师。
  在华清远见上课过程中,发现静态映射方面初学者比较难于掌握和理解,下面分析一下静态映射机制的原理并通过GPIO和USB、LCD等的静态映射作为例子来说明如何通过这种静态映射的方式访问外设资源。
  内核提供了一个重要的结构体STruct machine_desc ,这个结构体在内核移植中起到相当重要的作用,内核通过machine_desc结构体来控制系统体系架构相关部分的初始化。machine_desc结构体的成员包含了体系架构相关部分的几个最重要的初始化函数,包括map_io,init_IRq, init_machine以及phys_io , TImer成员等。
  machine_desc结构体定义如下:
  struct machine_desc {
  * Note! The first four elements are used
  * by assembler code in head-armv.S
  unsigned int????????????????? nr;???????? /* architecture number???????? */
  unsigned int????????????????? phys_io;????????? /* start of physical io???????? */
  unsigned int????????????????? io_pg_offst; /* byte offset for io
  * page tabe entry???????? */
  cONst char???????????????? *name;????????? /* architecture nAME????????? */
  unsigned long???????????????????? ;boot_params;????????? /* tagged list????????? */
  unsigned int????????????????? video_start;???????? /* start of video RAM????????? */
  unsigned int????????????????? video_end;???????? /* end of video RAM????????? */
  unsigned int???????????????? reserve_lp0 :1;????????? /* never has lp0????????? */
  unsigned int???????????????? reserve_lp1 :1;????????? /* never has lp1????????? */
  unsigned int????????????????? reserve_lp2 :1;????????? /* never has lp2????????? */
  unsigned int????????????????? soft_reboot :1;????????? /* soft reboot????????? */
  void????????????????????????? (*fixup)(struct machine_desc *,
  struct tag *, char **,
  struct meminfo *);
  void???????????????????????? (*map_io)(void);/* IO mapping function????????? */
  void???????????????????????? (*init_irq)(void);
  struct sys_timer????????? *timer;????????? /* system tick timer????????? */
  void???????????????????????? (*init_machine)(void);
  machine_desc结构体通过MACHINE_START宏来初始化,这里以s3c2410平台为例:
  s3c2410 machine_desc结构体定义如下:
  /* arch/arm/mach-s3c2410/mach-SMDk2410.c */
  MACHINE_START(smdK2410, "SMDK2410") /* @TODO: request a new identifier and switch
  * to SMDK2410 */
  /* Maintainer: Jonas Dietsche */
  .phys_io = S3C2410_PA_UART,
  .io_pg_offst = (((u32)S3C24XX_VA_UART) >> 18) & 0xfffc,
  .boot_params = S3C2410_SDRAM_PA + 0x100,
  .map_io = smdk2410_map_io,
  .init_irq = s3c24xx_init_irq,
  .init_machine = smdk2410_init,
  .timer = &s3c24xx_timer,
  MACHINE_END
  其中的宏MACHINE_START和MACHINE_END定义如下:
  * Set of macros to define architecture features. This is built into
  * a table by the linker.
  #define MACHINE_START(_type,_name) \
  const struct machine_desc __mach_desc_##_type \
  __attribute__((__section__(".arch.info.init"))) = { \
  .nr = MACH_TYPE_##_type, \
  .name = _name,
  #define MACHINE_END \
  其中MACH_TYPE_##_type 为GCC扩展语法中的字符拼接标识,在预编译的时候会用真正的字符代替,比如我们这里就是MACH_TYPE_SMDK2410
  MACHINE_START的使用及各个成员函数的的放置位置以及调用过程如下:
  MACH_TYPE_SMDK2410这个值是目标板的类型值,定义在arch/include/asm-arm/mach-types.h内,值为193.
