查看: 137|回复: 0
C#中用API实现MP3等音频文件的播放类
发表于 2012-1-22 00:19:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
C#没有提供播放MP3等音频文件的类,要编写播放MP3等音频文件程序,必须使用第三方控件或类。本文使用API函数mciSendString,编写一个播放MP3等音频文件的类。 具体源码如下: 一、使用API函数mciSendString构成的媒体播放类。 using System; using System.Runtime.InteropServices; using System.Text; using System.IO ; namespace clsMCIPlay {   ///   /// clsMci 的摘要说明。   ///   public class clsMCI   { public clsMCI() {   //   // TODO: 在此处添加构造函数逻辑   // } //定义API函数使用的字符串变量 [MarshalAs(Unmana gedType.byValTStr,SizeConst=260)] private string Name = "" ; [MarshalAs(UnmanagedType.byValTStr,SizeConst=128)] private string durLength = "" ; [MarshalAs(UnmanagedType.LPTStr,SizeConst=128)] private string TemStr =""; int ilong; //定义播放状态枚举变量 public enum State {   mPlaying = 1,   mPuase = 2,   mStop = 3 }; //结构变量 public struct structMCI {   public bool bMut;   public int iDur;   public int iPos;   public int iVol;   public int ibal;   public string iName;   public State state; }; public structMCI mc =new structMCI() ; //取得播放文件属性 public string FileName {   get   { return mc.iName;   }   set   { //ASCIIEncoding asc = new ASCIIEncoding(); try {   TemStr ="";   TemStr = TemStr.PadLeft(127,Convert.ToChar(" "));   Name = Name.PadLeft(260,Convert.ToChar(" ")) ;   mc.iName = value;   ilong = APIClass.GetShortPathName(mc.iName,Name, Name.Length);   Name = GetCurrPath(Name);   //Name = "open " + Convert.ToChar(34) + Name + Convert.ToChar(34) + " alias media";   Name = "open " + Convert.ToChar(34) + Name + Convert.ToChar(34) + " alias media";   ilong = APIClass.mciSendString("close all", TemStr, TemStr.Length , 0);   ilong = APIClass.mciSendString( Name, TemStr, TemStr.Length, 0);   ilong = APIClass.mciSendString("set media time format milliseconds", TemStr, TemStr.Length , 0);   mc.state = State.mStop; } catch {   Messagebox.Show("出错错误!"); }   } } //播放 public void play() {   TemStr = "";   TemStr = TemStr.PadLeft(127,Convert.ToChar(" "));   APIClass.mciSendString("play media", TemStr, TemStr.Length , 0);   mc.state = State.mPlaying ; } //停止
                                public void StopT() {   TemStr = "";   TemStr = TemStr.PadLeft(128,Convert.ToChar(" "));   ilong = APIClass.mciSendString("close media", TemStr, 128, 0);   ilong = APIClass.mciSendString("close all", TemStr, 128, 0);   mc.state = State.mStop ; } public void Puase() {   TemStr = "";   TemS tr = TemStr.PadLeft(128,Convert.ToChar(" "));   ilong = APIClass.mciSendString("pause media", TemStr, TemStr.Length, 0);   mc.state = State.mPuase ; } private string GetCurrPath(string name) {   if(name.Length <1) return "";   name = name.Trim();   name = name.Substring(0,name.Length-1);   return name; } //总时间 public int Duration {   get   { durLength = ""; durLength = durLength.PadLeft(128,Convert.ToChar(" ")) ; APIClass.mciSendString("status media length", durLength, durLength.Length, 0); durLength = durLength.Trim(); if(durLength == "") return 0; return (int)(Convert.ToDouble(durLength) / 1000f);   } } //当前时间 public int CurrentPosition {   get   { durLength = ""; durLength = durLength.PadLeft(128,Convert.ToChar(" ")) ; APIClass.mciSendString("status media position", durLength, durLength.Length, 0); mc.iPos = (int)(Convert.ToDouble(durLength) / 1000f); return mc.iPos;   } }   }   public class APIClass   { [DllImport("kernel32.dll", CharSet = CharSet.Auto)] public static extern int GetShortPathName (   string lpszLongPath,   string shortFile,   int cchbuffer ); [DllImport("winmm.dll", EntryPoint="mciSendString", CharSet = CharSet.Auto)] public static extern int mciSendString (   string lpstrCommand,   string lpstrReturnString,   int uReturnLength,   int hwndCallback );   } }
GMT+8, 2025-7-21 22:54 , 耗时 0.083121 秒, 18 个查询请求 , Gzip 开启.
