查看: 228|回复: 0
单片机音乐程序设计(含源程序)
发表于 2011-4-29 20:05:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
单片机音乐程序设计
随便找一个仿真机或者什么单片机实验板,只要能工作的就行,将程序输入,运行,然后找个音箱(你计算机旁边应当就有一对吧)拨出插头,插头的前端接在P1。0上,后面部分找根线接单片机的地,就应当有声了,然后怎么改进硬件连接就是你的事了。。。。
音乐程序汇编代码代码1 -------------Voice.asm--------------------------
ORG 0000H
LJMP START
ORG 000BH
INC 20H ;中断服务,中断计数器加1
MOV TH0,#0D8H
MOV TL0,#0EFH ;12M晶振,形成10毫秒中断
RETI
START:
MOV SP,#50H
MOV TH0,#0D8H
MOV TL0,#0EFH
MOV TMOD,#01H
MOV IE,#82H
MUSIC0:
NOP
MOV DPTR,#DAT ;表头地址送DPTR
MOV 20H,#00H ;中断计数器清0
MOV B,#00H ;表序号清0
MUSIC1:
NOP
CLR A
MOVC A,@A+DPTR ;查表取代码
JZ END0 ;是00H,则结束
CJNE A,#0FFH,MUSIC5
LJMP MUSIC3
MUSIC5:
NOP
MOV R6,A
INC DPTR
MOV A,B
MOVC A,@A+DPTR ;取节拍代码送R7
MOV R7,A
SETB TR0 ;启动计数
MUSIC2:
NOP
CPL P1.0
MOV A,R6
MOV R3,A
LCALL DEL
MOV A,R7
CJNE A,20H,MUSIC2 ;中断计数器(20H)=R7否?
;不等,则继续循环
MOV 20H,#00H ;等于,则取下一代码
INC DPTR
; INC B
LJMP MUSIC1
MUSIC3:
NOP
CLR TR0 ;休止100毫秒
MOV R2,#0DH
MUSIC4:
NOP
MOV R3,#0FFH
LCALL DEL
DJNZ R2,MUSIC4
INC DPTR
LJMP MUSIC1
END0:
NOP
MOV R2,#64H ;歌曲结束,延时1秒后继续
MUSIC6:
MOV R3,#00H
LCALL DEL
DJNZ R2,MUSIC6
LJMP MUSIC0
DEL:
NOP
DEL3:
MOV R4,#02H
DEL4:
NOP
DJNZ R4,DEL4
NOP
DJNZ R3,DEL3
RET
NOP
DAT:
db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h
db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h
db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h
db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h
db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h
db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h
db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h
db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h
db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h
db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h
db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h
db 20h,10h,2bh,10h,26h,30h,30h,80h,00H
END
音乐程序汇编代码代码2 -------------Voice1.asm--------------------------
;标题 '八月桂花香'发声程序
;摘要 详见'无线电'92年3期
;作者 周振安
ORG 0000H
LJMP START
ORG 000BH
MOV TH0,#0D8H
RETI
START:
MOV SP,#50H
MOV TH0,#0D8H
MOV TL0,#0EFH
MOV TMOD,#01H
MOV IE,#82H
MUSIC0:
NOP
MOV B,#00H ;表序号清0
MUSIC1:
NOP
CLR A
JZ END0 ;是00H,则结束
CJNE A,#0FFH,MUSIC5
LJMP MUSIC3
MUSIC5:
NOP
MOV R6,A
INC DPTR
MOV A,B
MOV R7,A
SETB TR0 ;启动计数
MUSIC2:
NOP
CPL P1.0
MOV A,R6
MOV R3,A
LCALL DEL
MOV A,R7
;不等,则继续循环
INC DPTR
; INC B
LJMP MUSIC1
MUSIC3:
NOP
CLR TR0 ;休止100毫秒
MOV R2,#0DH
MUSIC4:
NOP
MOV R3,#0FFH
LCALL DEL
DJNZ R2,MUSIC4
INC DPTR
LJMP MUSIC1
END0:
NOP
MUSIC6:
MOV R3,#00H
LCALL DEL
DJNZ R2,MUSIC6
LJMP MUSIC0
DEL:
NOP
DEL3:
MOV R4,#02H
DEL4:
NOP
DJNZ R4,DEL4
NOP
DJNZ R3,DEL3
RET
NOP
DAT:
DB 18H, 30H, 1CH, 10H
DB 20H, 40H, 1CH, 10H
DB 18H, 10H, 20H, 10H
DB 1CH, 10H, 18H, 40H
DB 1CH, 20H, 20H, 20H
DB 1CH, 20H, 18H, 20H
DB 20H, 80H, 0FFH, 20H
DB 30H, 1CH, 10H , 18H
DB 20H, 15H, 20H , 1CH
DB 20H, 20H, 20H , 26H
DB 40H, 20H , 20H , 2BH
DB 20H, 26H, 20H , 20H
DB 20H, 30H , 80H , 0FFH
DB 20H, 20H, 1CH , 10H
DB 18H, 10H, 20H , 20H
DB 26H, 20H , 2BH , 20H
DB 30H, 20H , 2BH , 40H
DB 20H, 20H , 1CH , 10H
DB 18H, 10H, 20H, 20H
DB 26H, 20H , 2BH, 20H
DB 30H, 20H, 2BH , 40H
DB 20H, 30H, 1CH , 10H
DB 18H, 20H , 15H , 20H
DB 1CH, 20H , 20H , 20H
DB 26H, 40H, 20H , 20H
DB 2BH, 20H, 26H , 20H
DB 20H, 20H, 30H , 80H
DB 20H, 10H, 1CH , 10H
DB 20H, 20H, 26H , 20H
DB 2BH, 20H, 30H , 20H
DB 2BH, 40H, 20H , 15H
DB 1FH, 05H, 20H , 10H
DB 1CH, 10H, 20H , 20H
DB 26H, 20H, 2BH , 20H
DB 20H, 20H, 30H, 30H
DB 20H, 30H, 1CH, 10H
DB 18H, 40H, 1CH, 20H
DB 20H, 20H, 26H, 40H
DB 13H, 60H, 18H , 20H
DB 15H, 40H, 13H , 40H
DB 18H, 80H, 00H
end
GMT+8, 2025-11-21 05:21 , 耗时 0.090787 秒, 18 个查询请求 , Gzip 开启.
