查看: 397|回复: 0
PIC单片机实现CRC的小程序
发表于 2012-1-27 18:22:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PIC单片机实现CRC的小程序PIC单片机实现Dallas的iButton通讯时,编了段产生和校验CRC的子程序。IC单片机 www.pic16.com    #include ;-------------------------------    cblock    0x20datBuff:8            ;assign 8 byte data bufferbit_cnt                ;bit counting CRC_COUNT            ;number of bytes for CRCCRC_RESULT            ;CRC resulrcrc_temp            ;temporary data buffer during CRC    endc;-------------------------------#define    skp0    btfsc#define    skp1    btfss;===============================    org    0x000    movlw    .7    movwf    CRC_COUNT    movlw    datBuff    movwf    FSR        ;FSR point to data buffer    call    CRC_CHECK    movwf    datBuff+7    goto    $;===============================;CHECK THE CRC FOR ? BYTES DATA;For the polynomial of X^8 + X^5 + X^4 + 1;Derived from Dallas's iButton standard;Before calling, FSR       = data buffer;                CRC_COUNT = number of bytes for CRCCRC_CHECK    ;"""""""""""""""    clrf    CRC_RESULT    ;initialize the CRC buffer_crc_00    movlw    .8        ;number of bits for one byte    movwf    bit_cnt        ;set bit counter    movf    INDF,w        ;get one data byte    movwf    crc_temp    ;copy to temporary location_crc_01    rrf    crc_temp,f    ;get LSB in C    skpc            ;is this LSB=1?    goto    _crc_02        ;go if LSB=0    movlw    0x01        ;do if LSB=1    xorwf    CRC_RESULT,f_crc_02    rrf    CRC_RESULT,w    ;get LSB of CRC    skpc            ;test LSB    goto    _crc_03        ;go if LSB=0    movlw    0x18        ;do if LSB=1    xorwf    CRC_RESULT,f    ;polynomial implementation_crc_03    rrf    CRC_RESULT,w    ;whole byte right rotate    rrf    CRC_RESULT,f    decfsz    bit_cnt,f    ;bit counting    goto    _crc_01        ;go on until aa 8 bits done    incf    FSR,f        ;pointer update to next byte    decfsz    CRC_COUNT,f    ;byte counting    goto    _crc_00        ;go on until all byte done    movf    CRC_RESULT,w    ;get CRC, Z set if CRC=0    return            ;return with CRC in W    END
GMT+8, 2025-12-31 12:12 , 耗时 0.096514 秒, 19 个查询请求 , Gzip 开启.