  /* arch/include/asm-arm/mach-types.h */
  #define MACH_TYPE_SMDK2410 193
  由上发现,MACHINE_START主要是定义了"struct machine_desc"的类型,放在 section(".arch.info.init"),是初始化数据,其所占用的内存在内核起来之后将会被释放。
  这里的map_io成员即内核提供给用户的创建外设I/O资源到内核虚拟地址静态映射表的接口函数。map_io成员函数会在系统初始化过程中被调用,流程如下:
  start_kernel -> setup_arch() --> paging_init()中被调用
  struct machine_desc 结构体的各个成员函数在不同时期被调用:
  1. .init_machine 在 arch/arm/kernel/setup.c 中被 customize_machine 调用,放在 arch_initcall( ) 段里面,会自动按顺序被调用(另外博客分析,敬请关注)。
  2. init_irq在start_kernel( ) --> init_IRQ( ) --> init_arch_irq( ) 被调用
  3. map_io 在 setup_arch( ) --> paging_init( )被调用
  其他主要都在 setup_arch() 中用到。
  用户可以在定义machine_desc结构体时指定map_io的接口函数,我们也正是这样做的。
  接下来我们继续分析smdk2410_map_io的执行过程,流程如下:
  smdk2410_map_io-> s3c24xx_init_io(smdk2410_iodesc, ARRAY_SIZE(smdk2410_iodesc))
  下面来看一下s3c24xx_init_io函数:
  void __init s3c24xx_init_io(struct map_desc *mach_desc, int mach_size)
  /* register our io-tables */
  iotable_init(s3c_iodesc, ARRAY_SIZE(s3c_iodesc));
  iotable_init内核提供,定义如下:
  * Create the architecture specific mappings
  void __init iotable_init(struct map_desc *io_desc, int nr)
  int i;
  for (i = 0; i nr; i++)
  create_mapping(io_desc + i);
  由上知道,smdk2410_map_io最终调用iotable_init建立映射表。
  iotable_init函数的参数有两个:一个是map_desc类型的结构体,另一个是该结构体的数量nr。这里最关键的就是struct map_desc。map_desc结构体定义如下:
  /* include/asm-arm/mach/map.h */
  struct map_desc {
  unsigned long virtual;
  unsigned long physical;
  unsigned long length;
  unsigned int type;
  create_mapping( )函数就是通过map_desc提供的信息创建线性映射表的。
  这样的话我们就知道了创建I/O映射表的大致流程为:只要定义相应I/O资源的map_desc结构体,并将该结构体传给iotable_init函数执行,就可以创建相应的I/O资源到内核虚拟地址空间的映射表了。
  我们来看看s3c2410是怎么定义map_desc结构体的(即上面iotable_init()函数内的s3c_iodesc)。
  [arch/arm/mach-s3c2410/CPU.c]
  /* minimal IO mapping */
  static struct map_desc s3c_iodesc[] __initdata = {
  IODESC_ENT(GPIO),
  IODESC_ENT(IRQ),
  IODESC_ENT(MEMCTRL),
  IODESC_ENT(UART)
  IODESC_ENT宏如下:
  #define IODESC_ENT(x) { (unsigned long)S3C24XX_VA_##x, S3C2410_PA_##x, S3C24XX_SZ_##x, MT_DEVICE }
  展开后等价于:
  .virtual = S3C24XX_VA_GPIO,
  .physical = S3C24XX_PA_GPIO,
  .length = S3C24XX_SZ_GPIO,
  .type = MT_DEVICE
  至此,我们可以比较清晰看到GPIO被静态映射的过程,由于我们在前面的静态映射中已经做好了GPIO的映射,也就是我们写GPIO相关驱动的时候可以如下配置引脚的原因:
  s3c2410_gpio_cfgpin(xxx,xxx);
  其实,s3c2410_gpio_cfgpin定义如下:
  void s3c2410_gpio_cfgpin(unsigned int pin, unsigned int function)
  void __iomem *base = S3C2410_GPIO_BASE(pin);
  unsigned long mask;
  unsigned long con;
  unsigned long flags;
  if (pin > 1) + S3C24XX_VA_GPIO)
  至此,GPIO的静态映射就看得很明白了。
  下面来看其他外设的静态映射:
  在s3c24xx_init_io()函数中,除了iotable_init()以为,还会在最后调用,
  (CPU->map_io)(mach_desc, size);
  而CPU的这个map_io在arch/arm/mach-s3c2410/cpu.c里面定义如下:
  static struct cpu_table cpu_ids[] __initdata = {
  .idcode = 0x32410000,
  .idmask = 0xffffffff,
  .map_io = s3c2410_map_io,
  .init_clocks = s3c2410_init_clocks,
  .init_uarts = s3c2410_init_uarts,
  .init = s3c2410_init,
  .name = name_s3c2410
  再查看s3c2410_map_io(),函数代码如下:
  void __init s3c2410_map_io(struct map_desc *mach_desc, int mach_size)
  iotable_init(s3c2410_iodesc, ARRAY_SIZE(s3c2410_iodesc));
  iotable_init(mach_desc, mach_size);
  接下来看结构s3c2410_iodesc [arch/arm/mach-s3c2410/s3c2410.c],代码如下,
  /* Initial IO mappings */
  static struct map_desc s3c2410_iodesc[] __initdata = {
  IODESC_ENT(USBHOST),
  IODESC_ENT(USBDEV),
  IODESC_ENT(CLKPWR),
  IODESC_ENT(LCD),
  IODESC_ENT(TIMER),
  IODESC_ENT(ADC),
  IODESC_ENT(WATCHDOG),
  赫然发现IODESC_ENT(TIMER)这一行,结合之前GPIO的类似分析,IODESC_ENT宏如下:
  至此,TIMER, USBHOST,USBDEV,lcd,adc,watchdog等的静态映射都看得很明白了。
  “本文由华清远见http://www.embedu.org/index.htm提供”
GMT+8, 2026-4-27 05:01 , 耗时 0.102192 秒, 18 个查询请求 , Gzip 开启.
