查看: 349|回复: 0
混合式调度器C51源代码
发表于 2012-1-18 00:59:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1ms时标 混合式调度器(一个抢占式任务,多个合作式任务)
作者:shadow.hu
#include
#define uchar  unsigned char
#define ushort unsigned short
#define SCH_MAX_TASKS 9
#define ERROR_SCH_TOO_MANY_TASKS  9
#define ERROR_SCH_CANOT_DELETE_TASK 0
#define RETURN_ERROR 0
#define RETURN_NORMAL 1
#define INTERRPT_Timer_2_Overflow 5
#define SCH_REPORT_ERRORS
#ifdef  SCH_REPORT_ERRORS
#define Error_Port P1
#endif
typedef data struct
    void (code *pTask)(void);
ushort Delay;
ushort Period;
ushort RunMe;
uchar  Co_op;//如果任务是合作式的,设置为1,如果任务是抢占式的,设置为0
}sTask;
sTask SCH_tasks_G[SCH_MAX_TASKS];
void SCH_Init_T2(void);
uchar SCH_Add_Task(void (code * pFunction)(),const ushort Delay,   ushort PERIOD);
//                      函数名指针                 延时的时标数    执行任务的时间间隔
//                                                 为0则立即执行   如果为0,表示单次任务
void SCH_Dispatch_Tasks(void);
void SCH_Start(void);
bit SCH_Delete_Task(const ushort TASK_INDEX);
void SCH_Go_To_Sleep(void);
void SCH_Report_Status(void);//报告系统状况
void LED_Flash_Init(void);
void LED_Flash_Update_A(void);
void LED_Flash_Update_B(void);
void LED_Flash_Update_C(void);
void LED_Flash_Update_D(void);
void LED_Flash_Update_E(void);
void LED_Flash_Update_F(void);
void LED_Flash_Update_G(void);
void LED_Flash_Update_H(void);
uchar Error_code_G = 0;//
static ushort Error_tick_count_G;//记住自从上一次纪录错误以来的时间
static uchar Last_error_code_G;//上次的错误代码(在1分钟之后复位)
uchar  LED_State_G_A = 0;
uchar  LED_State_G_B = 0;
uchar  LED_State_G_C = 0;
uchar  LED_State_G_D = 0;
uchar  LED_State_G_E = 0;
uchar  LED_State_G_F = 0;
uchar  LED_State_G_G = 0;
uchar  LED_State_G_H = 0;
sbit LED_pin_A = P1^0;
sbit LED_pin_B = P1^1;
sbit LED_pin_C = P1^2;
sbit LED_pin_D = P1^3;
sbit LED_pin_E = P1^4;
sbit LED_pin_F = P1^5;
sbit LED_pin_G = P1^6;
sbit LED_pin_H = P1^7;
//Error_code_G = ERROR_SCH_TOO_MANY_TASKS;
//Error_code_G = ERROR_SCH_WAITING_FOR_SLAVE_TO_ACK;
//Error_code_G = ERROR_SCH_WAITING_FOR_START_COMAND_FROM_MASTER;
//Error_code_G = ERROR_SCH_ONE_OR_MORE_SLAVES_DID_NOT_START;
//Error_code_G = ERROR_SCH_LOST_SLAVE;
//Error_code_G = ERROR_SCH_CAN_BUS_ERROR;
//Error_code_G = ERROR_I2C_WRITE_BYTE_AT24C64;
void main(void)
SCH_Init_T2();
LED_Flash_Init();
SCH_Add_Task(LED_Flash_Update_A,0,1000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_B,0,2000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_C,0,3000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_D,0,4000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_E,0,5000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_F,0,6000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_G,0,7000);//添加一个任务
SCH_Add_Task(LED_Flash_Update_H,0,8000);//添加一个任务
SCH_Start();//开全局中断
while(1)
  SCH_Dispatch_Tasks();
这是调度器的中断服务程序,初始化函数中的定时器设置决定了它
的调度频率,这个版本的调度器由定时器2触发中断,定时器自动重装。
void SCH_Update(void) interrupt INTERRPT_Timer_2_Overflow
//刷新任务队列
uchar Index;
TF2 = 0;//必须手工清除
//注意:计算单位为时标(不是毫秒)
for(Index = 0;Index  0)&&(SCH_tasks_G[Index].Co_op))
   (*SCH_tasks_G[Index].pTask)();//执行任务
   SCH_tasks_G[Index].RunMe -= 1;//清除任务需要执行的标志
  //如果这是个“单次”任务,将它从队列中删除
  if(SCH_tasks_G[Index].Period == 0)
   SCH_tasks_G[Index].pTask = 0;// 比通过调用来删除任务更快SCH_Delete_Task(Index);
SCH_Report_Status();//报告系统状况
SCH_Go_To_Sleep();
EA = 1;
bit Return_code;
if(SCH_tasks_G[TASK_INDEX].pTask == 0)
  //这里没有任务。。。设置全局错误变量
  Error_code_G = ERROR_SCH_CANOT_DELETE_TASK;
  Return_code = RETURN_ERROR;//返回错误代码
else
  Return_code = RETURN_NORMAL;
//删除任务
SCH_tasks_G[TASK_INDEX].pTask = 0x0000;
SCH_tasks_G[TASK_INDEX].Delay = 0;
SCH_tasks_G[TASK_INDEX].Period = 0;
SCH_tasks_G[TASK_INDEX].RunMe = 0;
return Return_code;
void SCH_Go_To_Sleep()
PCON |= 0x01;//进入休眠模式
/* #ifdef SCH_REPORT_ERRORS
if(Error_code_G != Last_error_code_G)
  Error_Port = 255 - Error_code_G;
  Last_error_code_G = Error_code_G;
  if(Error_code_G != 0)
   Error_tick_count_G = 60000;
  else
   Error_tick_count_G = 0;
else
  if(Error_tick_count_G != 0)
   if(--Error_count_G == 0)
    Error_code_G = 0;
#endif    */
if(LED_State_G_A == 1)
  LED_State_G_A = 0;
  LED_pin_A = 0;
else
  LED_State_G_A = 1;
  LED_pin_A = 1;
if(LED_State_G_B == 1)
  LED_State_G_B = 0;
  LED_pin_B = 0;
else
  LED_State_G_B = 1;
  LED_pin_B = 1;
if(LED_State_G_C == 1)
  LED_State_G_C = 0;
  LED_pin_C = 0;
else
  LED_State_G_C = 1;
  LED_pin_C = 1;
if(LED_State_G_D == 1)
  LED_State_G_D = 0;
  LED_pin_D = 0;
else
  LED_State_G_D = 1;
  LED_pin_D = 1;
if(LED_State_G_E == 1)
  LED_State_G_E = 0;
  LED_pin_E = 0;
else
  LED_State_G_E = 1;
  LED_pin_E = 1;
if(LED_State_G_F == 1)
  LED_State_G_F = 0;
  LED_pin_F = 0;
else
  LED_State_G_F = 1;
  LED_pin_F = 1;
if(LED_State_G_G == 1)
  LED_State_G_G = 0;
  LED_pin_G = 0;
else
  LED_State_G_G = 1;
  LED_pin_G = 1;
if(LED_State_G_H == 1)
  LED_State_G_H = 0;
  LED_pin_H = 0;
else
  LED_State_G_H = 1;
  LED_pin_H = 1;
LED_State_G_A= 0;//初始化LED状态
LED_State_G_B= 0;//初始化LED状态
LED_State_G_C= 0;//初始化LED状态
GMT+8, 2026-3-25 05:12 , 耗时 0.102249 秒, 19 个查询请求 , Gzip 开启.
