查看: 334|回复: 0
PIC16Fxxx的LCD驱动程序(适用于HD44780兼容
发表于 2011-4-30 10:55:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PIC16Fxxx的LCD驱动程序(适用于HD44780兼容的驱动器)
;* LCD.ASM *
;* Contains subroutines to control an external *
;* lcd panel in 4-bit mode. These routines *
;* were designed specifically for the panel on *
;* the MCU201 workshop demo board, but should *
;* work with other LCDs with a HD44780 type *
;* controller. *
;* Routines include: *
;* - InitLCD to initialize the LCD panel *
;* - putcLCD to write a character to LCD *
;* - SendCmd to write a command to LCD *
;* - clrLCD to clear the LCD display *
;* - L1homeLCD to return cursor to line 1 home*
;* - L2homeLCD to return cursor to line 2 home*
;* - PutHexLCD to write a HEX Code to LCD *
;* - Hex2ASCII to convert 4 bits to ASCII Code*
list p=16f877
#i nclude
; Defines for I/O ports that provide LCD data & control
; PORTB.0 - PORTB.3 are Data Pins for LCD Module
; PORTB.4 is E Control Signal for LCD
; PORTB.5 is RS Control Signal for LCD
; PORTC.2 is BackLight Control pin for LCD Module
global InitLCD
global putcLCD
global clrLCD
global L1homeLCD
global L2homeLCD
global SendCmd
global PutHexLCD
global Hex2ASCII
LCD_DATA equ PORTB
LCD_CNTL equ PORTB
; Defines for I/O pins that provide LCD control
RS equ 5
E equ 4
; LCD Module commands
DISP_ON EQU 0x00C ; Display on
DISP_ON_C EQU 0x00E ; Display on, Cursor on
DISP_ON_B EQU 0x00F ; Display on, Cursor on, Blink cursor
DISP_OFF EQU 0x008 ; Display off
CLR_DISP EQU 0x001 ; Clear the Display
ENTRY_INC EQU 0x006 ;
ENTRY_INC_S EQU 0x007 ;
ENTRY_DEC EQU 0x004 ;
ENTRY_DEC_S EQU 0x005 ;
DD_RAM_ADDR EQU 0x080 ; Least Significant 7-bit are for address
DD_RAM_UL EQU 0x080 ; Upper Left coner of the Display
; Directs linker to provide 4 variables in GPR memory
UDATA
Byte RES 1
Byte1 RES 1
Count RES 1
Count1 RES 1
W_BUFR RES 1
Hex_Bfr RES 1
PROG1 CODE
;* The LCD Module Subroutines *
;* Command sequence for 2 lines of 5x16 characters *
InitLCD
BANKSEL TRISB
movlw 0xc0 ; Initialize inputs/outputs for LCD
movwf TRISB
BANKSEL LCD_DATA
clrf LCD_DATA ; Clear LCD data & control bits
movlw .50 ; Power=On delay 50mS
Call Delay_MS
movlw 0x02 ; Init for 4-bit interface
call Send_4bit
movlw .10 ; Delay 10 mS
Call Delay_MS
movlw b'00000011' ; Fully Initial LCD module
call Send_4bit ; Sent '0011' data 4 time
movlw .5 ; Delay 5mS
Call Delay_MS
movlw b'00000011'
call Send_4bit
call Delay_1MS ; Delay 1mS
movlw b'00000011'
call Send_4bit
movlw b'00000010'
call Send_4bit
movlw b'00101000' ; Set 2 lines & 5 x 7 dots
call SendCmd
movlw DISP_ON ; Turn display on (0x0C)
call SendCmd
movlw ENTRY_INC ; Configure cursor movement
call SendCmd
movlw DD_RAM_ADDR ; Set writes for display memory
call SendCmd
return
;*SendChar - Sends character to LCD *
;*This routine splits the character into the upper and lower *
;*nibbles and sends them to the LCD, upper nibble first. *
putcLCD
banksel Byte
movwf Byte ; Save WREG in Byte variable
call Delay_1MS
swapf Byte,W ; Write upper nibble first
andlw 0x0f
movwf LCD_DATA
bsf LCD_CNTL, RS ; Set for data
bsf LCD_CNTL, E ; Clock nibble into LCD
bcf LCD_CNTL, E
movf Byte,W ; Write lower nibble last
andlw 0x0f
movwf LCD_DATA
bcf LCD_CNTL, E
return
;* To put the HEX value to LCD Display ,,
;* High nibble first than Low nibble
;* Input : W Reg.
PutHexLCD
banksel W_BUFR
movwf W_BUFR ; Save W Register !!
swapf W_BUFR,W ; High nibble first !!
call Hex2ASCII
call putcLCD
movf W_BUFR,W
call Hex2ASCII
call putcLCD
return
;* Convert a low nibble to ASCII code
;* Input : W Reg.
;* Output: W Reg.
Hex2ASCII
andlw 0x0f ; Mask Bit 4 to 7
movwf Hex_Bfr
sublw .09
btfsc STATUS,C ; If W less than A (C=1) --> only add 30h
goto Add_W_30
Add_W_37 movlw 0x37
goto Hex_cont
Add_W_30 movlw 0x30
Hex_cont addwf Hex_Bfr,W ; The correct ASCII code for this char !!
return
;* SendCmd - Sends command to LCD *
;* This routine splits the command into the upper and lower *
;* nibbles and sends them to the LCD, upper nibble first. *
SendCmd
banksel Byte
call Delay_1MS
swapf Byte,W ; Send upper nibble first
andlw 0x0f
movwf LCD_DATA
bcf LCD_CNTL,RS ; Clear for command
bsf LCD_CNTL,E ; Clock nibble into LCD
bcf LCD_CNTL,E
Send_4bit andlw 0x0f
movwf LCD_DATA
bcf LCD_CNTL,E
return
;* clrLCD - Clear the contents of the LCD *
clrLCD
movlw CLR_DISP ; Send the command to clear display
call SendCmd
return
;* L1homeLCD - Moves the cursor to home position on Line 1 *
L1homeLCD
movlw DD_RAM_ADDR|0x00 ; Send command to move cursor to
call SendCmd ; home position on line 1
return
;* L2homeLCD - Moves the cursor to home position on Line 2 *
L2homeLCD
movlw DD_RAM_ADDR|0x28 ; Send command to move cursor to
call SendCmd ; home position on line 2
return
;* Delay - Generic LCD delay (1.024mS @ 4MHz) *
;* Since the microcontroller can not read the busy flag of the *
;* LCD, a specific delay needs to be executed between writes to *
;* the LCD. *
Delay_1MS ; 2 cycles for call
clrf Count ; 1 cycle to clear counter variable
Dloop
nop
decfsz Count,F ; These two instructions provide a
goto Dloop ; (256 * 3) -1 cycle count
return ; 2 cycles for return
;* Delay - 1mS base delay *
;* input : W Reg. *
Delay_MS
movwf Count1
DLop1 call Delay_1MS
decfsz Count1,F
goto DLop1
return
END
GMT+8, 2026-3-23 13:06 , 耗时 0.149277 秒, 18 个查询请求 , Gzip 开启.
