查看: 180|回复: 0
液晶显示屏模块1602驱动程序源代码
发表于 2011-4-30 13:25:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
液晶显示屏模块1602驱动程序源代码
//lcd1602 drive program for 51 mcu
//designed by Wangchao
//2006-6-14
#i nclude "reg52.h"
//lcd part
#define LINE10
#define LINE21
#define LINE1_HEAD0x80
#define LINE2_HEAD0xC0
#define LCD_DELAY_TIME40
#define DATA_MODE0x38
#define OPEN_SCREEN0x0C
#define DISPLAY_ADDRESS0x80
#define CLEARSCREENLCD_en_command(0x01)
//common part
#define HIGH1
#define LOW 0
#define TRUE 1
#define ZERO 0
//change this part at different board
#define LCDIOP2
sbit LCD1602_RS=P0^7;//data command select1 data0 commandpin 4
sbit LCD1602_RW=P0^6;//read write select1 read 0 write pin 5
sbit LCD1602_EN=P0^5;//LCD enable signal pin 6
void LCD_delay(void);//lcd delay
void LCD_en_command(unsigned char command);//write command
void LCD_en_dat(unsigned char temp);//write data
void LCD_set_xy( unsigned char x, unsigned char y );//set display address
void LCD_write_char( unsigned x,unsigned char y,unsigned char dat);//write lcd a character
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);//write lcd string
void LCD_init(void);//lcd initize
void delay_nms(unsigned int n);//delay
void main(void)
LCD_init();
while(TRUE )
CLEARSCREEN;
delay_nms(2);
LCD_write_string(0,LINE1,"Wellcome to DLUT");
LCD_write_string(0,LINE2,"www.dlut.edu.cn!");
delay_nms(500);
CLEARSCREEN;
delay_nms(2);
LCD_write_string(0,LINE1," lcd test ");
LCD_write_string(0,LINE2," successful! ");
delay_nms(500);
CLEARSCREEN;
delay_nms(2);
LCD_write_string(0,LINE1," I'm WangChao. ");
LCD_write_string(0,LINE2," Thank You! ");
delay_nms(500);
/******************** LCD PART *************************************/
unsigned char i;
for(i=LCD_DELAY_TIME;i>ZERO;i--) //be sure lcd reset
LCDIO=command;
LCD1602_RS=LOW;
LCD1602_RW=LOW;
LCD1602_EN=LOW;
LCD_delay();
LCD1602_EN=HIGH;
void LCD_en_dat(unsigned char dat)
LCDIO=dat;
LCD1602_RS=HIGH;
LCD1602_RW=LOW;
LCD1602_EN=LOW;
LCD_delay();
LCD1602_EN=HIGH;
unsigned char address;
if (y == LINE1)
address = LINE1_HEAD + x;
else
address = LINE2_HEAD + x;
LCD_en_command(address);
LCD_set_xy( x, y );
LCD_en_dat(dat);
LCD_set_xy( X, Y ); //set address
while (*s) // write character
LCDIO=*s;
LCD_en_dat(*s);
s ++;
void LCD_init(void)
CLEARSCREEN;//clear screen
LCD_en_command(DATA_MODE);//set 8 bit data transmission mode
LCD_en_command(OPEN_SCREEN);//open display (enable lcd display)
LCD_en_command(DISPLAY_ADDRESS);//set lcd first display address
/*********************** OTHER PART *********************************/
unsigned int i=0,j=0;
for (i=n;i>0;i--)
for (j=0;j<1140;j++);
GMT+8, 2026-4-4 13:07 , 耗时 0.089222 秒, 19 个查询请求 , Gzip 开启.
